  3. New RFM69 driver error
19 Posts 4 Posters 4.6k Views 5 Watching
  • firstof9F
    firstof9F
    firstof9
    While attempting to compile for an Uno using a W5100 Ethernet gateway setup I get the following error(s):
    Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
    In file included from D:\Documents\Arduino\libraries\MySensors/MySensors.h:343:0,
                     from D:\OneDrive\Home Automation Project\GatewayW5100.ino\GatewayW5100.ino.ino:120:
    D:\Documents\Arduino\libraries\MySensors/drivers/RFM69/new/RFM69_new.cpp: In function 'void RFM69_prepareSPITransaction()':
    D:\Documents\Arduino\libraries\MySensors/drivers/RFM69/new/RFM69_new.cpp:73:2: error: '_SREG' was not declared in this scope
      _SREG = SREG;
    D:\Documents\Arduino\libraries\MySensors/drivers/RFM69/new/RFM69_new.cpp:78:2: error: '_SPCR' was not declared in this scope
      _SPCR = SPCR;
    D:\Documents\Arduino\libraries\MySensors/drivers/RFM69/new/RFM69_new.cpp:79:2: error: '_SPSR' was not declared in this scope
      _SPSR = SPSR;
    D:\Documents\Arduino\libraries\MySensors/drivers/RFM69/new/RFM69_new.cpp: In function 'void RFM69_concludeSPITransaction()':
    D:\Documents\Arduino\libraries\MySensors/drivers/RFM69/new/RFM69_new.cpp:99:9: error: '_SPCR' was not declared in this scope
      SPCR = _SPCR;
    D:\Documents\Arduino\libraries\MySensors/drivers/RFM69/new/RFM69_new.cpp:100:9: error: '_SPSR' was not declared in this scope
      SPSR = _SPSR;
    D:\Documents\Arduino\libraries\MySensors/drivers/RFM69/new/RFM69_new.cpp:104:9: error: '_SREG' was not declared in this scope
      SREG = _SREG;
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    option enabled in File -> Preferences.
    Anyone have any ideas what's going on?
    Thanks in advance.
      Never seen that error. Did you try to compile for a different arduino? Are you using mysensors 2.2?
      • firstof9F
        firstof9F
        firstof9
        @gohan said in New RFM69 driver error:
        It seems to work fine for the Adafruit Feather Wings when selected.
        The error only comes up when I switch the board to the Uno for the ethernet gateway.
        Yes
          What arduino ide version do you have? What Arduino Boards Definitions are you using? Did you try compiling for pro mini?
          firstof9F 1 Reply Last reply
          • scalzS
            scalzS
            wrote on last edited by scalz
            hmm, I think there is maybe a little bug.
            I don't remember how exactly works uno/nano ethernet gw in softspi mode. When I tested it, I used hw spi for both.
            Just to be sure, have you modified the gw sketch? (it's good habit, for helping, to post the problematic sketch so we can check defines).
            If that's the case, that
            • you haven't modified the gw sketch
            • and followed connection here https://www.mysensors.org/build/ethernet_gateway
            could you try to change two lines in the following file:
            • path is your Mydocuments\Arduino\libraries\Mysensors\drivers\rfm69\new\RFM69_new.cpp
            It's quick&dirty (not digged for a cleaner solution), but you just need to hack 2lines, for a simple test.
            Line 46, change:
            #if defined (SREG) && !defined(SPI_HAS_TRANSACTION)
            by
            #if defined (SREG)	&& (!defined(SPI_HAS_TRANSACTION) || defined(MY_SOFTSPI))
            And finally, line 50, change:
            #if defined (SPCR) && defined (SPSR) && !defined(SPI_HAS_TRANSACTION)
            by
            #if defined (SPCR) && defined (SPSR) && (!defined(SPI_HAS_TRANSACTION) || defined(MY_SOFTSPI))
            This should compile, I have no idea if it will run ok as I have no time to prepare a test setup for the moment.
            Please tell if it's ok or not. I hope this will help
              firstof9F
              firstof9F
              firstof9
              @gohan
              Arduino: 1.8.5
              Arduino AVR Boards 1.6.20 (for my Uno with W5100 Ethernet shield)
              Adafruit AVR Boards 1.4.12 (for the Feather boards 32u4)
              No as i don't have or use Pro Minis
              It does compile for my Nano sensor just fine.
              So far the error's only occurred when trying to compile for the Uno.
              • scalzS
                scalzS
                I think it happens because of the softspi define, in the w5100 ethernet gw sketch.
                could you try my test above please ?
                • scalzS scalz
                  firstof9F
                  firstof9F
                  firstof9
                  @scalz
                  Your modifications seemed to have resolved the issue.
