  3. Magnetic light switch and 2 DHT 11
4 Posts 2 Posters 1.2k Views 2 Watching
  • FedynF
    FedynF
    Fedyn
    Hi..
    I been using this forum allot to create my MySensors nods and GW's and so on..
    Now to my problem. I have small food storage room like a "pantry" there no lights in it so now I want to make a MySensors thing to light a 12v LED Strip true a relay thats connected to the mains "230v". The relay is controlled by a magnetic switch, by the door magnet. This part I have figured.. Now for the DHT part i have tried my best but no luck.
    Is there some one that could take a luck att my sketch?
    #define MY_TRANSPORT_WAIT_READY_MS 3000     //set how long to wait for transport ready. in milliseconds
    #include <Bounce2.h>
    #include <DHT.h>
    #define RELAY_PIN  3      // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  4     // Arduino Digital I/O pin number for button
    #define CHILD_ID 1        // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define DHT_DATA_PIN 7
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool state;
    MyMessage msg(CHILD_ID, V_STATUS);
    pinMode(BUTTON_PIN, INPUT);              // Setup the button pin
    digitalWrite(BUTTON_PIN, HIGH);           // Activate internal pull-up
    debouncer.attach(BUTTON_PIN);
    debouncer.interval(5);
    pinMode(RELAY_PIN, OUTPUT);               // set relay pin in output mode
    digitalWrite(RELAY_PIN, RELAY_OFF);      // Make sure relay is off when starting up
    void presentation()  {
    sendSketchInfo("Relay & Button & Temp+Hum", "1.1");
    present(CHILD_ID_HUM, S_HUM);
    present(CHILD_ID, S_BINARY);
    debouncer.update();
      int value = debouncer.read();                               // Get the update value
      if (value != oldValue) {                      // check for new button push
      state =  !state;                                          // Toggle the state
      send(msg.set(state), false);                               // send new state to      controller, no ack requested
      digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);    // switch the relay to the new state
    oldValue = value;
    dht.readSensor(true);
    if (isnan(temperature)) {
    lastTemp = temperature;
    if (!metric) {
    // Reset no updates counter
    nNoUpdatesTemp = 0;
    #ifdef MY_DEBUG
    Serial.print("T: ");
    Serial.println(temperature);
    } else {
    nNoUpdatesTemp++;
    if (isnan(humidity)) {
    lastHum = humidity;
    nNoUpdatesHum = 0;
    #ifdef MY_DEBUG
    Serial.print("H: ");
    Serial.println(humidity);
    } else {
    nNoUpdatesHum++;
    sleep(UPDATE_INTERVAL);
    /*-------------------start of functions--------------------------*/
    if (message.type == V_STATUS) {                               // check to see if incoming message is for a switch
    state = message.getBool();                                  // get the current state
    digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);      // switch relay to current state
    // Write some debug info
    Serial.print(message.sensor);
    rejoe2R 1 Reply Last reply
    • FedynF Fedyn
      Hi..
      #include <DHT.h>
      #define RELAY_ON 1
      #define RELAY_OFF 0
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      int oldValue = 0;
      bool state;
      debouncer.update();
      oldValue = value;
      if (!metric) {
      nNoUpdatesTemp = 0;
      #ifdef MY_DEBUG
      } else {
      nNoUpdatesTemp++;
      lastHum = humidity;
      nNoUpdatesHum = 0;
      #ifdef MY_DEBUG
      } else {
      nNoUpdatesHum++;
      rejoe2R
      rejoe2R
      rejoe2
      @fedyn First remark: as working at 230V mains is dangerous you may think about leaving the 230V always on and use the 12V also to power the arduino and switch the LED on using a MOSFET (relay may also be ok).
      Wrt to your sketch, imo you should not combine sleep() with a debouncer-design for your switch. The debounced PIN (your button) then will not be read while sleeping.
      You may either have to use a non-blocking-loop() (example how to do this: see the https://www.mysensors.org/build/pulse_water - sketch) or use PIN 2 or 3 for an interrupt-based solution (following the https://www.mysensors.org/build/motion - example).
      FedynF 1 Reply Last reply
      • rejoe2R rejoe2
        FedynF
        FedynF
        Fedyn
        @rejoe2 Thx.
        And Thx for the advise.
        Have tried now but no luck.
        • FedynF Fedyn
          @rejoe2 Thx.
          rejoe2R
          rejoe2R
          rejoe2
          @fedyn Thx for reporting back. Just in case you expect anyone to help you further with this, it is necessary to post updated code together with more info what is "not working" (here: the switch/lightning part or the DHT).
          You may also find some more hints in how to combine relay and non-blocking loop() starting here: https://forum.mysensors.org/post/81401
          Btw.: you mentionned 2 DHT in the title of your post, but in the code, there's only one.
