  3. Small wall outlet sensor node
40 Posts 17 Posters 29.6k Views 12 Watching
  • S
    sharath krishna
    really cool :) what are u using to convert the AC-DC ? how u doing it ?
    axillentA J 2 Replies Last reply
    • S sharath krishna
      axillentA
      axillentA
      axillent
      @sharath-krishna thanks
      yearly in this thread you can find a schematics.
      I'm using here SR10. Many alternatives were discussed here http://forum.mysensors.org/topic/687/230v-power-supply-to-arduino
      I've found a solution to my problem with DHT. I put delay(500) at the beginning of setup().
      This is needed to stabilize DC before initializing DHT.
      Alternatively a 4.7uF capacitor can be connected between RESET and GND
      sense and drive
      • axillentA
        axillentA
        axillent
        This is my combined sketch with automatic detection of connected many DS18B20 and DHT11/22
        #define RADIO_CHANNEL		76
        #define DS18B20_PIN			A0
        #define DS18B20_MAX_SENSORS	8
        #define DHT_PIN				A5
        #define LED_PIN				5
        #define SLEEP_TIME_SEC		60
        #include <avr/wdt.h>
        #include <avr/interrupt.h>
        #include <avr/sleep.h>
        #include <OneWire.h>
        #include <DHT.h>
        // DS18B20
        OneWire oneWire(DS18B20_PIN);
        DallasTemperature	sensors(&oneWire);
        MyMessage msgHum(0, V_HUM);
        MyMessage msgTemp(0, V_TEMP);
        struct {
        	struct {
        		uint8_t	count;
        		float	lastTemperature[DS18B20_MAX_SENSORS];
        	} ds18b20;
        	struct {
        		DHT		sensor;
        		uint8_t	count;
        		float lastTemp;
        		float lastHum;
        	} dht;
        } var;
        ISR(WDT_vect) {
        	wdt_disable();
        	//delay(500);
        	pinMode(LED_PIN, OUTPUT);
        	digitalWrite(LED_PIN, HIGH);
        	// init mysensors
        	var.gw.begin(NULL, AUTO, false, AUTO, RF24_PA_LEVEL,RADIO_CHANNEL);
        	// init dalas
        	sensors.begin();
        	var.ds18b20.count = sensors.getDeviceCount();
        	if(var.ds18b20.count > DS18B20_MAX_SENSORS) var.ds18b20.count = DS18B20_MAX_SENSORS;
        	// init dht
        	digitalWrite(LED_PIN, LOW);
        	var.dht.sensor.setup(DHT_PIN);
        	float temperature = var.dht.sensor.getTemperature();
        	var.dht.count = (isnan(temperature))?0:1;
        	var.gw.sendSketchInfo("WallCombined", "1.0");
        	// present ds18b20
        	for (int i=0; i<var.ds18b20.count; i++) {
        		var.gw.present(i+2, S_TEMP);
        	if(var.dht.count) {
        		var.gw.present(0, S_HUM);
        		var.gw.present(1, S_TEMP);
        	var.gw.debugPrint(PSTR("Init of combined sensor: %d ds18b20 sensors, %d dht sensors\n"), var.ds18b20.count, var.dht.count);
        	for(int i=0; i < var.ds18b20.count + var.dht.count; i++) {
        		delay(500);
        		delay(1000);
        	var.gw.process();
        	if(var.ds18b20.count) sensors.requestTemperatures();
        		float temperature = static_cast<float>(static_cast<int>((var.gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        		if (var.ds18b20.lastTemperature[i] != temperature && temperature != -127.00) {
        			var.gw.send(msgTemp.setSensor(i+2).set(temperature,1));
        			var.ds18b20.lastTemperature[i]=temperature;
        	if(var.dht.count) {
        		boolean metric = var.gw.getConfig().isMetric;
        		if (isnan(temperature)) {
        			var.gw.debugPrint(PSTR("Failed reading temperature from DHT\n"));
        		} else if (temperature != var.dht.lastTemp) {
        			var.dht.lastTemp = temperature;
        			if (!metric) {
        				temperature = var.dht.sensor.toFahrenheit(temperature);
        			var.gw.send(msgTemp.setSensor(1).set(temperature, 1));
        		float humidity = var.dht.sensor.getHumidity();
        		if (isnan(humidity)) {
        			var.gw.debugPrint(PSTR("Failed reading humidity from DHT"));
        		} else if (humidity != var.dht.lastHum) {
        			var.dht.lastHum = humidity;
        			var.gw.send(msgHum.setSensor(0).set(humidity, 1));
        	delay(5000);
        	delay(500);
        	// sleep
        	Serial.flush();
        	var.gw.powerDown();
        	for(int wdt_count=SLEEP_TIME_SEC; wdt_count > 0; wdt_count--) {
        		wdt_enable(WDTO_1S);
        		WDTCSR |= (1 << WDIE);
        		set_sleep_mode(SLEEP_MODE_PWR_DOWN);
        		sleep_enable();
        		sei();
        		sleep_cpu();
        		sleep_disable();
        	wdt_disable();
        sense and drive
        • axillentA
          axillentA
          axillent
          3D models are published here http://www.thingiverse.com/thing:688442
          sense and drive
          • axillentA axillent
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            nice job
            can you tell us what kind of 3D printer you are using, and if you are happy with it.
