  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 75.4k Views 11 Watching
  • fahrettineF
    fahrettineF
    fahrettine
    Thanks for the answer.
    1-I installed Pimatic.
    2-I installed Serial Gateway on the Arduino Nano.
    3-I installed the Light sketch from MySensors on the Nano.
    Pimatic logs look like below. It seems it doesnt receive any signal.
    I think there is someting wrong with the USB port...
    Are my USB port settings coreect?
    You can see MySensors plugin settings above.
    2016-04-05 19:23:46info [pimatic]: Listening for HTTP-request on port 80...
    19:23:46info [pimatic-mobile-frontend]: rendering html finished
    19:23:20info [pimatic-mobile-frontend]: rendering html
    19:23:20info [pimatic-mobile-frontend]: packing static assets finished
    19:23:18info [pimatic-mobile-frontend]: packing static assets
    19:23:18info [pimatic]: New device "Light"...
    19:23:08info [pimatic-cron]: the time is: Tue Apr 05 2016 14:23:08 GMT-0200 (GMT+2)
    19:23:08info [pimatic]: Loading plugin: "pimatic-mysensors" (0.8.25)
    19:23:02info [pimatic]: Loading plugin: "pimatic-mobile-frontend" (0.8.82)
    19:22:59
    • OitzuO
      OitzuO
      Oitzu
      @fahrettine said:
         "plugin": "mysensors",
         "driver": "serialport",
         "protocols": "1.5.1",
         "startingNodeId": 1,
         "driverOptions": {
           "//": "'/dev/ttyUSB0' if using serial Gateway",
           "serialDevice": "/dev/ttyMySensorsGateway",
           "baudrate": 115200
      You may want to double check that config.
      It should be more like:
         "driverOptions": {
           "serialDevice": "/dev/ttyUSB0",
           "baudrate": 115200
      if, ttyUSB0 is your connected arduino nano.
      • fahrettineF
        fahrettineF
        fahrettine
        I plugged the controller and light sensor on my pc.
        The controller receives and the sensor transmits signals.
        So, the hardware is OK.
        I changed the USB setting as "serialDevice": "/dev/ttyUSB0"
        But still no signal.
        Because I am new on RPi I cant set the USB corectly.
        My USB settings (lsusb -t) are like below:
        What is my USB port? USB0 or USB1 or other else?
        pi@raspberrypi:~ $ lsusb -t
        /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
        |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
        |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
        |__ Port 2: Dev 4, If 0, Class=Wireless, Driver=btusb, 12M
        |__ Port 2: Dev 4, If 1, Class=Wireless, Driver=btusb, 12M
        |__ Port 3: Dev 5, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
        |__ Port 5: Dev 7, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
        • OitzuO
          OitzuO
          Oitzu
          dmesg | grep tty
          Will give you an output like:
          ch341-uart converter now attached to ttyUSBXX
          • fahrettineF
            fahrettineF
            fahrettine
            Oitzu thank you very much.
            I solved the problem.
            It was the nodeID. I set the nodeID to on the sketch to 15 and the problem solved.
            Thanks for your help...
            • fahrettineF
              fahrettineF
              fahrettine
              Hi everyone,
              I installed Pimatic. It works fine...
              I installed light sensor code from MySensor: http://www.mysensors.org/build/light
              Light sensor works fine...
              After that I intalled the Relay code: http://www.mysensors.org/build/relay
              The relay doesnt work!!! Any idea for the problem???
              When I turn the buton On/Off I can see the sending messages on debug.
              Thanks!!!
              Below are my Pimatic Config codes and debug messages:
                "id": "Switch",
                "name": "Switch",
                "class": "MySensorsSwitch",
                "nodeid": 10,
                "sensorid": 1
              debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;1
              21:21:09debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;0
              21:21:01debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;1
              21:20:56debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;0
              21:20:26info [pimatic]: Listening for HTTP-request on port 80...
              21:20:26info [pimatic-mobile-frontend]: rendering html finished
              D 1 Reply Last reply
              • fahrettineF fahrettine
                Hi everyone,
                Thanks!!!
                  "id": "Switch",
                  "name": "Switch",
                  "nodeid": 10,
                  "sensorid": 1
                D
                D
                Dheeraj
                @fahrettine said:
                check whether you received any message ( serialport output ) on relay sensor node.
                • rollercontainerR
                  rollercontainerR
                  rollercontainer
                  I've seen the "protocol" line. Is it suitable for 2.0.0beta sketches ?
                  SweebeeS 1 Reply Last reply
                  • rollercontainerR rollercontainer
                    SweebeeS
                    SweebeeS
                    Sweebee
                    @rollercontainer the plug-in works fine with 2.0. You dont have to change the protocol value in the plug-in.
                    • RedferneR
                      RedferneR
                      Redferne
                      Is there any development of this plugin?
                      • R
                        R
                        ricardot
                        @Dheeraj,
                        Do you plan to continue to develop this plugin? I will very pleased to see a mysensors button. Thank you!
                        • R ricardot
                          @Dheeraj,
                          D
                          D
                          DavidZH
                          @ricardot said in pimatic-mysensors controller plugin:
                          @Dheeraj,
                          I second this. And also see if we can lose the dependency on serialport 2.0.6 so that we can use Node.js > 4.9.1
