  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • NeverDieN NeverDie
    Are you guys running bCNC under Linux? Because installing it under Windows is proving to be challenging....
    andrewA
    andrewA
    andrew
    @neverdie yep, I've a linux vm for flatcam and bcnc.
      rmtuckerR
      rmtuckerR
      rmtucker
      @neverdie
      Linux for me too.Never used windows in years:relaxed:
      • NeverDieN
        NeverDieN
        #203
        Here's the machine oil I'm using. As you can tell from the manufacturer, it's meant for sewing machines and similar:
        • NeverDieN
          NeverDieN
          Well, now that I found this pulldown in Chilipeppr, I might stick with it a while longer:
          • NeverDieN
            NeverDieN
            #205
            The strange thing is that the Chilipeppr demo seems to mill at z=0.000. So, if I were to try to etch the pattern for real, I would have to "zero" z at an actual z value of, say, z=-0.5 or something (whatever depth I wanted it to etch at).
            Is that normal?
            Anyhow, I've been through multiple trial iterations with no bit installed and with the spindle disabled, and during all that the X and Y couplers have not come loose. So, I think that the Locktite has lived up to its name and solved the problem I was having earlier. :)
            andrewA 1 Reply Last reply
              Is that normal?
              andrewA
              andrewA
              andrew
              @neverdie said in CNC PCB milling:
              Is that normal?
              yes, the chilipeppr demo works like this. but keep in mind, that for "real" isolation milling, the milling depth which you used during the g code generation will be calculate from the relative z zero, so in that case you really have to set z0 to the pcb surface.
              • NeverDieN
                NeverDieN
                #207
                Disaster. Out of the blue, it suddenly just stopped working. Now I can't get it to spin the spindle or move in any x, y, or z direction. Gcode appears to be sent to it, and it does respond to me if I send it a '$" through the Chilipeppr console window. Just no movement whatsoever.
                I removed the heatsinks, as a possible culprit, but still no go.
                Suggestions on how to diagnose it?
                • NeverDieN
                  NeverDieN
                  #208
                  I found the problem: bad power supply brick. It is supplying no voltage at all. :(
                  The power brick that came as part of the kit says it is rated at 24v dc 5.62amp. Is that enough, or should I get something that can do more amps?
                  andrewA 2 Replies Last reply
                    andrewA
                    andrewA
                    andrew
                    @neverdie oh :( if you have a chance to power the cnc from a variable current power supply, then check the current it drains by starting from low to higher current. if it eats lot, maybe there is a short somewhere. you could also try to open the power supply and find a fuse.
                    good luck!
                      andrewA
                      andrewA
                      andrew
                      @neverdie I've a PS with the same parameters. it is enough.
                      • NeverDieN
                        NeverDieN
                        #211
                        I don't have much optimism that the cheap-ass power supply that came with the kit can be repaired (well, not by me anyway).
                        I ordered a 6amp one as a replacement, just to have a little more headroom:
                        https://www.amazon.com/gp/product/B01AJQ9G2C/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
                        It may turn out to be cheap-ass also, but I can get it tomorrow, so I'm rolling the dice.
                        If that burns out too, then there's this one, which looks more beefy and would be my first choice, but will take a week to receive it:
                        https://www.amazon.com/gp/product/B01J19G00E/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
                        • NeverDieN
                          NeverDieN
                          #212
                          Dang. I cancelled the order, as I'm not sure whether its 5.5mmx2.1mm barrel jack will fit or whether a 5.5mm x2.5mm is required.
                          Looks as though the barrel on the woodpeck is 2.5mm inside diameter....
                          • NeverDieN
                            NeverDieN
                            #213
                            Powering it from a variable power supply, it apparently works. Here's the etching on a piece of plywood:
                            I watched the current being drawn, and it appeared to always be below 1 amp. The variable power supply can supply up to 5 amps, so no problem there as far as I can see.
                            The etching that it did was a bit weird: deep cuts in the inside diameter of the P's, but only faint cuts just outside. The R was barely even touched at all. The surface doesn't feel sufficiently non-flat to account for that.
                            Ideas as to what's going wrong there?
                            • NeverDieN
                              NeverDieN
                              #214
                              Here is a contextual photo:
                              The clamps are holding the board very securely.
                              • NeverDieN
                                NeverDieN
                                After thinking about it, my hypothesis is that the feedrate is too high. I have it set to 1 in ChilliPeppr. I think maybe it comes down rapidly to the programmed height, but if it meets resistance then it skips some motor steps. Since it's open loop, it doesn't know. Then it dwells at that depth until it picks up the bit and relocates. I'll try a slower feedrate and see if it makes a difference.
                                • NeverDieN
                                  NeverDieN
                                  Maybe the bit is too dull as well. It's one of the freebies that came with the kit.
                                  • NeverDieN
                                    NeverDieN
                                    #217
                                    Also, what is the preferred way to tighten the ER11 chuck? So far, I did it just by hand, which seems to have been good enough. However, maybe a better practice is to give it a 1/4 turn further tightening using wrenches after that? How are others here approaching that?
                                    andrewA ben999B zboblamontZ 3 Replies Last reply
                                      andrewA
                                      andrewA
                                      andrew
                                      @neverdie for er11 fastening you should use two wrenches.
                                      if you loose steps during the milling, then with the given feed rate / depth / spindle speed combination the cnc / spindle / steppers are not powerful enough.
                                      if you wood milling depth is not constant then:
                                      • the wood is not flat
                                      • the cnc bad is not flat
                                      • the cnc x axis is not horizontal
                                      my availability for the next couple of days will be quite limited, so I wish you good luck for experiencing the router and for the first PCBs!
                                      NeverDieN 1 Reply Last reply
                                        ben999B
                                        ben999B
                                        ben999
                                        Also, what is the preferred way to tighten the ER11 chuck? So far, I did it just by hand, which seems to have been good enough. However, maybe a better way is to give it a 1/4 turn further tightening using wrenches after that? How are others here approaching that?
                                        +1 for the wrench, mostly because of vibrations that could unscrew it. No need to pull a muscle on it as it is tapered and has big contact surface
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @neverdie If it is anyway similar to a Router, it should have a locking pin to hold the spindle, or a second nut against which you tighten the collet. Do not overtighten, just enough to bite the shaft, otherwise you either damage the shaft or more seriously shatter the collet, it should be just enough to be a firm clamp to ensure grip, the collet will do the rest.
                                          Not a user of these CNCs but I would guess the same principles apply... Just my 2c...