                  Also I've made this modification to MyTransport.cpp so it resets the radio on init:
                  void stInitTransition(void)
                  	#if defined(ADAFRUIT_RFM69)
                  	pinMode(9, OUTPUT);
                  	digitalWrite(9, HIGH);
                  	delay(100);
                  	digitalWrite(9, LOW);
                  	delay(100);
                  	TRANSPORT_DEBUG(PSTR("TSM:INIT\n"));
                  Sketch for reference:
                  // Enable Adafruit RFM69 breakout fix
                  #define ADAFRUIT_RFM69
                  #define MY_RADIO_RFM69
                  #define MY_RFM69_NEW_DRIVER // ATC on RFM69 works only with the new driver
                  #define MY_RFM69_ATC_TARGET_RSSI_DBM (-70)  // target RSSI -70dBm
                  #define MY_RFM69_MAX_POWER_LEVEL_DBM (10) // amx. TX power 10dBm = 10mW
                  #define MY_IS_RFM69HW  // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
                  #define MY_RF69_FREQUENCY RFM69_915MHZ  // Define for frequency setting. Needed if you're radio module isn't 868Mhz (868Mhz is default in lib)
                  #define MY_RF69_SPI_CS 4
                  #define MY_RF69_IRQ_PIN 2
                  //#define MY_RF69_IRQ_NUM 0
                  //#define W5100SPIPATCH
                  #define SKETCH_NAME "MySensors Ethernet Gateway"
                  #define SKETCH_MAJOR "0"
                  #define SKETCH_MINOR "5"
                  #define MY_GATEWAY_W5100
                  // radio on the same spi bus.
                    #define MY_SOFTSPI
                    #define MY_SOFT_SPI_MISO_PIN 15
                    #define MY_SOFT_SPI_MOSI_PIN 16
                  // Enable to UDP
                  //#define MY_USE_UDP
                  #define MY_IP_ADDRESS 192,168,1,204   // If this is disabled, DHCP is used to retrieve address
                  #define MY_PORT 5003
                  //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
                  // Enable inclusion mode
                  // Set blinking period
                  // Flash leds on rx/tx/err
                  //#define MY_DEFAULT_ERR_LED_PIN 5  // Error led pin
                  #define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
                  //#define MY_DEFAULT_TX_LED_PIN  7  // Transmit led pin
                  #if defined(MY_USE_UDP)
                  #include <EthernetUdp.h>
                  #include <Ethernet.h>
                    sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR"."SKETCH_MINOR);
                  • scalzS
                    scalzS
                    @firstof9
                    reset is already implemented in rf69 driver (see here https://github.com/mysensors/MySensors/blob/master/drivers/RFM69/new/RFM69_new.cpp#L196 )
                    in your sketch you just need to define it like this
                    #define MY_RFM69_RST_PIN  your_reset_pin
                    https://www.mysensors.org/apidocs/group__RFM69SettingGrpPub.html#ga0837813278d8622eb317a3bac22963e7
                    firstof9F 2 Replies Last reply
                    • scalzS scalz
                      @firstof9
                      firstof9F
                      firstof9F
                      firstof9
                      @scalz
                      I've updated my sketch to include that for the new driver. Thank you.
                      I had to use that mod for the older driver.
                      scalzS 1 Reply Last reply
                      • scalzS scalz
                        @firstof9
                        firstof9F
                        firstof9F
                        firstof9
                        wrote on last edited by firstof9
                        @scalz Trying to update all my nodes to the new driver, getting this on the gateway now:
                        0 MCO:BGN:INIT GW,CP=RPNGA---,VER=2.2.0
                        3 TSM:INIT
                        4 TSF:WUR:MS=0
                        5 RFM69:INIT
                        11 RFM69:INIT:PIN,CS=4,IQP=2,IQN=0,RST=9
                        116 RFM69:PTX:LEVEL=5 dBm
                        118 !RFM69:INIT:SANCHK FAIL
                        120 !TSM:INIT:TSP FAIL
                        122 TSM:FAIL:CNT=1
                        124 TSM:FAIL:DIS
                        126 TSF:TDI:TSL
                        128 RFM69:RSL
                        Same sketch as previously posted (with RFM69 verbose defined for more info). Any ideas?
                        firstof9F N 2 Replies Last reply
                        • firstof9F firstof9
                          3 TSM:INIT
                          4 TSF:WUR:MS=0
                          5 RFM69:INIT
                          122 TSM:FAIL:CNT=1
                          124 TSM:FAIL:DIS
                          126 TSF:TDI:TSL
                          128 RFM69:RSL
                          firstof9F
                          firstof9F
                          firstof9
                          Jumped the gun on a "fixed" post :(
                            3 TSM:INIT
                            4 TSF:WUR:MS=0
                            5 RFM69:INIT
                            122 TSM:FAIL:CNT=1
                            124 TSM:FAIL:DIS
                            126 TSF:TDI:TSL
                            128 RFM69:RSL
                            N
                            N
                            Nightbodom
                            I have the same error as @firstof9. I have tried all the combinations of arduino (uno, nano) and rfm69, rfm69hw and node, gw sketch and nodemanager... but always got this SANCHK FAIL error...
