  3. Is ARM the future of MySensors?
31 Posts 12 Posters 9.7k Views 15 Watching
  • alowhumA
    alowhumA
    alowhum
    I've been testing the wonderful MY_SIGNING_SIMPLE_PASSWD feature on the 2.2 branch.
    So far most of my nodes that currently use an Arduino nano will not have enough memory to run things.
    So..
    Does this secretly imply that if you want to fully embrace MySensors 2.2 you'll need too switch to more powerful hardware, like STM32? or ESP8266? Or one of the other new IoT chips?
    What is the platform that most people are switching to?
    "just good enough" as a strategy
    I actually really like Arduino as a platform because it offers something the more powerful platforms don't: they are very hard to hack or take over. There simply isn't enough space left for malicious actors' code.
    For example, after reading about harddrives having persistent malware through ARM-based controller chips, I've become quite aware of this attack vector.If you follow Slashdot a bit you'll know that anything with a chip is a target nowadays.
    So, personally, whatever becomes the new "recommended platform", I hope it will stay 'cloudless' by default.
    Other discussions:
    https://forum.mysensors.org/topic/8852/best-hardware-for-gateway-with-encryption-and-signing/4
    mfalkviddM gohanG NeverDieN 3 Replies Last reply
    • alowhumA alowhum
      So..
      Other discussions:
      @alowhum to me, SAMD and nrf5 are most interesting for the future.
      The processing power is very seldom a bottleneck for home automation, but flash space and ram is a problem (as you've noticed). With nrf5 and samd we take a big step up: 16x ram and 8x flash compared to atmega328 (for SAMD21 and most nrf51 and even more for the larger versions).
      Nrf5 has a big benefit compared with samd: integrated radio. No risk for wiring mistakes, no need to order separate radio modules.
      But atmega328 will probably be around for a long time. They are very popular and easy to buy.
      • alowhumA alowhum
        So..
        Other discussions:
        @alowhum every news about malware needs to be put in the right context: malware programs can infect a target a low level system if they are made specifically for the purpose and in addition there must be a way to actually program the target, so if you have an arduino board that can be only programmed through serial port, I seriously doubt you will be a possible target for malware infection, otherwise if it was that easy we wouldn't struggle that much to have FOTA updates working.
        • alowhumA alowhum
          So..
          Other discussions:
          NeverDieN
          NeverDieN
          @alowhum said in Is ARM the future of MySensors?:
          I think an integrated MCU+radio, such as the nRF5, will be the inevitable winner for reasons of cost, size, capability, and efficiency. There may be cases, though, where you want to use a LoRa or other radio for superior range. It's not completely clear yet how well the nRF52840 will stack up in that department (since final silicon isn't yet available, and we can only speculate as to its pricing), but I'm guessing it will be capable enough for most home automation.
          That said, the atmega328p is just plain hard to beat as far as ultra low (~100na) sleep current goes, and it has the virtue of relative simplicity, so I think it will be around for quite a while yet.
          • nagelcN
            nagelcN
            nagelc
            I think the NRF5 with integrated radio will be the best solution for most home automation tasks as long as it has enough range to do a typical house without repeaters. But, I am fascinated by the "blue pill" stm32 boards -- very much like an Arduino Nano, but with modern ARM. It's a larger board, I don't know about battery operation yet, but for a powered sensor, it is easy to use, powerful, and cheap.
            Thanks to @NeverDie I also have a RA-01 LoRa module on a ESP8266 running as a gateway. So many amazing technologies . . ..
            It's hard to fault a ProMini with an NRF2 or RMF69. Those networks will probably always be reporting temperature and motion in my house. But I am always excited to think about the capabilities of these new technologies, particularly more memory. For me, it is a hobby and I can afford to try things just for fun and to learn about them, but even I must settle on a technology so I can get back to making interesting sensors and actuators.
            I keep looking for HopeRF to come out with an ARM-RFM combo to compete with NRF5, but they do not seem to be going that direction. Right now, I would bet on NRF5 as the best technology going forward.
            • D
              D
              DavidZH
              I certainly can see the appeal for the NRF5 series, which wil work perfect in areas with detached and terraced houses. But in Urban areas with lots of high rises the 2.4GHz band is a bit congested. So there another band will work much better.
              In that regard I fully agree with @nagelc to pray to your deity of choice for HopeRF to start integrating an MCU with the RFM, or Nordic to start exploring a different part of the ether.
              I have not set foot in the 'large' part of the MCU spectrum, but I have a Feather M0 in the house which will be the center of my new experiments.
