  3. Is ARM the future of MySensors?
31 Posts 12 Posters 9.9k Views 15 Watching
  • NeverDieN
    NeverDieN
    Don't your neighbors have better things to do?
    gohanG 1 Reply Last reply
    • NeverDieN NeverDie
      wrote on last edited by gohan
      #22
      @neverdie I was about to say the same... it must be a very boring town :D
      • G
        G
        ghiglie
        Well, last week I couldn't realize how my garage temp was so high.... I noticed my neighboor started autoproducing some sensors too... :D So it's time for signing/encryption.
        atmega328p serial killer
        HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
        • Nca78N Nca78
          @davidzh said in Is ARM the future of MySensors?:
          But in Urban areas with lots of high rises the 2.4GHz band is a bit congested.
          That's my case , there are 350 appartments in my building alone and my nrf24 network runs well, while my old 433MHz system regularly miss messages, that's why it will soon be replaced.
          D
          D
          dakipro
          @nca78 said in Is ARM the future of MySensors?:
          If nrf24 working on same/similar frequency as wifi, is it not being disturbed by other wifi networks? (I guess that in 350 apartments there are a minimum of 350 wifi networks).
          I never quite understood how exactly nrf24 and wifi go along.
          Nca78N gohanG YveauxY 3 Replies Last reply
          • D dakipro
            Nca78N
            Nca78N
            @dakipro said in Is ARM the future of MySensors?:
            It depends on the channels used by NRF24 and wifi networks, so far I've been lucky it seems :)
            Also, high rise is in fact probably helping by having thick concrete walls with lots of rebars inside, attenuating radio signals. I see many networks but most of them have week signal.
            • D dakipro
              @dakipro wifi only overlaps the nrf24 range for a number of channels, so usually if you choose channels at the margins of the spectrum you should be good
              • D dakipro
                YveauxY
                YveauxY
                The frequency band of nrf24 is wider than used by wifi. If you select a frequency just outside the wifi band it should help in reducing interference.
                D 1 Reply Last reply
                • skywatchS
                  skywatchS
                  skywatch
                  The current NRF24 set up is more secure than bluetooth or wifi from attack.
                  I say this based on the fact that anyone with a laptop, mobile etc can have software to crack/hack/spoof/inject into bluetooth or wifi. It is not that difficult for kids to do.
                  The NRF is another matter as to achieve this on that radio module would require acquiring a module, setting it up with a pc/phone and then getting software to attack it.
                  People often go the easiest route and I am less worried about nrf24 than I would be if the system used bluetooth/wifi or cloud.
                  Just my thoughts on a dark and wet Monday morning.....
                  • YveauxY Yveaux
                    D
                    D
                    dakipro
                    @yveaux said in Is ARM the future of MySensors?:
                    Thanks, that is what I thought. Btw, I am using default channel for mysensors (79 or whatnot), is that "just outside" enough?
                    I never had (connection) problems with mysensors, so I never researched fine-tuning options.
                    Can some android wifi analyzer help with the showing what is best to use, is there some guide available regarding nrf24? (should we write a guide? :) )
                    NeverDieN YveauxY 2 Replies Last reply
                    • D dakipro
                      NeverDieN
                      NeverDieN
                      #30
                      I don't believe so. Channel 123 is though. Easy to remember.
                      • D dakipro
                        YveauxY
                        YveauxY
                        @dakipro see here for a mapping of wifi and nrf24 channels: https://forum.mysensors.org/topic/4721/nrf-frequency-and-channels/5
                        NRF24 Channels 2..96 overlap with wifi. I personally would stay away from the high nrf24 channels (110+) as I've seen troublesome performance with clones.
                        Channel 100 performs well at my place.
