  3. 💬 EASY PIR multisensors box
mysensorsrfm69temperaturepirbh1750longlifelightdc-dcsi7021
23 Posts 10 Posters 8.3k Views 9 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/564/EASY-PIR-multisensors-box
    • O
      O
      Omemanti
      It looks amazing,,!
      • MiKaM
        MiKaM
        MiKa
        please add also "Hall efect" sensor
          Mathea90
          Looks very nice. How satisfied are you with the PIR sensor in your design? I only have experience with BISS0001 based PIR sensors but I don't like the large amount of components (resistors and capacitors) I have to fit on my PCB design to make them work.
          • Nca78N
            Nca78N
            May I ask where you got the PIR sensors from ? I asked Senba for some samples, they say it's free for a few units but ask for 28$ for DHL shipping, with the custom processing fee I'll inevitably get from DHL it gets really expensive just to test the sensor.
            O 1 Reply Last reply
            • Nca78N Nca78
              O
              O
              Omemanti
              @Koresh Why did you choose this PIR sensor?
              I'm experimenting with an AM612 and works well for as far as I can tellen (is THT though).
              Do you know if there is a difference in performance compared to the "standard" PIR sensors you get on eBay for 1 dollar?
              • KoreshK
                KoreshK
                Koresh
                @omemanti AM312 and S16-L201D have almost the same performance, I think. But I must to use SMD pir on this board to have ablilty to place double batteries holder on the bottom. I have strict mechanical limitations in this device :)
                • KoreshK
                  KoreshK
                  Koresh
                  @omemanti said in 💬 EASY PIR multisensors box:
                  Do you mean PIR based on the BISS0001? It drains ~100uA, so you must to use large batteries.
                  • Nca78N
                    Nca78N
                    @Koresh I think you missed my previous message :)
                    Where did you get your PIR sensors ?
                    KoreshK 1 Reply Last reply
                    • KoreshK Koresh
                      O
                      O
                      Omemanti
                      wrote on last edited by Omemanti
                      @koresh https://www.openhardware.io/view/420/AM612-Passive-Infrared-Sensor-Breakout-Board
                      But they all are THT so if you need smd 😀 it's a nono
                      • Nca78N Nca78
                        KoreshK
                        KoreshK
                        Koresh
                        @nca78 I bought these sensors for prototype boards in the local store ( http://www.pcmount.by/catalog/radiokomponenty/mikroshemy/ic-pir-s16-l201d )
                        Nca78N 1 Reply Last reply
                        • KoreshK
                          KoreshK
                          Koresh
                          I applied a little improvement for the first small batch. Now we have two leds to show events ;)
                          NRF version:
                          RFM version:
                          • KoreshK Koresh
                            Nca78N
                            Nca78N
                            @koresh said in 💬 EASY PIR multisensors box:
                            For information for all those who like me are a bit far from this "local" store. I made a procurement request on LCSC.com for 10 sensors (S16-L221D-2) and they charge me a bit less than 1$ for each, so with Singapore Post shipping it's less than 14$, 1.4$ per sensor.
                            Senba was ok to send me some samples for free but I had to pay 20$ for DHL shipping, so this is much more interesting :)
                            • scalzS
                              scalzS
                              wrote on last edited by scalz
                              and here an eval board that you can find in others shops too.
                              For those who don't want to solder it ;)
                              https://www.seeedstudio.com/Grove-mini-PIR-motion-sensor-p-2930.html
                              gohanG 1 Reply Last reply
                              • NeverDieN
                                NeverDieN
                                Interesting. Its small size is an attractive feature.
                                I'd be curious to know though how well it detects compared to the am612 and it's larger PIR lens. IIRC, the small lens on the am312 didn't do so well....
                                • scalzS scalz
                                  @scalz wow 5$ each? 😱
                                  • scalzS
                                    scalzS
                                    @NeverDie
                                    I can't tell you about this PIR ic. I'm not using it.
                                    I don't think they're all equal. Shops selling these eval boards mention short range with this lens type. But it can be due to the PIR&lens.
                                    I prefer TO5 PIR for multiple reason (but it's less handy when mecha constraints). One of them is you have more choice for lens and focal. I'm not sure if using a bigger lens with a smd PIR like this one, wouldn't break the recommanded focal, and thus degrade fov or range..
                                    @gohan I just showed a seeed link, i'm not advicing anything ;) But, 5$, a lot.. really?? Here I'm not spending 5bucks for PIR ic, a bit less. But you would use 10 modules for a house, that would be 50 bucks.. personally I'm not shocked, it's price for some commercial devices. I know xia**i have cheap hw, but are their PIR devices more than just PIR..
                                    Of course i can understand 5$ can be a lot, depends where you live then.
                                      wrote on last edited by gohan
                                      Nca78 is buying the bare sensor for 1$ as a end user, so to me 4$ for a pcb and a connector is overpriced
                                      Xiaomi PIR sensors are zigbee devices, so you shoud compare them to a normal pro mini pir sensor with nrf24 and an etra light sensor.
                                      scalzS NeverDieN 2 Replies Last reply
                                        scalzS
                                        scalzS
                                        @gohan said in 💬 EASY PIR multisensors box:
                                        calc is wrong :) Nca is buying it for 1.4$, the unsoldered bare sensor only..
                                        then for 4$ you get the lens, a few components+connector, pcb, soldered/assembled.. maybe you'll find for cheaper in aliexpress in future. "Overpriced" like you said, perhaps.. but not that much I think. People need to do benefits, run their company etc to live.. Plus, for example seeed has degressive price with quantity.
                                        Just that sometimes, I feel nowadays people would like things for almost free. Poor people workers assembling stuff for peanuts, not cool, or locals decentralizing.. but I don't want to debate on this.
                                        Sorry for OT @koresh, cute board btw, nice work :+1:
                                        • Nca78N
                                          Nca78N
                                          I think they buy it for cheaper than my 10 parts at 0.95$. But except for that I agree with @scalz : they paid some guy to watch the market for new sensors, order this one and test it, another one to design a PCB, test/solder some prototypes and test again, take some photographs of the final product, make the online form & PDF documentation, get it produced and stocked.
                                          Not huge sums but I don't think they will sell x0 000 units like the cheap ass breakout boards on AliExpress/Ebay, so they have to get back the investment and make a decent margin, too.
