  3. Auto reset node.
Auto reset node.
10 Posts 3 Posters 2.6k Views 3 Watching
  • E Offline
    E Offline
    eric007
    Here the thing,
    I'm using domoticz(on raspberry) +serialgateway+nrf24L01 plus one node.
    My node is a 4 relays node used for watering my garden.
    My node and the gateway are separated for 1m
    In fact, the node is outside, but there were a hole in the wall so i brought back the rfn24L01 attached to my node inside. Gateway and node works fine together.
    My problem is : something like twice a week Gateway stop reaching the node and the problem persist until a do a reset on the node!
    (a reset on my raspberry and gateway, don't solve anything)
    When i'm home, it's not a big deal but if i'm in holiday for 4 week, my garden will not be watered.
    I'm thinking about setting up a watchdog on the node.
    but i don't know nature of the problem:
    if NRF24L01+ module has crashed or if Arduino nano is crashed, it's different;
    I would like to setup something like this:
    I setup a watchdog on the node.
    The gateway send a specific serial command each minutes to the node, and the node use this command to reset watchdog timer.
    is there a way of doing this ?
    I probably could build a .c program on my raspberry to send a command to the node but i would like to do this from the gateway.
    Thank,
    Eric.
      You could try to check istransportready or sanitycheck and if they return false after 4 or 5 times call a delay (60000) and if you enabled the avr watchdog it should reset the node
      • raptorjrR Offline
        raptorjrR Offline
        raptorjr
        I would suggest to find the problem instead of treating the symptom.
        I had similar problem with a outside node. Lost contact after 3-4 days. Had to switch from electrolytical capacitor to tantalum on the power of the nrf24 to solve the problem. Of course there can be other causes, but it feels much better when the real problem is solved.
          Watchdog is always a good thing to have anyway
          • E Offline
            E Offline
            eric007
            wrote on last edited by eric007
            Thank you both of you,
            i done a mix :
            i setup a watchdog using istransportready and i added a capacitor to the NRF24 (i know i had to but i haden't done it yet, so now it's done).
            for now, it seems working, i'll post a feedback in few days.
            Bye,
            Eric.
            raptorjrR 1 Reply Last reply
            • E eric007
              i done a mix :
              Bye,
              Eric.
              raptorjrR Offline
              raptorjrR Offline
              raptorjr
              @eric007 It is possible to know if the watchdog have restarted? Otherwise you wont know which solution worked. But that it is working may be good enough =)
                you could send millis every time you send data, if you see the millis starting from 0 you had a reset. Maybe there is a more elegant way of doing it
                E 1 Reply Last reply
                • E Offline
                  E Offline
                  eric007
                  It works fine!!! No more signal issue.
                  However, i don't know wich solution has worked but the idea of ​​testing the millis function is perfect and should give a clue.
                  Thank for advices, it was so helpfull.
                  I'll post something when i'll have more details.
                  Eric.
                    E Offline
                    E Offline
                    eric007
                    @gohan yes, i was thinking about using eeprom memory to set a data just before reaching timeout watchdog and use this data at next startup to decide if Arduino has been reseted by watchdog or not.
                    But using millis function is more clever and don't use eeprom memory.
                    Thank,
                    Eric.
                      The capacitor is probably the best option to solve stability issues on nrf24
                      11.8k
                      113.2k
