  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 75.4k Views 11 Watching
  • OitzuO
    OitzuO
    Oitzu
    @karl261 maybe a defect nrf24 module? The serial connection to the nano seems to work and should normaly show received messages.
    Do you have any spare modules laying arround?
    • karl261K
      karl261K
      karl261
      @Oitzu that is possible. And also weird. It was working for three weeks without problem. Is there no way to get an error message from the nrf24? Why does it work after unplugging the pi? Why does it not help to reset the sub bus, which should power cycle the nano and the radio module?
      I have some nrf24 around, but the installation is in a remote place which I can only access from time to time. That's why I installed mysensors and piratical in the first place. To remote control some things. So three weeks before I can try another radio. I hoped I could reset the system somehow to be able to use my system in the meantime...
      OitzuO 1 Reply Last reply
      • karl261K karl261
        OitzuO
        OitzuO
        Oitzu
        Well i can only guess whats the problem or whats the reason to it.
        A faulty device can fail at the first day or just after 3 weeks.
        The mysensors libs will check at start time the communication with the nrf24 module. If the communication don't work it will give out a "check wires" instead of the "Gateway startup complete.".
        Maybe the difference between the full power cycle and the nano power cycle is the duration of the power cycle?
        I can guess that the full power cycle left the nrf24 module for a longer time without power?
        A longer power down of the nano would result in more time for the caps to discharge?
        • karl261K
          karl261K
          karl261
          wrote on last edited by karl261
          #64
          @Oitzu thanks a lot for your help. I appreciate it.
          Some more observations:
          • If I reboot the pi, I get
          in the screen session.
          • However, if I do
          echo '1-1.5' > /sys/bus/usb/drivers/usb/unbind
          echo '1-1.5' > /sys/bus/usb/drivers/usb/bind
          which should power cycle the usb device I do not see anything in the screen session. Which means that the arduino nano was not power cycled.
          However I do see that something happened in the log file:
          Nov 12 17:31:40 raspberrypi kernel: [  300.831131] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
          Nov 12 17:31:40 raspberrypi kernel: [  300.839881] ftdi_sio 1-1.5:1.0: device disconnected
          Nov 12 17:31:46 raspberrypi kernel: [  306.271337] ftdi_sio 1-1.5:1.0: FTDI USB Serial Device converter detected
          Nov 12 17:31:46 raspberrypi kernel: [  306.278553] usb 1-1.5: Detected FT232RL
          Nov 12 17:31:46 raspberrypi kernel: [  306.283631] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB0
          So, what does it mean? I don't understand. Maybe there is something wrong with the pi's USB hub? Which is only reset when I pull the plug? But then the wifi should also not work, because it is sitting on the same USB hub.
          /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
              |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
                  |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
                  |__ Port 4: Dev 4, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
                  |__ Port 5: Dev 5, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
          I really don't like that there is no error message nowhere...
          Is there any other place I could ask for help?
          • karl261K
            karl261K
            karl261
            Ok, so I found a way to reset the usb bus using hub-ctrl.c. There is interesting information here:
            https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=93463
            https://github.com/codazoda/hub-ctrl.c
            https://www.raspberrypi.org/forums/viewtopic.php?t=71044&p=513908
            http://raspberrypi.stackexchange.com/questions/27903/usb-power-cycling-problem
            So, in my case I can issue the command
            ./hub-ctrl -h 0 -P 5 -p 0 ; sleep 3; ./hub-ctrl  -h 0 -P 5 -p 1
            and it does indeed reset the right port, because if I open now the screen sessoin I get the usual
            BUT: Still the thing is not sending receiving anything. WHY?
            • OitzuO
              OitzuO
              Oitzu
              Tried to extend the sleep between power down and up?
              • karl261K
                karl261K
                karl261
                Yes, I also tried with 30 seconds. Longer?
                • OitzuO
                  OitzuO
                  Oitzu
                  Well.. i think you can't lose anything. :D
                  Will be hard to debug after that without access to the actual hardware.
                  • karl261K
                    karl261K
                    karl261
                    So, I made some modifications to the Serial Gateway sketch so it includes
                    radio.printDetails();
                    I see that it is looping though the loop function, but I actually see NO ouput from this function. What does this mean? That there is actually no radio connected? Wouldn't it say something like "no radio" or so?
                    • OitzuO
                      OitzuO
                      Oitzu
                      https://github.com/mysensors/Arduino/blob/f9c8579bbdeaa50a0937287d4f7c14f794460540/libraries/MySensors/drivers/RF24/RF24.cpp#L455
                      Do you have MY_DEBUG_VERBOSE defined?
                      • karl261K
                        karl261K
                        karl261
                        Good point. I had not, now I have. But still, there is absolutely 0 output from this. The only message I see is the "Gateway startup complete" stuff.
                        fetsF 1 Reply Last reply
                        • E
                          E
                          edautz
                          wrote on last edited by edautz
                          #72
                          I use Pimatic for more than a year now and I am using the Mysensors plugin 0.8.21 for more than 4 weeks now.
                          I use a serial gateway based on a arduino nano and a NRF24 radio.
                          I have already several sensors running without troubles and it appear to be stable.
                          What I see from your information is that the serial gateway is communicating, but seems to recieve nothing from your sensors.
                          If you can see on the PI that your gateway is started up, then the PI is able to recieve the information.
                          I debugged my serial gateway using the
                          serial monitor in the Arduino ide. This is also the way to test your sensors. In the serial monitor you can see if they are connecting to the gateway and sending information.
                          • B
                            B
                            BastienVH
                            After using OpenHAB for quite some time, I've made the transition to Pimatic.
