  3. NOT WORKING: DHT and RELAYS on Ethernet GW
20 Posts 3 Posters 4.2k Views 3 Watching
  • Z
    Z
    ZachFlem
    Hi Folks!
    I've recieved my DHT11/22s and finally resolved an issue I was having with an ethernet shield (replaced the DOA unit with another new one) and I sat down to have a play and try and get one of the DHTs working on my current relay gateway/node and I ran into a loop of "Failed reading temperature from DHT!" but I can't work out what it is I'm doing wrong.
    I have the DHT working on it's own, or I have the relays working on their own, but not both at the same time.
    It doesn't seem to be a pin conflict or anything there, it may be power related though as I was trying to use the 3.3v pint o power the DHT and the 5v pin to power the relays.
    I need to invest (read: pull apart a phone charger) in a better 5v power supply for my gateway.
    If you fine people could cast an eye over my sketch and suggest any changes, maybe where I've gone wrong, or even a more elegant way of doing the same thing, I'd be greatly appreciative.
    note: for some reason i couldn't paste with code tags, so I've dumped it at pastebin:
    https://pastebin.com/HQpPKdeF
    Cheers in advance!
    gohanG 1 Reply Last reply
    • rejoe2R
      rejoe2R
      rejoe2
      Not sure, if this is really the cause of your troubles, bit imo it's not the best way to measure the DHT values every time when loop() is gone through. Doing so, the arduino most of the time is just waiting for the DHT to finish measurement.
      I'd recommend to use a non-blocking-loop() function - you may use the https://www.mysensors.org/build/pulse_water example to build your own code or search the arduino website for non-blocking loop.
      • Z ZachFlem
        Hi Folks!
        Cheers in advance!
        @zachflem I'd put a
        wait(300000)
        at the end of loop so the sensor only sends data every 5 minutes while the rest of the GW functions keep working
        rejoe2R Z 2 Replies Last reply
          @zachflem I'd put a
          wait(300000)
          rejoe2R
          rejoe2R
          rejoe2
          @gohan The reason behind proposing to use a non-blocking loop() was as follows: The former gw.process()-function has been pushed in the background so it is no longer visible directly in the sketches. But nevertheless I thought, for GW's and repeaters it still is highly recommended to go through the loop() as often as possible to avoid any delays in the processing of ingoing messages.
          The proposal to just use wait() is not really compatible with this understanding of the internal machanics of MySensors. Did I get something wrong?
            "Wait" will keep the rest of the GW functions running, it is not like "delay" that blocks the code execution
            rejoe2R 1 Reply Last reply
              @zachflem I'd put a
              wait(300000)
              Z
              Z
              ZachFlem
              @gohan would the 5 minute wait() affect the rest of the loop? as in, if I add the wait, will it delay the activation of relays etc
                It does affect the loop of course, but since you are only running the DHT code it shouldn't be an issue. Give it a try, it is not a complicated change :)
                  rejoe2R
                  rejoe2R
                  rejoe2
                  @gohan said in NOT WORKING: DHT and RELAYS on Ethernet GW:
                  Thx for clarification :+1:
                  • Z
                    Z
                    ZachFlem
                    OK folks, so I've got it going to some extent.
                    Added the wait(), and that seems to have calmed things down a bit, but I also added an external 5v power supply to the sensor and relay board
                    The relays are working, and the temp and humidity are being reported on the serial monitor, but there is no value coming back to MyController from the DHT22.
                    Sketch @ https://pastebin.com/mMxh65xp
                    As always, your help is appreciated.
                    Cheers
                      Is the gateway actually sending the temperature? Do you see it in the logs?
                      Z 1 Reply Last reply
                        Z
                        Z
                        ZachFlem
                        @gohan nope, just checked, and I can see the presentation, and my manual trigger of the relays, but no data back from the sensor.
                        I'm also only getting the humidity presented to MyController
                          DHT sensors are quite lazy so they need their time, try adding a wait(1000) before the
                          • rejoe2R
                            rejoe2R
                            rejoe2
                            @zachflem said in NOT WORKING: DHT and RELAYS on Ethernet GW:
                            This also indicates some trouble in the communication between GW and Controller. For debugging, you may also add some wait()-time in between the presentation of the individual child-ID's.
                            • Z
                              Z
                              ZachFlem
                              So I've moved inside (it was bloody hot in the shed) and I'm working on my development board (it's a mirror of the setup in the shed, minus the external power supply for the sensors)
                              But with the shed sketch loaded into this MEGA, I'm getting the DHT values in the Serial Monitor, I'll hook it up proper to the network and see how we go.
                                As a personal suggestion, I'd start looking at better sensors like the I2C ones (SHT31, SHT21, Si7021, BME280, etc)
                                  Z
                                  Z
                                  ZachFlem
                                  So far I've done this, and I have a value coming from the GW for humidity, and I'm seeing a presentation for the temp sensor in the logs, but nothing comes up when I discover the GW...
                                    What kind of gateway are you running?
                                      Z
                                      Z
                                      ZachFlem
                                      An arduino mega clone with a w5100 based ethernet shield.
                                      I think I might have found the problem, the humidity sensor reports as ID 0, the 2 relays as 1 and 2, and the temp sensor is showing up as 1, but before the relay.
                                      So I think i need to add something to the sketch so that each type of sensor has a different prefix.
                                      i.e. relays are 1XX, temp are 2XX etc
                                      any thoughts?
                                      • Z ZachFlem
                                        any thoughts?
                                        rejoe2R
                                        rejoe2R
                                        rejoe2
                                        any thoughts?
                                        Not sure about if that's still valid, but there had been the recommendation to use ChildID 1 for the first relay. So you may use 3+4 for temp/hum or start with 10, 20 (or whatever you like) as proposed to have room for further relays or other type of switches.
                                        • rejoe2R rejoe2
                                          any thoughts?
                                          Z
                                          Z
                                          ZachFlem
                                          @rejoe2 said in NOT WORKING: DHT and RELAYS on Ethernet GW:
                                          any thoughts?
                                          Yeah, just re-read it and found the hard define for the IDs of those, and set them to 100 and 101.
                                          Now I have the 2 relays defined as 1 & 2 and the Humidity as 100 and Temp as 101.
                                          Can see all 4 sensors but only getting a value from the temp sensor.
