  3. πŸ’¬ EFEKTA Temperature & Humidity mini sensor
temperatureatmega328batteryhumidityatmega 328p-mu
42 Posts 10 Posters 11.0k Views 9 Watching
  • berkseoB
    berkseoB
    berkseo
    Completed the transfer of 3D models to non-transparent plastics
    5_1547979717759_6.jpg 4_1547979717759_5.jpg 3_1547979717759_4.jpg 2_1547979717759_3.jpg 1_1547979717759_2.jpg 0_1547979717758_1.jpg
    YveauxY 1 Reply Last reply
    • berkseoB berkseo
      YveauxY
      YveauxY
      @berkseo what's the function of the 2 buttons?
      berkseoB 1 Reply Last reply
      • YveauxY Yveaux
        berkseoB
        berkseoB
        berkseo
        wrote on last edited by berkseo
        #23
        @yveaux
        One button is reset, the second button is multifunctional. Depends on how many seconds you hold this button. In my program, I use this button to connect via air to other devices and to transfer the device to receive settings (data transmission intervals, led operation and so on). This button is not used in my test sketch
        An example of direct connection between devices (without the use of controllers, without changing the SOFTWARE) is my development, which is in the testing stage is the controller of Underfloor heating. This device controls the five contours of the Underfloor heating. Up to 10 such temperature sensors can be connected to this device simply by pressing the connect button. Maximum of two temperature sensors per one relay channel.
        https://youtu.be/8mvJFieInsM
        https://youtu.be/kXsxtYVbNAw
        https://youtu.be/NyNFx7sd9ZE
        Examples of direct connections (micro-networks) based on MySensors can be found here:
        https://youtu.be/jFDBeInBZcI
        https://youtu.be/x1oNCO0TXG8
        https://youtu.be/h8Ly_JRFwLg
        • berkseoB
          berkseoB
          berkseo
          https://youtu.be/puOXej1odeU
          • jeremushkaJ
            jeremushkaJ
            jeremushka
            Is it possible for you to share the sketch as it has been removed from the project presentation because of the rules of the website?
            • jeremushkaJ jeremushka
              berkseoB
              berkseoB
              berkseo
              @jeremushka said in πŸ’¬ EFEKTA Temperature & Humidity mini sensor:
              https://www.openhardware.io/view/589#tabs-source
              jeremushkaJ 1 Reply Last reply
              • berkseoB
                berkseoB
                berkseo
                Finished the enclosure for the sensor on the battery 2477 (1000mA) :)
                https://youtu.be/XWu5sogiiQg
                • berkseoB
                  berkseoB
                  berkseo
                  To install the sensor on the wall, I recommend 3M adhesive strips (with easy removal)
                  0_1548509884908_art-5-05119-command-17024-poloska-malenkaya-kleykaya-dlya-plakatov-belyy-450-gr-12-sht-v-up-1.jpg
                  • berkseoB
                    berkseoB
                    berkseo
                    Some more photos... :)
                    • berkseoB berkseo
                      jeremushkaJ
                      jeremushkaJ
                      jeremushka
                      @berkseo said in πŸ’¬ EFEKTA Temperature & Humidity mini sensor:
                      Thank you very much. Great casing, it is very discret. professional design. congratulations :)
                        berkseoB
                        berkseoB
                        berkseo
                        @jeremushka
                        Thanks. This is actually my first experience in designing sensor housings. I've never done 3D modeling before. A month and a half ago I started watching a video on YouTube on modeling in SolidWorks. With printing on a 3D printer is also my first experience.
                        • JoeridemanJ
                          JoeridemanJ
                          Joerideman
                          How did you produce such a nice result? The text and buttons are very detailed.
                          Is it SLA printing?
                          • JoeridemanJ Joerideman
                            Is it SLA printing?
                            berkseoB
                            berkseoB
                            berkseo
                            @joerideman said in πŸ’¬ EFEKTA Temperature & Humidity mini sensor:
                            Is it SLA printing?
                            Yes it is an SLA. One day, watching again another video on YouTube about how people make models of characters on such printers(with high detail), at some point I realized that this technology is very well suited for prototyping cases for miniature devices. It is possible to obtain an almost industrial quality of the final product. ...Then I bought it :) ...And I did.
                            These are attempts to repeat the model on the FDM printer(two different people, on two different printers):
                            1_1548692930506_photo_2019-01-27_19-49-24.jpg 0_1548692930506_photo_2019-01-27_19-19-28.jpg
                            • berkseoB
                              berkseoB
                              berkseo
                              SLA printer:
                              1_1548693091849_photo_2019-01-25_21-27-54.jpg 0_1548693091849_photo_2019-01-25_21-27-54 (2).jpg
                              • berkseoB
                                berkseoB
                                berkseo
                                It turns out a very interesting surface, like a soft-touch
                                • JoeridemanJ
                                  JoeridemanJ
                                  Joerideman
                                  Nice to see the difference.
                                  • jeremushkaJ
                                    jeremushkaJ
                                    jeremushka
                                    Do you solder the components on the PCB by yourself and you launch the whole process in factory? Because soldering such kind of chip ATMEGA328_QFN32 is not that easy or need a microscope i think.
                                      berkseoB
                                      berkseoB
                                      berkseo
                                      #38
                                      I myself solder pcb. These small 328s are easier and faster to solder than the large 328s. Because you don’t need to solder each contact. Positioning, fixing, heating with a soldering dryer, elimination of excess solder with the help of a soldering iron.
                                      • berkseoB
                                        berkseoB
                                        berkseo
                                        https://youtu.be/k2tJ3sJiTnc
                                        • jeremushkaJ
                                          jeremushkaJ
                                          jeremushka
                                          Hello Berk,
                                          Do you still have PCB board available for sales for this project or for the upgraded one with NRF5 ?
                                          With your input, this post could be even better πŸ’—
