  3. I'm not good at programming
6 Posts 2 Posters 1.4k Views 2 Watching
  • zrom69Z
    zrom69Z
    zrom69
    wrote on last edited by zrom69
    Hello I'm not good at programming I mix two motion light my times his block is what a he can look at thank
    #define MY_RF24_CE_PIN A0
    #define MY_REPEATER_FEATURE
    #include <Bounce2.h>
    #define MOTION_PIN 4
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define SSR_A_ID 1 // Id of the sensor child
    #define MOTION_ID 2
    // Sleep time between reads (in milliseconds)
    unsigned long SLEEP_TIME = 100000;
    unsigned long T = 1;
    const int buttonPinA = 3;
    const int relayPinA = 5;
    int oldValueA = 0;
    bool stateA = false;
    bool lastMotion;
    Bounce debouncerA = Bounce();
    MyMessage msgA(SSR_A_ID, V_STATUS);
    MyMessage motion_msg(MOTION_ID, V_TRIPPED);
    pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
    pinMode(relayPinA, OUTPUT);
    // After setting up the buttons, setup debouncer
    debouncerA.attach(buttonPinA);
    debouncerA.interval(5);
    digitalWrite(relayPinA, RELAY_OFF);
    // Define the motion sensor pin for digital input
    pinMode(MOTION_PIN, INPUT);
    /*--------------------- Added these lines for toggle switch-------------------------*/
    oldValueA = digitalRead(buttonPinA); // set oldValueA to the current status of the toggle switch
    send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
    void presentation() {
    sendSketchInfo("Mains Controller", "1.0");
    present(SSR_A_ID, S_LIGHT);
    // Register the motion sensor to the gateway
    present(MOTION_ID, S_MOTION);
    Example on how to asynchronously check for new messages from gw
    debouncerA.update();
    // Get the update value
    int valueA = debouncerA.read();
    if (valueA != oldValueA) {
    send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
    oldValueA = valueA;
    // Read digital motion value
    bool motion = digitalRead(MOTION_PIN) == HIGH;
    if (motion != lastMotion) {
    // Send tripped value to gw
    send(motion_msg.set(motion ? "1" : "0"));
    lastMotion = motion;
    T++;
    if (T > SLEEP_TIME) {
    T = 1;
    Serial.print("Motion: ");
    Serial.println(motion);
    switch (message.sensor) {
      case 1:
        stateA = message.getBool();
        digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
        break;
      // Write some debug info
    Serial.println(message.sensor);
    Serial.print("from node:");
    Serial.println(message.sender);
    zrom69Z 1 Reply Last reply
    • zrom69Z zrom69
      #define RELAY_ON 1
      #define RELAY_OFF 0
      #define MOTION_ID 2
      int oldValueA = 0;
      bool lastMotion;
      oldValueA = valueA;
      T++;
      T = 1;
        case 1:
          break;
      zrom69Z
      zrom69Z
      zrom69
      This post is deleted!
      • alowhumA
        alowhumA
        alowhum
        So, if I get this right..
        You want a motion detection sensor? And you tried turning a button node into a motion sensing node by having the motion sensor acting as the button?
        And you want two motion sensors?
        Or do you want to be able to turn on the light and/or sense motion at the same time? You code seems to imply the second.
        So.. what is the problem? Is it not working?
        This is odd:
        A solid sate relay (SSR) is an actuator, not a sensor. Did you try to turn that into a second sensor?
        If you want to have two motion sensors connected, you should probably have two of these:
        (or set the child ID and use one message holder)
        Here you are writing to a relay though:
        Hmmm, you're counting the loops? Up to 100.000? Hmm, I wonder how long that takes in milliseconds. In any case, your node will have trouble receiving any command form the gateway if it's sleeping.
        I'm not sure how that debouncer works.
        What's this all about?
        Why the +4? If you only have one relay, why not just point to that pin directly?
        • zrom69Z
          zrom69Z
          zrom69
          thank you for your response
          light with classic toggle switch
          and i have add pir sensor
          for what I ask to correct
            I have to thank you
          • alowhumA
            alowhumA
            alowhum
            Can you explain the problem a bit more?
            • zrom69Z
              zrom69Z
              zrom69
              in domoticz he sends his state of light
              it is he and turn on or off
