  3. CNC PCB milling
CNC PCB milling
934 Posts 29 Posters 848.6k Views 28 Watching
  • NeverDieN NeverDie
    I seem to be finished with the mechanical assembly:
    However, these washers came with the kit, and I'm not sure what they're for:
    Anyone know? Are they for mounting the woodpecker board to the frame?
    Next I need to do the firmware upgrade and then wire things up.
    rmtuckerR
    rmtuckerR
    rmtucker
    @neverdie
    You have gone quiet:relaxed:
    Must be beavering away cutting pcb's?
    NeverDieN 1 Reply Last reply
    • rmtuckerR
      rmtuckerR
      rmtucker
      Carved this on my home made cnc router recently.
      Bit off topic but good fun.
      It is about 2ft diameter and 8" thick(old millstone)
      rmtuckerR 1 Reply Last reply
      • rmtuckerR rmtucker
        rmtuckerR
        rmtuckerR
        rmtucker
        @rmtucker
        And this for our lass
          @neverdie
          NeverDieN
          NeverDieN
          @rmtucker said in CNC PCB milling:
          @neverdie
          No, I've simply misplaced my Dragon AVR programmer for the firmware upgrade, so I need to hunt it down.
          • NeverDieN
            NeverDieN
            #165
            Anyway, once I do get the firmware upgraded and it wired up, what's the best way to start testing it? Do I need to learn GRBL as execuval seems to imply, or are there some simple tests I can run? I imagine some kind of calibration would be the need step, but I haven't read that far ahead because there's nothing to read (well, haven't googled it out yet either).
            rmtuckerR E 2 Replies Last reply
              rmtuckerR
              rmtuckerR
              rmtucker
              @neverdie
              Stick some g-code in and press cycle start:grin:
              • zboblamontZ zboblamont
                @neverdie said in CNC PCB milling:
                ER11
                FYI - Was reading on another forum where the user was going to replace the ER11 with a larger version so he could use 8mm bits (fairly standard metric size for wood routing bits, but incredibly strong)...
                Somebody pointed out to the guy that there are collets available for the ER11 specifically for 8mm shafted toolbits...
                https://www.sorotec.de/shop/Spannzange-ER-11---8-00mm-DIN-6499B-4008E-Klasse-II.html
                NeverDieN
                NeverDieN
                #167
                @zboblamont said in CNC PCB milling:
                Given how it's installed, I don't see how you can get it off. I would assume it's permanent.
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  @neverdie From memory the guy got it off with a hub-puller, and a persuader, but the point I was trying to make was that there is a collet assembly for the ER11which takes 8mm...
                    E
                    E
                    executivul
                    First watch the video (now I can't get it out of my head :man-bowing: )
                    https://www.youtube.com/watch?v=UOk6echpeqQ
                    Then, after you update to grbl 0.9j go to chilipeppr.com/grbl, download the SPJS, start it and start playing.
                    • NeverDieN
                      NeverDieN
                      #170
                      I hope these heatsinks that came with the kit don't short things out. Seems rather dicey.
                      In any case, until I can find my Dragon, I'm going to limp along with GRBL 0.9j so I can finish up the build. I'll upgrade later after I find it.
                      andrewA 1 Reply Last reply
                        andrewA
                        andrewA
                        andrew
                        @neverdie the er-11 should be permanent. this spindle is not powerful enough to handle bigger tools and to mill harder materials.
                        you can start with grbl 0.9j, but it is worth to upgrade to 1.1f.
                        to the fw upgrade you can use a simple arduino as ISP programmer as well if you do not find your dragon.
                        with chilipeppr (in case of grbl 0.9j go for http://chilipeppr.com/grbl , for 1.1.f go for http://chilipeppr.com/jpadie) you can quickly run its default logo engraving path for testing / demo purposes.
                        • NeverDieN
                          NeverDieN
                          Done! Jack was certainly, uh, generous with the length of the wiring. I provisionally tacked it out of the way with the zip ties provided. I'll secure it better after I'm sure it's all working.
                            andrewA
                            andrewA
                            andrew
                            wrote on last edited by andrew
                            #173
                            @neverdie for the cable issue I ordered this cable organizer spiral, although not yet installed it :)
                            • andrewA andrew
                              NeverDieN
                              NeverDieN
                              #174
                              @andrew said in CNC PCB milling:
                              Thanks! That provided exactly what I was looking for. I ran the demo with no etching bit installed, and at first both X and Y seemed to be working, but the adapter coupling eventually loosened on both of them to the point where there was no longer X and Y movement. I've re-tightened tem, and it's working again. I hope it lasts.
                              Not sure where I should go next from here though.
                                andrewA
                                andrewA
                                andrew
                                #175
                                so, as this machine does not have limit switches installed, it is your responsibility to move the gantry to a position, from where you would like to start the job and which provides enough space for each direction movement. usually you have to set a relative zero at the given starting point.
                                what is next? did you adjusted the stepper drivers? if not, then do it (I shared the link above). this is necessary to be sure, that the steppers will be powered with enough current (so they will be powerful enough for the given speed related movement and to provide enough force) or will not be overdriven.
                                then, I would say try to engrave the chilipeppr logo to a soft material first, have some experience with the cnc.
                                then, as I mentioned, discover the flatcam tool and try to create an isolation routing job for a test pcb.
                                I already mentioned my confirmed settings for the given jobs (edge / hole milling, isolation routing).
                                you should sacrifice some boards for your experience :)
                                also, try to find your ideal g code sender tool by trying multiple ones.
                                • NeverDieN
                                  NeverDieN
                                  #176
                                  I don't see any plugs on the woodpecker board that are designated for connecting to a touch plate. So, I guess it's configured using the woodpecker header pins? How is that best set up?
                                  By the way, after re-tightening the set-screws on the adapters used to connect the step-motors to the screw rods, they seem to be holding now and not slipping loose. I take it back, one of them just came loose again. :(
                                  NeverDieN andrewA 2 Replies Last reply
                                    NeverDieN
                                    NeverDieN
                                    #177
                                    And now the other one did too. Is anyone using a threadlocker on the set screws to keep this from happening?
                                    I think I'll put on some locktite and let it dry overnight and then see if it still happens tomorrow. I'll start with just the threaded rods.
                                    Anyhow, the good news is that the heat sinks plainly did not short out the GRBL controller boards. I guess the adhesive must act as an electrical insulator.
                                    • NeverDieN
                                      NeverDieN
                                      #178
                                      Thinking about it now, an alternative might be to grind one side of the threaded rod flat in the region where it fits into the adapter. That would match the concept of the motor rotor, where that has already been done.
                                      Ideally I would notch it in just the region where the set screw makes contact. I suppose I could do that with a Dremel.
                                      Investigating now, I see that the adapter came loose on the motor rotor also. So, I think locktite will be a must.
                                      http://www.loctiteproducts.com/tds/T_LKR_BLUE_tds.pdf
                                      Looking at the datasheet, it takes 24 hours to cure.
                                      • NeverDieN
                                        NeverDieN
                                        Well, humbug! I'm all out. Maybe tomorrow I'll buy the red threadlocker, which is even stronger.
                                        dbemowskD 1 Reply Last reply
                                        • NeverDieN
                                          NeverDieN
                                          @rmtucker Which g-code sender is it that you like best?