                            I solder all rfm69s to nrf2rfm69 converter by @tbowmo
                            • N Nightbodom
                              scalzS
                              scalzS
                              @nightbodom
                              If i understand it well, i think firstof9 issue is solved.
                              Regarding yours, please post more infos else we can't help much.. : hw used, sketch so we can check your defines&code, logs..
                              Note: it is not recommanded (explained in mysensors docs) to use rfm69 which is not 5V tolerant (3.6v max), with uno/nano which are 5v signal levels boards (SPI is running 5v). For this you would need level shifting board.
                              Maybe your modules are not dead because of these tests but better be careful.
                              To be sure, about your modules&sketch, you could try with arduino mini pro 3v/8mhz boards.
                              SANCHK FAIL means you need to check wiring or change module
                              N firstof9F 2 Replies Last reply
                              • scalzS scalz
                                @nightbodom
                                N
                                N
                                Nightbodom
                                @scalz thanks for advice... I connect modules like sheme on mysensors and watch only for Vcc to be 3V. I try with NodeMCU for gateway and pro mini for node and modules are OK. I use NodeManager for sketches.
                                But I have another problem. If I use on both (GW and node) rfm69 the range of connection is about 10 -15m trough the wall. So I try to extend range with use of rfm69hw. If I use both hw modules there is no connection even nodes are one by another. If I use one ordinary and one hw module, the range is max. about 1m.
                                Node is connected through FDTI and NodeMCU is on USB.
                                node log:
                                ,ft=0,st=OK:4294967270
                                0 MCO:BGN:INIT NODE,CP=RPNNA---,VER=2.2.0
                                43 MCO:BGN:BFR
                                NodeManager v1.7
                                LIB V=2.2.0 R=P E=- T=N A=A S=- B=-
                                BATTERY I=201 P=30 T=38
                                SIGNAL I=202 P=33 T=37
                                RADIO...108 TSM:INIT
                                188 TSF:WUR:MS=0
                                206 RFM69:INIT
                                223 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                262 RFM69:PTX:LEVEL=5 dBm
                                288 TSM:INIT:TSP OK
                                311 TSM:INIT:STATID=101
                                335 TSF:SID:OK,ID=101
                                358 TSM:FPAR
                                372 RFM69:SWR:SEND,TO=255,RETRY=0
                                411 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                1572 RFM69:SAC:SEND ACK,TO=0,RSSI=-31
                                1615 TSF:MSG:READ,0-0-101,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                1675 TSF:MSG:FPAR OK,ID=0,D=1
                                2490 TSM:FPAR:OK
                                2506 TSM:ID
                                2521 TSM:ID:OK
                                2535 TSM:UPL
                                2549 RFM69:SWR:SEND,TO=0,RETRY=0
                                2633 RFM69:SWR:ACK,FROM=0,SEQ=3,RSSI=-73
                                2676 RFM69:ATC:ADJ TXL,cR=-73,tR=-80,TXL=4
                                2721 RFM69:PTX:LEVEL=4 dBm
                                2750 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                2824 RFM69:SAC:SEND ACK,TO=0,RSSI=-31
                                2867 TSF:MSG:READ,0-0-101,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                2926 TSF:MSG:PONG RECV,HP=1
                                2957 TSM:UPL:OK
                                2973 TSM:READY:ID=101,PAR=0,DIS=1
                                3010 RFM69:SWR:SEND,TO=0,RETRY=0
                                3092 RFM69:SWR:ACK,FROM=0,SEQ=5,RSSI=-72
                                3135 RFM69:ATC:ADJ TXL,cR=-72,tR=-80,TXL=3
                                3180 RFM69:PTX:LEVEL=3 dBm
                                3209 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                3289 RFM69:SAC:SEND ACK,TO=0,RSSI=-31
                                3330 TSF:MSG:READ,0-0-101,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                3393 RFM69:SWR:SEND,TO=0,RETRY=0
                                3497 RFM69:SWR:ACK,FROM=0,SEQ=7,RSSI=-74
                                3540 RFM69:ATC:ADJ TXL,cR=-74,tR=-80,TXL=2
                                3586 RFM69:PTX:LEVEL=2 dBm
                                3614 TSF:MSG:SEND,101-101-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
                                3694 RFM69:SWR:SEND,TO=0,RETRY=0
                                3778 RFM69:SWR:ACK,FROM=0,SEQ=8,RSSI=-73
                                3821 RFM69:ATC:ADJ TXL,cR=-73,tR=-80,TXL=1
                                3866 RFM69:PTX:LEVEL=1 dBm
                                3895 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                OK
                                5969 RFM69:SWR:SEND,TO=0,RETRY=0