                            I've got a pro mini 3V running on 2 AA batteries with a DS18B20-temp-sensor.
                            I would like to be able to display the battery level but am having some trouble.
                            I combined the temp and battery sensor into 1, but the battery status isn't being analyzed properly.
                            When I restart the node it transmits a value of 12 and shortly after that a value of 0.
                            Any ideas how to solve this?
                            Is this related to pimatic and the format in which it receives battery data or is it simply a fault in my code?
                            Thanks in advance!
                            This is my code:
                             * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                             * http://www.mysensors.org/build/temp
                            #include <OneWire.h>
                            int numSensors=0;
                            int node_id = 12;
                            int oldBatteryPcnt = 0;
                            boolean metric = true;
                            MyMessage msg(0,V_TEMP);
                              sensors.begin();
                               analogReference(INTERNAL1V1);
                            #else
                               analogReference(INTERNAL);
                              gw.begin(NULL, node_id);
                              gw.sendSketchInfo("Temperature Sensor met battery", "1.0");
                                 gw.present(i, S_TEMP);
                               // get the battery Voltage
                               #ifdef DEBUG
                               Serial.println(sensorValue);
                               float batteryV  = sensorValue * 0.003363075;
                               #ifdef DEBUG
                               Serial.print(batteryV);
                               Serial.println(" V");
                               Serial.print(batteryPcnt);
                               Serial.println(" %");
                                 // Power up radio after sleep
                                 oldBatteryPcnt = batteryPcnt;}
                              gw.process();
                              gw.sleep(conversionTime);
                                #if COMPARE_TEMP == 1
                                #else
                              gw.sleep(SLEEP_TIME);
                            D 1 Reply Last reply
                            • B BastienVH
                              Thanks in advance!
                              This is my code:
                              int numSensors=0;
                              int node_id = 12;
                                sensors.begin();
                              #else
                                 #ifdef DEBUG
                                 #ifdef DEBUG
                                gw.process();
                                  #else
                              D
                              D
                              Dheeraj
                              wrote on last edited by Dheeraj
                              #74
                              @BastienVH . check few things first.
                              1. hardware wiring is correct and as per mysensor guide.
                              2. what debug value "sensorValue" you are seeing on serial console if you debug your sensor node.
                              3. check the debug log in pimatic
                              B 1 Reply Last reply
                              • D Dheeraj
                                B
                                B
                                BastienVH
                                @Dheeraj
                                I feel so stupid now... I built this circuit on a breadboard and after fiddling around with it yesterday, I forgot to place the resistor for the battery in the right pin. It was now on a different row.
                                Saw it and fixed it. Now I get a battery percentage in Pimatic!
                                Thanks for your help!
                                • karl261K karl261
                                  fetsF
                                  fetsF
                                  fets
                                  @karl261 Do you have any news ?
                                  Which raspberry pi are you using ? PI 2 ?
                                  I experienced the same issue with domoticz on raspberry pi2 + serial gateway with RFM69 radio.
                                  I really don't think that the issue is the controller. It seems that the radio is stuck cause when I debug my node after reset, all outgoing messages are marked with st=fail meaning that radios can't reach each other.
                                  I don't know if it's my chinese arduino nano or raspberry pi 2 usb power or my radio module.
                                  Investigation in progress. Something a reboot is not enough, I have to disconnect usb cable in order to make it work again.
                                  • karl261K
                                    karl261K
                                    karl261
                                    @fets Yes, indeed, I made some progress during the last weeks. Today I finally found a way to display these debug messages. Took me months. See this thread: http://forum.mysensors.org/topic/2392/how-to-properly-debug-serial-gateway-nrf24l01
                                    I think my serial gateway was somehow badly connected. During the past weeks I verified everything, re-soldered, tested various power supplies and radio modules, etc. Now it seems to work usually stable. But not always. Now I am playing around with increasing the sending power of the radio modules.
                                    I am using a pi 2.
                                    Interesting, your problem sounds very similar. Unfortunately I do not really have any advice. Maybe try to build a duplicate and see if this works better?
                                    • karl261K karl261
                                      I am using a pi 2.
                                      fetsF
                                      fetsF
                                      fets
                                      @karl261 My issue seems solve using capacitors on my rfm69 radios.
                                      • fahrettineF
                                        fahrettineF
                                        fahrettine
                                        Hi everyone,
                                        I installed Pimatic and it looks work just fine.
                                        In the Config menu I added the codes below.
                                        Saved and restarted the Pimatic.
                                        I see "Light Unknown%" on the frontpage.
                                        How can I fix that? Thanks....
                                          "plugin": "mysensors",
                                          "driver": "serialport",
                                          "protocols": "1.5.1",
                                          "startingNodeId": 1,
                                          "driverOptions": {
                                            "//": "'/dev/ttyUSB0' if using serial Gateway",
                                            "serialDevice": "/dev/ttyMySensorsGateway",
                                            "baudrate": 115200
                                        "devices": [
                                        "id": "Light",
                                        "name": "Light",
                                        "class": "MySensorsLight",
                                        "nodeid": 15,
                                        "batterySensor": false,
                                        "sensorid": 2
                                        SweebeeS 1 Reply Last reply
                                        • fahrettineF fahrettine
                                          Hi everyone,
                                            "driverOptions": {
                                              "baudrate": 115200
                                          "devices": [
                                          "id": "Light",
                                          "name": "Light",
                                          "nodeid": 15,
                                          "sensorid": 2
                                          SweebeeS
                                          SweebeeS
                                          Sweebee
                                          @fahrettine How does your sketch look? Does pimatic receive anything in de log?
