  3. Error verifying DhtTemperatureAndHumiditySensor Script wont compile
6 Posts 2 Posters 3.5k Views 2 Watching
  • S
    sentur
    wrote on last edited by sentur
    I'm trying to setup a mysensor with DHT22 sensor. Following the DhtTemperatureAndHumiditySensor.io script on the website and additional example scripts on Github.
    However the code wont verify / compile without an error saying it's missing DHT::Class().
    I'm using the Arduino IDE 1.8.5, the MySensors library installed through IDE, MySensors Library 2.1.1.
    I'm trying to verify the code to finall upload to an Arduino Pro Mini at 8mhz using an FTDI programmer over USB. But I don't think that should matter.
    Here's the error:
    DhtTemperatureAndHumiditySensor:73: error: no matching function for call to 'DHT::DHT()'
     DHT dht;
    /Users/enwhat/Desktop/DhtTemperatureAndHumiditySensor/DhtTemperatureAndHumiditySensor.ino:73:5: note: candidates are:
    In file included from /Users/enwhat/Desktop/DhtTemperatureAndHumiditySensor/DhtTemperatureAndHumiditySensor.ino:44:0:
    /Volumes/Data/Users/enwhat/Documents/Arduino/libraries/DHT-sensor-library-master/DHT.h:40:4: note: DHT::DHT(uint8_t, uint8_t, uint8_t)
        DHT(uint8_t pin, uint8_t type, uint8_t count=6);
    /Volumes/Data/Users/enwhat/Documents/Arduino/libraries/DHT-sensor-library-master/DHT.h:40:4: note:   candidate expects 3 arguments, 0 provided
    /Volumes/Data/Users/enwhat/Documents/Arduino/libraries/DHT-sensor-library-master/DHT.h:38:7: note: constexpr DHT::DHT(const DHT&)
     class DHT {
    /Volumes/Data/Users/enwhat/Documents/Arduino/libraries/DHT-sensor-library-master/DHT.h:38:7: note:   candidate expects 1 argument, 0 provided
    /Volumes/Data/Users/enwhat/Documents/Arduino/libraries/DHT-sensor-library-master/DHT.h:38:7: note: constexpr DHT::DHT(DHT&&)
    /Users/enwhat/Desktop/DhtTemperatureAndHumiditySensor/DhtTemperatureAndHumiditySensor.ino: In function 'void setup()':
    DhtTemperatureAndHumiditySensor:91: error: 'class DHT' has no member named 'setup'
    DhtTemperatureAndHumiditySensor:92: error: 'class DHT' has no member named 'getMinimumSamplingPeriod'
    DhtTemperatureAndHumiditySensor:97: error: 'class DHT' has no member named 'getMinimumSamplingPeriod'
    /Users/enwhat/Desktop/DhtTemperatureAndHumiditySensor/DhtTemperatureAndHumiditySensor.ino: In function 'void loop()':
    DhtTemperatureAndHumiditySensor:104: error: 'class DHT' has no member named 'readSensor'
       dht.readSensor(true);
    DhtTemperatureAndHumiditySensor:107: error: 'class DHT' has no member named 'getTemperature'
    DhtTemperatureAndHumiditySensor:114: error: 'class DHT' has no member named 'toFahrenheit'
    DhtTemperatureAndHumiditySensor:131: error: 'class DHT' has no member named 'getHumidity'
    exit status 1
    option enabled in File -> Preferences.
    Note: there's an additional DHTtester.io script in File>Examples> that I can compile / verify without any errors. It appears to reference a DHT library without any issues.
    Here's the full DHTtester script:
    // Example testing sketch for various DHT humidity/temperature sensors
    // Written by ladyada, public domain
    #include "DHT.h"
    #define DHTPIN 2     // what digital pin we're connected to
    // Uncomment whatever type you're using!
    //#define DHTTYPE DHT11   // DHT 11
    #define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
    //#define DHTTYPE DHT21   // DHT 21 (AM2301)
    // Connect pin 1 (on the left) of the sensor to +5V
    // NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
    // to 3.3V instead of 5V!
    // Connect pin 2 of the sensor to whatever your DHTPIN is
    // Connect pin 4 (on the right) of the sensor to GROUND
    // Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
    // Initialize DHT sensor.
    // Note that older versions of this library took an optional third parameter to
    // tweak the timings for faster processors.  This parameter is no longer needed
    // as the current DHT reading algorithm adjusts itself to work on faster procs.
    DHT dht(DHTPIN, DHTTYPE);
      Serial.begin(9600);
      Serial.println("DHTxx test!");
      dht.begin();
      // Wait a few seconds between measurements.
      delay(2000);
      // Reading temperature or humidity takes about 250 milliseconds!
      // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
      float h = dht.readHumidity();
      // Read temperature as Celsius (the default)
      float t = dht.readTemperature();
      // Read temperature as Fahrenheit (isFahrenheit = true)
      float f = dht.readTemperature(true);
      // Check if any reads failed and exit early (to try again).
      if (isnan(h) || isnan(t) || isnan(f)) {
        Serial.println("Failed to read from DHT sensor!");
        return;
      // Compute heat index in Fahrenheit (the default)
      float hif = dht.computeHeatIndex(f, h);
      // Compute heat index in Celsius (isFahreheit = false)
      float hic = dht.computeHeatIndex(t, h, false);
      Serial.print("Humidity: ");
      Serial.print(h);
      Serial.print(" %\t");
      Serial.print("Temperature: ");
      Serial.print(t);
      Serial.print(" *C ");
      Serial.print(f);
      Serial.print(" *F\t");
      Serial.print("Heat index: ");
      Serial.print(hic);
      Serial.print(hif);
      Serial.println(" *F");
    • S sentur
      Here's the error:
       DHT dht;
       class DHT {
      exit status 1
      #include "DHT.h"
        Serial.begin(9600);
        dht.begin();
        delay(2000);
          return;
        Serial.print(h);
        Serial.print(t);
        Serial.print(f);
        Serial.print(hic);
        Serial.print(hif);
      Welcome to the MySensors community, @sentur !
      Could you post the full sketch that is causing the error?
      • S
        sentur
        Sure here's the sketch that wont compile.
         * Version 1.0: Henrik EKblad
        // Enable debug prints
        //#define MY_RS485
        #include <DHT.h>
        #define DHT_DATA_PIN 3
        #define SENSOR_TEMP_OFFSET 0
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        DHT dht;
          sendSketchInfo("TemperatureAndHumidity", "1.1");
          present(CHILD_ID_HUM, S_HUM);
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            Serial.println(temperature);
          } else {
            nNoUpdatesTemp++;
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
          } else {
            nNoUpdatesHum++;
          sleep(UPDATE_INTERVAL);
        • S sentur
          //#define MY_RS485
          #include <DHT.h>
          float lastTemp;
          float lastHum;
          bool metric = true;
          DHT dht;
              if (!metric) {
              nNoUpdatesTemp = 0;
              #ifdef MY_DEBUG
            } else {
              nNoUpdatesTemp++;
              lastHum = humidity;
              nNoUpdatesHum = 0;
              #ifdef MY_DEBUG
            } else {
              nNoUpdatesHum++;
          @sentur thanks.
          It seems like you have installed a DHT library that is very different from the DHT library used by MySensors.
          The DHTester script seems to be built for Adafriut's DHT library. When I try to compile that with the DHT library used by MySensors, I get a lot of errors:
          sketch_nov11b:10: error: 'DHT22' was not declared in this scope
          C:\Users\Micke\AppData\Local\Temp\arduino_modified_sketch_594104\sketch_nov11b.ino:24:17: note: in expansion of macro 'DHTTYPE'
          C:\Users\Micke\AppData\Local\Temp\arduino_modified_sketch_594104\sketch_nov11b.ino: In function 'void setup()':
          sketch_nov11b:30: error: 'class DHT' has no member named 'begin'
             dht.begin();
          C:\Users\Micke\AppData\Local\Temp\arduino_modified_sketch_594104\sketch_nov11b.ino: In function 'void loop()':
          sketch_nov11b:39: error: 'class DHT' has no member named 'readHumidity'
          sketch_nov11b:41: error: 'class DHT' has no member named 'readTemperature'
          sketch_nov11b:43: error: 'class DHT' has no member named 'readTemperature'
          sketch_nov11b:52: error: 'class DHT' has no member named 'computeHeatIndex'
          sketch_nov11b:54: error: 'class DHT' has no member named 'computeHeatIndex'
          Using library DHT in folder: R:\Documents\Arduino\libraries\DHT (legacy)
          exit status 1
          Since you don't get those errors, you probably have the Adafruit DHT library installed.
          You'll need to either convert your sketch to use the Adafruit library, or remove the Adafruit library and install the one used by MySensors instead.
          If you have already installed the MySensors DHT library, you should have gotten a message like this:
          Multiple libraries were found for "DHT.h"
           Used: R:\Documents\Arduino\libraries\DHT
           Not used: R:\Documents\Arduino\libraries\arduino_702005
          If I install the Adafruit DHT library, the DHTTest sketch compiles fine but I get the Multiple libraries error and the MySensors DHT example can no longer be compiled.
          • S
            sentur
            All sorted. I removed all my libraries and started a fresh and the issue has resolved itself. Definitely to do with some sort of library conflict as mentioned by @mfalkvidd
            • S sentur
              @sentur great that you found a solution. Thanks for reporting back.