                                6057 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-72
                                6100 RFM69:ATC:ADJ TXL,cR=-72,tR=-80,TXL=0
                                6146 RFM69:PTX:LEVEL=0 dBm
                                6174 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=11,pt=0,l=17,sg=0,ft=0,st=OK:NodeManagerSENSOR
                                6268 RFM69:SWR:SEND,TO=0,RETRY=0
                                6350 RFM69:SWR:ACK,FROM=0,SEQ=10,RSSI=-73
                                6395 RFM69:ATC:ADJ TXL,cR=-73,tR=-80,TXL=-1
                                6440 RFM69:PTX:LEVEL=-1 dBm
                                6471 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                PRES I=201 T=30 D=BATTERY
                                6549 RFM69:SWR:SEND,TO=0,RETRY=0
                                6660 RFM69:SWR:ACK,FROM=0,SEQ=11,RSSI=-72
                                6705 RFM69:ATC:ADJ TXL,cR=-72,tR=-80,TXL=-2
                                6750 RFM69:PTX:LEVEL=-2 dBm
                                6780 TSF:MSG:SEND,101-101-0-0,s=201,c=0,t=30,pt=0,l=7,sg=0,ft=0,st=OK:BATTERY
                                PRES I=202 T=33 D=SIGNAL
                                6862 RFM69:SWR:SEND,TO=0,RETRY=0
                                6973 RFM69:SWR:ACK,FROM=0,SEQ=12,RSSI=-73
                                7016 TSF:MSG:SEND,101-101-0-0,s=202,c=0,t=33,pt=0,l=6,sg=0,ft=0,st=OK:SIGNAL
                                READY
                                7096 MCO:REG:REQ
                                7124 RFM69:SWR:SEND,TO=0,RETRY=0
                                7206 RFM69:SWR:ACK,FROM=0,SEQ=13,RSSI=-72
                                7251 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                7327 RFM69:SAC:SEND ACK,TO=0,RSSI=-30
                                7368 TSF:MSG:READ,0-0-101,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                7430 MCO:PIM:NODE REG=1
                                7454 MCO:BGN:STP
                                MY I=101 M=1
                                INT P=3 M=255
                                INT P=2 M=255
                                7475 MCO:BGN:INIT OK,TSP=1
                                BATTERY V=3.26 %=94
                                7616 RFM69:SWR:SEND,TO=0,RETRY=0
                                7720 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-73
                                7763 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:94
                                SEND D=0 I=201 C=0 T=38 S= I=0 F=3.26
                                7841 RFM69:SWR:SEND,TO=0,RETRY=0
                                7964 RFM69:SWR:ACK,FROM=0,SEQ=16,RSSI=-71
                                8007 TSF:MSG:SEND,101-101-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.26
                                SIGNAL V=-26
                                SEND D=0 I=202 C=0 T=37 S= I=0 F=0.00
                                8089 RFM69:SWR:SEND,TO=0,RETRY=0
                                8224 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-74
                                8269 TSF:MSG:SEND,101-101-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967270
                                SIGNAL V=-26
                                13357 RFM69:SWR:SEND,TO=0,RETRY=0
                                13494 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-70
                                13541 TSF:MSG:SEND,101-101-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967270
                                SIGNAL V=-26
                                18628 RFM69:SWR:SEND,TO=0,RETRY=0
                                18765 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-71
                                18812 TSF:MSG:SEND,101-101-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967270
                                SIGNAL V=-26
                                23898 RFM69:SWR:SEND,TO=0,RETRY=0
                                24035 RFM69:SWR:ACK,FROM=0,SEQ=20,RSSI=-69
                                24082 TSF:MSG:SEND,101-101-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967270
                                SIGNAL V=-26
                                29169 RFM69:SWR:SEND,TO=0,RETRY=0
                                29462 !RFM69:SWR:NACK
                                29485 RFM69:PTX:LEVEL=-1 dBm
                                29523 RFM69:SWR:SEND,TO=0,RETRY=1
                                29763 !RFM69:SWR:NACK
                                29786 RFM69:PTX:LEVEL=0 dBm
                                29855 RFM69:SWR:SEND,TO=0,RETRY=2
                                30095 !RFM69:SWR:NACK
                                30117 RFM69:PTX:LEVEL=1 dBm
                                30146 RFM69:SWR:SEND,TO=0,RETRY=3
                                30388 !RFM69:SWR:NACK
                                30410 RFM69:PTX:LEVEL=2 dBm
                                30480 RFM69:SWR:SEND,TO=0,RETRY=4
                                30720 !RFM69:SWR:NACK
                                30742 RFM69:PTX:LEVEL=3 dBm
                                30803 RFM69:SWR:SEND,TO=0,RETRY=5
                                31043 !RFM69:SWR:NACK
                                31066 RFM69:PTX:LEVEL=4 dBm
                                31135 !TSF:MSG:SEND,101-101-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=NACK:4294967270
                                SIGNAL V=-26
                                36227 RFM69:SWR:SEND,TO=0,RETRY=0
