  3. External power supply to radio
14 Posts 4 Posters 10.6k Views 1 Watching
  • gigiG
    gigiG
    gigi
    I connected a display arduino mega with a NRF24L01 radio module.
    I have power problems. I would like power radio with external 3.3v power supply.
    I tried to connect 3.3 volts from a second Arduino but the radio does not work.
    someone made a separate power supply for the radio?
    Thank
    Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
    RJ_MakeR 1 Reply Last reply
    • gigiG gigi
      Thank
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @gigi What kind of problems did you have when connected to the Mega's 3.3v pin?
      RJ_Make
      gigiG 1 Reply Last reply
      • P
        P
        pete1450
        No problem connecting different power supplies, but often finicky components don't like having separate grounds. Connect the ground of everything together and see how it works.
        • RJ_MakeR RJ_Make
          gigiG
          gigiG
          gigi
          does not transmit the data. sketch hangs after send data
          I try tomorrow
          I will keep you updated.
          I put together a radio rfm12b, a NRF24L01 and a display 128x64
          Thank
          • gigiG gigi
            I try tomorrow
            Thank
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @gigi Is there anything else connected to the 3.3v pin? If not, have you tried installing a cap (I have to use 47uf) on the radio across Vcc and GND?
            RJ_Make
              I had to use a step down from 5V to get stable 3.3v power on the mega.
                gigiG
                gigiG
                gigi
                unfortunately I did not step down to try!!!!
                With PC USB Arduino Mega does not start the radio.
                the system only works when I put an external power supply to VIN on Arduino Mega.
                after 2 or 3 hours arduino crashes!!!
                • gigiG
                  gigiG
                  gigi
                  This is the sketch arduino
                  emon_mysensors.ino
                  • gigiG gigi
                    emon_mysensors.ino
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    @gigi Wow, that's a lot of "stuff" on that 3.3v rail. I think that's your problem... What kind of current are you pulling on that rail when the radio is transmitting.?
                    RJ_Make
                    • RJ_MakeR RJ_Make
                      gigiG
                      gigiG
                      gigi
                      now I try to put the temperature sensor on the 5 volt
                      arduino mega limits the current on 3.3v?
                      I order AMS1117-3.3V,
                      My idea:
                      put the step-down input to 5V external power supply and output on 3.3 rail!!! For not use 3.3 v to MEGA
                      • gigiG gigi
                        My idea:
                        RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        @gigi
                        Here are some specs.
                        Summary:
                        Microcontroller ATmega2560
                        Operating Voltage 5V
                        Input Voltage (recommended) 7-12V
                        Input Voltage (limits) 6-20V
                        Digital I/O Pins 54 (of which 15 provide PWM output)
                        Analog Input Pins 16
                        DC Current per I/O Pin 40 mA
                        DC Current for 3.3V Pin 50 mA
                        Flash Memory 256 KB of which 8 KB used by bootloader
                        SRAM 8 KB
                        EEPROM 4 KB
                        Clock Speed 16 MHz
                        RJ_Make
                        • gigiG
                          gigiG
                          gigi
                          Relay on
                          Only 3.3 volt
                          I do not know if I measured correctly, and my instrument is accurate !!!!!
                          • gigiG gigi
                            Relay on
                            Only 3.3 volt
                            RJ_MakeR
                            RJ_MakeR
                            RJ_Make
                            wrote on last edited by RJ_Make
                            @gigi I just can't believe that the display, rfm12b and NRF24 on the same 3.3v rail is under 50ma,... not too mention the other stuff on it.. You could try disconnecting everything except the NRF24 and see what happens?
                            I can't even get my NRF24's to work with the shop's listed boost with the Pro Mini attached without a 'massive' capacitor.
                            RJ_Make
                            • gigiG
                              gigiG
                              gigi
                              I tried to put a separate power supply.
                              General supply 5V 2 Amps.
                              I do not have the controller and I put two arduino nano for 3.3 volts
                              after 2 hours the system crashes.
                              if I put only one of the two radio system is fine.
                              I tried it with a standalone with two radio but without a monitor and the system works perfectly!!!
                              I have to put other capacitors?
                              Thank
