  3. Home Assistant
  4. New Light is not shown in HASS
3 Posts 2 Posters 1.4k Views 2 Watching
  • Richard van der PlasR
    wrote on last edited by Richard van der Plas
    after uploading the code to a 5th node of the same code, the node is not seen in HASS,
    Debug log shows the first set section of the code is working:
    Mar 24 16:59:22 raspberrypi mysgw: GWT:RFC:C=1,MSG=14;255;3;0;6;M
    Mar 24 16:59:22 raspberrypi mysgw: TSF:MSG:SEND,0-0-14-14,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
    Mar 24 16:59:22 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=255,c=3,t=11,pt=0,l=8,sg=0:TuinLamp
    Mar 24 16:59:22 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.5
    Mar 24 16:59:23 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=1,c=0,t=27,pt=0,l=0,sg=0:
    Mar 24 16:59:24 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=2,c=0,t=4,pt=0,l=0,sg=0:
    Mar 24 16:59:26 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=3,c=0,t=3,pt=0,l=0,sg=0:
    Mar 24 16:59:28 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    Mar 24 16:59:28 raspberrypi mysgw: TSF:MSG:SEND,0-0-14-14,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    Mar 24 16:59:29 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=3,c=1,t=2,pt=2,l=2,sg=0:0
    Mar 24 16:59:30 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=2,c=1,t=2,pt=2,l=2,sg=0:0
    Mar 24 16:59:30 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=2,c=1,t=3,pt=2,l=2,sg=0:0
    Mar 24 16:59:30 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=1,c=1,t=41,pt=0,l=8,sg=0:00000000
    Mar 24 16:59:30 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
    Mar 24 16:59:30 raspberrypi mysgw: TSF:MSG:READ,14-14-0,s=1,c=1,t=3,pt=2,l=2,sg=0:0
    Home assistant log shows:
    Mar 24 17:07:22 raspberrypi hass[449]: #033[33m2018-03-24 17:07:22 WARNING (Thread-23) [mysensors] child_id 1 already exists in children of node 14, cannot add child#033[0m
    Mar 24 17:07:23 raspberrypi hass[449]: #033[33m2018-03-24 17:07:23 WARNING (Thread-23) [mysensors] child_id 2 already exists in children of node 14, cannot add child#033[0m
    Mar 24 17:07:24 raspberrypi hass[449]: #033[33m2018-03-24 17:07:24 WARNING (Thread-23) [mysensors] child_id 3 already exists in children of node 14, cannot add child#033[0m
    Mar 24 17:09:03 raspberrypi hass[449]: Exception in thread Thread-23:
    Mar 24 17:09:03 raspberrypi hass[449]: Traceback (most recent call last):
    Mar 24 17:09:03 raspberrypi hass[449]:   File "/usr/lib/python3.5/threading.py", line 914, in _bootstrap_inner
    Mar 24 17:09:03 raspberrypi hass[449]:     self.run()
    Mar 24 17:09:03 raspberrypi hass[449]:   File "/srv/homeassistant/lib/python3.5/site-packages/mysensors/gateway_tcp.py", line 180, in run
    Mar 24 17:09:03 raspberrypi hass[449]:     response = self.handle_queue()
    Mar 24 17:09:03 raspberrypi hass[449]:   File "/srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py", line 374, in handle_queue
    Mar 24 17:09:03 raspberrypi hass[449]:     reply = func(*args, **kwargs)
    Mar 24 17:09:03 raspberrypi hass[449]:   File "/srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py", line 202, in logic
    Mar 24 17:09:03 raspberrypi hass[449]:     ret = self._handle_set(msg)
    Mar 24 17:09:03 raspberrypi hass[449]:   File "/srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py", line 101, in _handle_set
    Mar 24 17:09:03 raspberrypi hass[449]:     msg.child_id, msg.sub_type, msg.payload)
    Mar 24 17:09:03 raspberrypi hass[449]:   File "/srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py", line 519, in set_child_value
    Mar 24 17:09:03 raspberrypi hass[449]:     msg.validate(self.protocol_version)
    Mar 24 17:09:03 raspberrypi hass[449]:   File "/srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py", line 634, in validate
    Mar 24 17:09:03 raspberrypi hass[449]:     const = get_const(protocol_version)
    Mar 24 17:09:03 raspberrypi hass[449]:   File "/srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py", line 32, in get_const
    Mar 24 17:09:03 raspberrypi hass[449]:     if parse_ver('1.5') <= parse_ver(version) < parse_ver('2.0'):
    Mar 24 17:09:03 raspberrypi hass[449]:   File "/usr/lib/python3.5/distutils/version.py", line 52, in __lt__
    Mar 24 17:09:03 raspberrypi hass[449]:     c = self._cmp(other)
    Mar 24 17:09:03 raspberrypi hass[449]:   File "/usr/lib/python3.5/distutils/version.py", line 337, in _cmp
    Mar 24 17:09:03 raspberrypi hass[449]:     if self.version < other.version:
    Mar 24 17:09:03 raspberrypi hass[449]: TypeError: unorderable types: str() < int()
    and the mysensors.json file has node 14 in its list, but HASS wont show it in the states list or the made groups.yaml ?
    the other nodes didn't have that issue.
      issue seems the version number, which in 2.2 is a text string (Major releas bladiebla) that messes with the json file somehow
      • martinhjelmareM
        martinhjelmareM
        martinhjelmare
        Please post your json persistence file.