                                36519 !RFM69:SWR:NACK
                                36542 RFM69:PTX:LEVEL=5 dBm
                                36579 RFM69:SWR:SEND,TO=0,RETRY=1
                                36818 !RFM69:SWR:NACK
                                36841 RFM69:PTX:LEVEL=6 dBm
                                36878 RFM69:SWR:SEND,TO=0,RETRY=2
                                37117 !RFM69:SWR:NACK
                                37140 RFM69:PTX:LEVEL=7 dBm
                                37201 RFM69:SWR:SEND,TO=0,RETRY=3
                                37441 !RFM69:SWR:NACK
                                37464 RFM69:PTX:LEVEL=8 dBm
                                37533 RFM69:SWR:SEND,TO=0,RETRY=4
                                37773 !RFM69:SWR:NACK
                                37795 RFM69:PTX:LEVEL=9 dBm
                                37824 RFM69:SWR:SEND,TO=0,RETRY=5
                                38066 !RFM69:SWR:NACK
                                38088 RFM69:PTX:LEVEL=10 dBm
                                38160 !TSF:MSG:SEND,101-101-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=1,st=NACK:4294967270
                                SIGNAL V=-26
                                43251 RFM69:SWR:SEND,TO=0,RETRY=0
                                43544 !RFM69:SWR:NACK
                                43567 RFM69:PTX:LEVEL=11 dBm
                                43606 RFM69:SWR:SEND,TO=0,RETRY=1
                                43845 !RFM69:SWR:NACK
                                43868 RFM69:PTX:LEVEL=12 dBm
                                43939 RFM69:SWR:SEND,TO=0,RETRY=2
                                44179 !RFM69:SWR:NACK
                                44201 RFM69:PTX:LEVEL=13 dBm
                                44240 RFM69:SWR:SEND,TO=0,RETRY=3
                                44480 !RFM69:SWR:NACK
                                44503 RFM69:PTX:LEVEL=14 dBm
                                44566 RFM69:SWR:SEND,TO=0,RETRY=4
                                44806 !RFM69:SWR:NACK
                                44828 RFM69:PTX:LEVEL=15 dBm
                                44900 RFM69:SWR:SEND,TO=0,RETRY=5
                                45139 !RFM69:SWR:NACK
                                45162 RFM69:PTX:LEVEL=16 dBm
                                45201 !TSF:MSG:SEND,101-101-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=2,st=NACK:4294967270
                                SIGNAL V=-26
                                50292 RFM69:SWR:SEND,TO=0,RETRY=0
                                50585 !RFM69:SWR:NACK
                                50608 RFM69:PTX:LEVEL=17 dBm
                                50638 RFM69:SWR:SEND,TO=0,RETRY=1
                                50878 !RFM69:SWR:NACK
                                50900 RFM69:PTX:LEVEL=18 dBm
                                50964 RFM69:SWR:SEND,TO=0,RETRY=2
                                51204 !RFM69:SWR:NACK
                                51226 RFM69:PTX:LEVEL=19 dBm
                                51298 RFM69:SWR:SEND,TO=0,RETRY=3
                                51537 !RFM69:SWR:NACK
                                51560 RFM69:PTX:LEVEL=20 dBm
                                51599 RFM69:SWR:SEND,TO=0,RETRY=4
                                51838 !RFM69:SWR:NACK
                                51861 RFM69:PTX:NO ADJ
                                51918 RFM69:SWR:SEND,TO=0,RETRY=5
                                52158 !RFM69:SWR:NACK
                                52180 RFM69:PTX:NO ADJ
                                52238 !TSF:MSG:SEND,101-101-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=3,st=NACK:4294967270
                                SIGNAL V=-26
                                57329 RFM69:SWR:SEND,TO=0,RETRY=0
                                57622 !RFM69:SWR:NACK
                                57645 RFM69:PTX:NO ADJ
                                57677 RFM69:SWR:SEND,TO=0,RETRY=1
                                57917 !RFM69:SWR:NACK
                                57939 RFM69:PTX:NO ADJ
                                57997 RFM69:SWR:SEND,TO=0,RETRY=2
                                58236 !RFM69:SWR:NACK
                                58259 RFM69:PTX:NO ADJ
                                58316 RFM69:SWR:SEND,TO=0,RETRY=3
                                58556 !RFM69:SWR:NACK
                                58578 RFM69:PTX:NO ADJ
                                58636 RFM69:SWR:SEND,TO=0,RETRY=4
                                58875 !RFM69:SWR:NACK
                                58898 RFM69:PTX:NO ADJ
                                58955 RFM69:SWR:SEND,TO=0,RETRY=5
                                59195 !RFM69:SWR:NACK
                                59217 RFM69:PTX:NO ADJ
                                59275 !TSF:MSG:SEND,101-101-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=4,st=NACK:4294967270
                                BATTERY V=3.26 %=94
                                60071 RFM69:SWR:SEND,TO=0,RETRY=0
                                60332 !RFM69:SWR:NACK
                                60354 RFM69:PTX:NO ADJ
                                60411 RFM69:SWR:SEND,TO=0,RETRY=1
                                60651 !RFM69:SWR:NACK
                                60674 RFM69:PTX:NO ADJ
                                60731 RFM69:SWR:SEND,TO=0,RETRY=2
                                60971 !RFM69:SWR:NACK
                                60993 RFM69:PTX:NO ADJ
                                61050 RFM69:SWR:SEND,TO=0,RETRY=3