              NeverDieN Nca78N 2 Replies Last reply
              • D DavidZH
                NeverDieN
                NeverDieN
                @davidzh said in Is ARM the future of MySensors?:
                Even doing that doesn't give you all the benefits that tighter integration onto one chip gives you. For instance, on the nRF5:
                1. You don't communicate over SPI. Instead, the radio can share pointers directly to memory using easyDMA. Much faster, which translates also to lower power consumption.
                2. You can manage the radio and do other tasks (albeit in a limited way) while the MCU sleeps using the Programmable peripheral interconnect (PPI). This is maybe something that's hard to appreciate until you've tried it, but I'm sold on it and would sorely miss it if forced to return to a non-integrated MCU and radio, even if they were co-located together on the same module.
                • D DavidZH
                  Nca78N
                  Nca78N
                  That's my case , there are 350 appartments in my building alone and my nrf24 network runs well, while my old 433MHz system regularly miss messages, that's why it will soon be replaced.
                  NeverDieN D 2 Replies Last reply
                  • Nca78N Nca78
                    NeverDieN
                    NeverDieN
                    @nca78 said in Is ARM the future of MySensors?:
                    LoRa isn't as much affected by interference since it's spread spectrum.
                    • alowhumA
                      alowhumA
                      alowhum
                      So is anyone thinking they will use the encryption features on a normal Arduino? Or is it, as I was thinking, that if you want to use encryption you'll have to upgrade?
                      AnticimexA 1 Reply Last reply
                        Simple encryption runs fine since it is mainly done by the radio chip
                        • alowhumA alowhum
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @alowhum if you only enable encryption (not signing) you can fit more into an atmga328p. Also, if you use a rfm69 radio, encryption is hw backed, so it require less flash space (thus potentially allow you to also fit signing).
                          Furthermore, using a atsha204a means signing also take less of flash since some of the algorithms are hw backed.
                          • NeverDieN
                            NeverDieN
                            Well, regarding the OP, I think I read somewhere that development would largely move to ARM, and that at some point it would stop on the atmega. Not sure that I'm recalling it correctly though. Is it true?
                            • alowhumA
                              alowhumA
                              alowhum
                              @anticimex: interesting.
                              This is my use case: all I want is that I put a password at the top of all my arduino files, and then my neighbours won't be able to receive my data because they don't have the password. That's encryption, right? At the moment anyone can pick up the values that my sensors are sending out into the city. And that's kinda creepy.
                              gohanG AnticimexA 3 Replies Last reply
                              • alowhumA alowhum
                                @alowhum I bet there are hundreds of people interested in your house temperature :sweat_smile:
                                Btw, yes that is encryption
                                alowhumA 1 Reply Last reply
                                • alowhumA alowhum
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @alowhum the simple password option is the simplest way of enabling security. At the same time it is the most expensive as it does not require personalization and therefore is pure software based (except for rfm69 encryption). So you need to trade simplicity for code size.
                                  That said, once you have figured out personalization (and there is plenty documentation on the matter) it can easily be repeated, as long as you keep the sketch used to program the personalization data.
                                  • alowhumA alowhum
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @alowhum also, the simple password option enable both signing and encryption so it takes up a lot of memory. If encryption is the only thing you want, just personalize the devices with an AES key and enable encryption only. It is not that good (fixed iv) and easily crackable by someone who has an idea about AES but it at least obfuscate your messages fairly well. Combined with signing it is better, but, again, that costs memory.
                                    • AnticimexA Anticimex
                                      alowhumA
                                      alowhumA
                                      alowhum
                                      @anticimex Hmm, I didn't realise that. Could it be an idea to create a MY_ENCRYPTION_SIMPLE_PASSWD feature as well, without the signing? Would that fit the "opportunistic curious neighbour" scenario?
                                      • alowhumA alowhum
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @alowhum give personalization a shot. Since you use the simple flag, you are already on the development branch, so you have a simplified personalization flow. It is documented in doxygen (see the pinned signing post for a link)
                                          alowhumA
                                          alowhumA
                                          alowhum
                                          @gohan said in Is ARM the future of MySensors?:
                                          Actually, just my temperature would already indicate
                                          • Whether I am home or not. "He'll never know we took the jewelry".
                                          • if I go on holidays a lot. "How is he paying for all that".
                                          • Whether I am feeling ill (set it a bit higher). "Got a fever last week? Or did your grandma visit"?
                                          • If I am environmentally conscious. Something I don't want to talk about at the neighbourhood BBQ..
                                          • Etc.
                                          Now add to that my other sensors.
                                          Now add to that all the actuators (yikes!).
