  3. Serial Gateway not working after Raspberry Pi upgrade
6 Posts 2 Posters 1.8k Views 1 Watching
  • C
    C
    CraigDubya
    wrote on last edited by CraigDubya
    I recently upgraded my raspberry pi with sudo apt-get upgrade.
    It must have overwritten config files because my serial gateway has stopped working.
    It's been a long time since I got it working, and I think the problem lies with specifying the usb port it is plugged in to.
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    I have tried:
    sudo ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
    and:
    sudo ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB0
    but it is still failing.
    Can anyone suggest anything that I am missing?
    I am using an Arduino Nano with nrf24 connected to raspberry pi via USB.
    • C
      C
      CraigDubya
      I have installed Arduino IDE on the raspberry pi, and opened a terminal window.
      I can see that the arduino nano is receiving messages from my sensor nodes, so it is definately my raspberry pi configuration.
      • C
        C
        CraigDubya
        Can anyone help?
        • C CraigDubya
          Can anyone help?
          @craigdubya the rapberry pi gateway is not for usb-connected Arduinos. The raspberry pi gateway is used when the nrf24 module is wired directly to the gpio pins on the raspberry pi, without using an Arduino.
          With your setup, you don't need the raspberry pi gateway. Just configure your controller to use the usb device that represents your Arduino Nano.
          C 1 Reply Last reply
            C
            C
            CraigDubya
            @mfalkvidd Ahh ok, so it seems that my openhab setup is the problem here. I will continue to try to understand the problem, since the whole purpose of the raspberry pi upgrade was to upgrade openhab to version 2.2.
            I'll hop over to their forums and try and understand what has changed since my upgrade.
            Thanks! :)
            • C CraigDubya
              Thanks! :)
              C
              C
              CraigDubya
              I have a new problem regarding the mysensors serial gateway.
              I have started with a fresh install of Openhab, and have found the documents detailing how to install an up to date java 8 version confusing and out of date. With that said, I'm not sure my java is working properly which may be causing this problem.
              I have installed the mysensors binding via the paperUI marketplace, and after adding the serial gateway and configuring it, it says UNINITIALIZED - HANDLER_INITIALIZING_ERROR.
              The logs in karafe gives:
              00:30:44.518 [DEBUG] [org.openhab.binding.mysensors        ] - BundleEvent STARTING - org.openhab.binding.mysensors
              00:30:44.529 [DEBUG] [org.openhab.binding.mysensors        ] - BundleEvent STARTED - org.openhab.binding.mysensors
              00:30:44.686 [DEBUG] [org.openhab.binding.mysensors        ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.mysensors.factory.MySensorsHandlerFactory, component.id=212, service.id=343, service.bundleid=225, service.scope=bundle} - org.openhab.binding.mysensors
              00:30:45.167 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:7e41fb40' changed from UNINITIALIZED to INITIALIZING
              00:30:45.250 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
              00:30:45.294 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
              00:30:45.299 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: null
              00:30:45.304 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.mysensors.handler.MySensorsBridgeHandler@18c1f58': null
              java.lang.NullPointerException: null
                      at org.openhab.binding.mysensors.handler.MySensorsBridgeHandler.loadCacheFile(MySensorsBridgeHandler.java:172) [225:org.openhab.binding.mysensors:2.3.0.201803141156]
                      at org.openhab.binding.mysensors.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:79) [225:org.openhab.binding.mysensors:2.3.0.201803141156]
                      at sun.reflect.GeneratedMethodAccessor43.invoke(Unknown Source) ~[?:?]
                      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
                      at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
                      at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [109:org.eclipse.smarthome.core:0.10.0.b1]
                      at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [109:org.eclipse.smarthome.core:0.10.0.b1]
                      at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:?]
                      at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:?]
                      at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:?]
                      at java.lang.Thread.run(Thread.java:748) [?:?]
              00:30:45.345 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:7e41fb40' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR)
              00:30:45.344 [ERROR] [home.core.thing.internal.ThingManager] - Exception occurred while initializing handler of thing 'mysensors:bridge-ser:7e41fb40': null
              Can anyone help me to debug this problem?
              I can confirm that when using the command:
              screen /dev/ttyUSB0 115200
              I can see the debug information coming from the gateway:
              0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0
              0;255;3;0;9;4 TSM:INIT
              0;255;3;0;9;6 TSF:WUR:MS=0
              0;255;3;0;9;14 TSM:INIT:TSP OK
              0;255;3;0;9;17 TSM:INIT:GW MODE
              0;255;3;0;9;20 TSM:READY:ID=0,PAR=0,DIS=0
              0;255;3;0;9;23 MCO:REG:NOT NEEDED
              0;255;0;0;18;2.2.0
              0;255;3;0;9;28 MCO:BGN:STP
              0;255;3;0;9;34 MCO:BGN:INIT OK,TSP=1
              And when I operate a sensor node:
              0;255;3;0;9;141450 TSF:MSG:READ,102-102-0,s=1,c=1,t=38,pt=7,l=5,sg=0:3.4
              102;1;1;0;38;3.4
              0;255;3;0;9;141457 TSF:MSG:READ,102-102-0,s=255,c=3,t=0,pt=1,l=1,sg=0:102
              102;255;3;0;0;102
              0;255;3;0;9;141470 TSF:MSG:READ,102-102-0,s=2,c=1,t=16,pt=1,l=1,sg=0:1
              102;2;1;0;16;1
              However, if I use the command:
              cat /dev/ttyUSB0
              I get nothing.