                                61290 !RFM69:SWR:NACK
                                61313 RFM69:PTX:NO ADJ
                                61370 RFM69:SWR:SEND,TO=0,RETRY=4
                                61609 !RFM69:SWR:NACK
                                61632 RFM69:PTX:NO ADJ
                                61689 RFM69:SWR:SEND,TO=0,RETRY=5
                                61929 !RFM69:SWR:NACK
                                61952 RFM69:PTX:NO ADJ
                                62009 !TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=5,st=NACK:94
                                62089 RFM69:SWR:SEND,TO=0,RETRY=0
                                62369 !RFM69:SWR:NACK
                                62392 RFM69:PTX:NO ADJ
                                62425 RFM69:SWR:SEND,TO=0,RETRY=1
                                62664 !RFM69:SWR:NACK
                                62687 RFM69:PTX:NO ADJ
                                62711 RFM69:SWR:SEND,TO=0,RETRY=2
                                62951 !RFM69:SWR:NACK
                                62973 RFM69:PTX:NO ADJ
                                63006 RFM69:SWR:SEND,TO=0,RETRY=3
                                63246 !RFM69:SWR:NACK
                                63268 RFM69:PTX:NO ADJ
                                63293 RFM69:SWR:SEND,TO=0,RETRY=4
                                63533 !RFM69:SWR:NACK
                                63555 RFM69:PTX:NO ADJ
                                63612 RFM69:SWR:SEND,TO=0,RETRY=5
                                63852 !RFM69:SWR:NACK
                                63875 RFM69:PTX:NO ADJ
                                63932 !TSF:MSG:SEND,101-101-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=6,st=NACK:3.26
                                64014 !TSM:READY:UPL FAIL,SNP
                                64045 TSM:FPAR
                                64061 RFM69:SWR:SEND,TO=255,RETRY=0
                                64104 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=7,st=OK:
                                SIGNAL V=-26
                                64366 !TSF:SND:TNR
                                66183 !TSM:FPAR:NO REPLY
                                66209 TSM:FPAR
                                66224 RFM69:SWR:SEND,TO=255,RETRY=0
                                66267 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                68345 !TSM:FPAR:NO REPLY
                                68370 TSM:FPAR
                                68386 RFM69:SWR:SEND,TO=255,RETRY=0
                                68429 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                SIGNAL V=-26
                                69441 !TSF:SND:TNR
                                70508 !TSM:FPAR:NO REPLY
                                70533 TSM:FPAR
                                70549 RFM69:SWR:SEND,TO=255,RETRY=0
                                70592 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                72671 !TSM:FPAR:FAIL
                                72691 TSM:FAIL:CNT=1
                                72714 TSM:FAIL:DIS
                                72734 TSF:TDI:TSL
                                72755 RFM69:RSL
                                SIGNAL V=-26
                                74516 !TSF:SND:TNR
                                SIGNAL V=-26
                                79591 !TSF:SND:TNR
                                82774 TSM:FAIL:RE-INIT
                                82798 TSM:INIT
                                82812 RFM69:INIT
                                82831 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                82874 RFM69:PTX:LEVEL=5 dBm
                                82903 TSM:INIT:TSP OK
                                82927 TSM:INIT:STATID=101
                                82954 TSF:SID:OK,ID=101
                                82980 TSM:FPAR
                                82995 RFM69:SWR:SEND,TO=255,RETRY=0
                                83038 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                SIGNAL V=-26
                                84666 !TSF:SND:TNR
                                85118 !TSM:FPAR:NO REPLY
                                85143 TSM:FPAR
                                85159 RFM69:SWR:SEND,TO=255,RETRY=0
                                85202 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                87281 !TSM:FPAR:NO REPLY
                                87306 TSM:FPAR
                                87322 RFM69:SWR:SEND,TO=255,RETRY=0
                                87365 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                89444 !TSM:FPAR:NO REPLY
                                89468 TSM:FPAR
                                89485 RFM69:SWR:SEND,TO=255,RETRY=0
                                89536 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                SIGNAL V=-26
                                89741 !TSF:SND:TNR
                                91615 !TSM:FPAR:FAIL
                                91637 TSM:FAIL:CNT=2
                                91658 TSM:FAIL:DIS
                                91678 TSF:TDI:TSL
                                91699 RFM69:RSL
                                SIGNAL V=-26
                                94814 !TSF:SND:TNR
                                SIGNAL V=-26
                                99887 !TSF:SND:TNR
                                On 29000 I move gateway far away on another side of laptop..
