  3. Colour temperature?
Colour temperature?
7 Posts 3 Posters 1.6k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    I need to send the correlated colour temperature (CCT) to the controller from a node. How can I present it please in MyMessage()/present()? It is expressed in Kelvins.
    FYG - Colour temperature defines the colour appearance of a white LED. CCT is defined in degrees Kelvin; a warm light is around 2700K, moving to neutral white at around 4000K, and to cool white, at 5000K or more.
    • rejoe2R
      rejoe2R
      rejoe2
      You may use virtually any other type of sensor as a child (apart from the ones representing percentage values). I fyou want to have it bidirectional, use one your controller is able to send. In most cases S_CUSTOM is a good idea, but eg. FHEM will then provide you with 5 variables to exchange info between controller and node - that may be to much.
      alexsh1A 1 Reply Last reply
      • rejoe2R rejoe2
        alexsh1A
        alexsh1A
        alexsh1
        @rejoe2 I am not sure Domoticz would accept S_CUSTOM. It may have been changed recently though. But I wonder if anyone has had a similar issue. How to represent Kelvins? What's the best representative in MySensors?
        • alexsh1A alexsh1
          @alexsh1 I would try the options supported by S_LIGHT_LEVEL, and normal temperature and see which looks best in Domoticz.
          Alternatively, convert the temperature to a rgb value (algorithm: http://www.tannerhelland.com/4435/convert-temperature-rgb-algorithm-code/ ) but I guess it depends on what you're going to do with the value.
          V_TEXT might be a viable fallback if nothing else works.
          • alexsh1A
            alexsh1A
            alexsh1
            @mfalkvidd Nice one - thanks. The only issue is this:
            Start with a temperature, in Kelvin, somewhere between 1000 and 40000.  (Other values may work,
                 but I can't make any promises about the quality of the algorithm's estimates above 40000 K.)
            I have values from 0 to 65535 on RGBW (Provides 16-bit resolution for each channel
            (R, G, B, W))
            • alexsh1A alexsh1
              (R, G, B, W))
              @alexsh1 that's why I suggested the conversion. Or do you need values below 1000K/ above 40000K?
                alexsh1A
                alexsh1A
                alexsh1
                @mfalkvidd For now, I left it all in Lux. I have to think about what to do next. This is for VEML6040 - I intent to use it to manage RGBW LED colours behind my TV