                                An here is GW log:
                                62 MCO:BGN:INIT GW,CP=RPNGE---,VER=2.2.0
                                105 MCO:BGN:BFR
                                NodeManager v1.7
                                LIB V=2.2.0 R=P E=- T=G A=E S=- B=-
                                RADIO...122 TSF:LRT:OK
                                228 TSM:INIT
                                242 TSF:WUR:MS=0
                                260 RFM69:INIT
                                276 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                315 RFM69:PTX:LEVEL=5 dBm
                                342 TSM:INIT:TSP OK
                                363 TSM:INIT:GW MODE
                                385 TSM:READY:ID=0,PAR=0,DIS=0
                                418 MCO:REG:NOT NEEDED
                                944 GWT:TIN:CONNECTING...
                                971 GWT:TIN:IP=192.168.1.30
                                1001 MCO:BGN:STP
                                MY I=0 M=255
                                INT P=3 M=255
                                INT P=2 M=255
                                1019 MCO:BGN:INIT OK,TSP=1
                                SIGNAL V=0
                                1571 TSF:MSG:READ,101-101-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                1632 TSF:MSG:BC
                                1649 TSF:MSG:FPAR REQ,ID=101
                                1679 TSF:CKU:OK,FCTRL
                                1702 TSF:MSG:GWL OK
                                2422 RFM69:SWR:SEND,TO=101,RETRY=0
                                2662 !RFM69:SWR:NACK
                                2692 RFM69:SWR:SEND,TO=101,RETRY=1
                                2774 RFM69:SWR:ACK,FROM=101,SEQ=1,RSSI=-31
                                2819 TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                3747 RFM69:SAC:SEND ACK,TO=101,RSSI=-73
                                3791 TSF:MSG:READ,101-101-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                3853 TSF:MSG:PINGED,ID=101,HP=1
                                3891 RFM69:SWR:SEND,TO=101,RETRY=0
                                4026 RFM69:SWR:ACK,FROM=101,SEQ=3,RSSI=-31
                                4071 TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                4206 RFM69:SAC:SEND ACK,TO=101,RSSI=-72
                                4251 TSF:MSG:READ,101-101-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                4316 RFM69:SWR:SEND,TO=101,RETRY=0
                                4489 RFM69:SWR:ACK,FROM=101,SEQ=5,RSSI=-31
                                4534 TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                4612 RFM69:SAC:SEND ACK,TO=101,RSSI=-74
                                4656 TSF:MSG:READ,101-101-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.2.0
                                RECV S=101 I=255 C=0 T=17 P=2.2.0
                                4891 RFM69:SAC:SEND ACK,TO=101,RSSI=-73
                                4936 TSF:MSG:READ,101-101-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                RECV S=101 I=255 C=3 T=6 P=
                                7172 RFM69:SAC:SEND ACK,TO=101,RSSI=-72
                                7216 TSF:MSG:READ,101-101-0,s=255,c=3,t=11,pt=0,l=17,sg=0:NodeManagerSENSOR
                                RECV S=101 I=255 C=3 T=11 P=NodeManagerSENSOR
                                7465 RFM69:SAC:SEND ACK,TO=101,RSSI=-73
                                7509 TSF:MSG:READ,101-101-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                RECV S=101 I=255 C=3 T=12 P=1.0
                                7774 RFM69:SAC:SEND ACK,TO=101,RSSI=-72
                                7818 TSF:MSG:READ,101-101-0,s=201,c=0,t=30,pt=0,l=7,sg=0:BATTERY
                                RECV S=101 I=201 C=0 T=30 P=BATTERY
                                8086 RFM69:SAC:SEND ACK,TO=101,RSSI=-73
                                8130 TSF:MSG:READ,101-101-0,s=202,c=0,t=33,pt=0,l=6,sg=0:SIGNAL
                                RECV S=101 I=202 C=0 T=33 P=SIGNAL
                                8321 RFM69:SAC:SEND ACK,TO=101,RSSI=-72
                                8365 TSF:MSG:READ,101-101-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                8432 RFM69:SWR:SEND,TO=101,RETRY=0
                                8528 RFM69:SWR:ACK,FROM=101,SEQ=13,RSSI=-30
                                8574 TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                8834 RFM69:SAC:SEND ACK,TO=101,RSSI=-73
                                8878 TSF:MSG:READ,101-101-0,s=255,c=3,t=0,pt=1,l=1,sg=0:94
                                RECV S=101 I=255 C=3 T=0 P=
                                9077 RFM69:SAC:SEND ACK,TO=101,RSSI=-71
                                9122 TSF:MSG:READ,101-101-0,s=201,c=1,t=38,pt=7,l=5,sg=0:3.26
                                RECV S=101 I=201 C=1 T=38 P=
                                9339 RFM69:SAC:SEND ACK,TO=101,RSSI=-74
                                9383 TSF:MSG:READ,101-101-0,s=202,c=1,t=37,pt=5,l=4,sg=0:4294967270
                                RECV S=101 I=202 C=1 T=37 P=
                                14607 RFM69:SAC:SEND ACK,TO=101,RSSI=-70
                                14653 TSF:MSG:READ,101-101-0,s=202,c=1,t=37,pt=5,l=4,sg=0:4294967270
                                19878 RFM69:SAC:SEND ACK,TO=101,RSSI=-71
                                19924 TSF:MSG:READ,101-101-0,s=202,c=1,t=37,pt=5,l=4,sg=0:4294967270
                                25148 RFM69:SAC:SEND ACK,TO=101,RSSI=-69
                                25193 TSF:MSG:READ,101-101-0,s=202,c=1,t=37,pt=5,l=4,sg=0:4294967270
                                SIGNAL V=-69
                                SIGNAL V=-69
                                SIGNAL V=-69
                                SIGNAL V=-69
                                SIGNAL V=-69
                                For node I use :
                                // RFM69 radio settings
                                //#define MY_RFM69_FREQUENCY RFM69_868MHZ
                                //#define MY_RFM69_ENABLE_ENCRYPTION
                                //#define MY_RFM69_NETWORKID 100
                                //#define MY_RF69_IRQ_PIN 2
                                //#define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
                                //#define MY_RF69_SPI_CS 10
                                //#define MY_RFM69_ATC_MODE_DISABLED
                                And for GW same as this except without MY_IS_RFM69HW.
                                Any sugestions?
                                • scalzS
                                  scalzS
                                  @Nightbodom
                                  It could also be
                                  • bad antennas: what's your antenna ? in case of "wire" antenna, what kind of wire do you use? It needs to be one solid core, 86mm for 868mhz.
                                  • power supply too. maybe not enough beefy ftdi on your node, when you increase distance and need more power to transmit.
                                  you could eliminate power supply point, by replacing it with 2xaa battery, or any other batt as long as you keep your vcc 3.3. it would provide a more clean power supply
                                  Maybe you could upload a pic of your gw and node assembly, in case we see something.
                                  If everything is ok, then i'll recheck hw&sw here, but i can't tell you when for the moment.
                                  • scalzS scalz
                                    @nightbodom
                                    firstof9F
                                    firstof9F
                                    firstof9
                                    @scalz Negitive my issue persists using the new driver. I've had to revert back to the old driver to get around this SANCHK FAIL. Same wiring same radios using older driver work perfectly fine.
                                    I read some where that the issue is resolved in beta version of 2.2.1.
                                      @scalz
                                      scalzS
                                      scalzS
                                      @firstof9 said in New RFM69 driver error:
                                      @scalz
                                      Why did you say this 4months ago? Does it mean you got it working with new driver at a moment?
                                      Then 3months later, you said you got hw sanity check error. What has changed?
                                      Maybe, have you updated lib and get again your initial problem??
                                      On other side, (if i get things right), nightbodom has no more sanity chech error but range issue now..
                                      Inconsistent details with hard to follow debug :crystal_ball: , unfortunately no time actually. I'll take a look later.
                                      • scalzS scalz
                                        @scalz
                                        firstof9F
                                        firstof9F
                                        firstof9
                                        @scalz Sorry, your changes fixed my OP problem with the compile errors. I forgot to follow up noting the TSP INIT fails and switching back to the old driver :(