            I have a lot of electronics, and not a lot of housings.... I'm thinking about jumping in!
            axillentA 1 Reply Last reply
              nice job
              axillentA
              axillentA
              axillent
              @BulldogLowell I'm using Makerbot Replicator 2 for more than 2 years
              I have nothing to compare with. But it gives the possibilities I never have.
              From hardware side I had to fix some problems Replicator 2 is having. New models I hope is more sufficient.
              Makerbot is progressing, at least an improvement on software side is essential.
              Today you will find many brands and many models to choose from.
              sense and drive
              • S sharath krishna
                J
                J
                Jan Gatzke
                @axillent How do you upload the sketch? Do you solder in a preprogrammed atmega or are there connectors on the board? The DHT needs only 1.5 mA. Wouldn't it be possible to supply this with an digital out pin of the atmega? This way you could delay the power up process.
                axillentA 2 Replies Last reply
                • bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  Just a fair warning for anyone considering a new ("5th generation") Makerbot Replicator. Check up on some reviews before getting one. Things have apparently gone downhill since the good old days. Extruders don't last as long etc. If anyone is willing to pay the sort of price that Makerbot is asking there are better alternatives.
                  http://nicklievendag.com/makerbot-replicator-5th-generation-review/
                  Also, the Makerbot software is painfully slow compared to most alternatives.
                  http://nicklievendag.com/simplify3d-vs-makerbot-desktop/
                  http://www.fabbaloo.com/blog/2014/7/20/hands-on-with-simplify3d
                  Not that I endorse Simplify3D. There are free / open-source alternatives that are just as fast.
                  Finally, I'm skeptical about the legal details surrounding Thingiverse.
                  • J Jan Gatzke
                    axillentA
                    axillentA
                    axillent
                    wrote on last edited by axillent
                    #29
                    @Jan-Gatzke originally a pre-loaded MCU were soldered but later I solder on top of the PCB a 6 pin ISP connectors
                    There is no need to source DHT from the MCU pin, it is simple to put delay at the beginning of setup or use highest startup time by fuses (my choice)
                    the original idea is to use pogopin connector, but I've just ordered them and not yet received. I need a very small footprint ISP connector for Mysensors devices
                    have no experience with 5th generation but fully agree with you that there are many alternatives
                    it is not true. I'm very satisfied with the performance of the software.
                    I do not believe that someone can be faster than instantaneous
                    what kind of issues?
                    sense and drive
                      bjornhallbergB
                      bjornhallbergB
                      bjornhallberg
                      I meant slicing speeds on very complex models specifically. But it would not surprise me if the print quality / toolpaths created are better with competing software as well.
                      Like Facebook and other big corporations where they basically own the data you upload and store on their servers.
                      Oh, also, bonus points to Makerbot / Stratasys for actually stealing technology and incorporating it into their own designs:
                      http://3dprintingindustry.com/2014/05/28/makerbot-become-takerbot/
                      Bottom line, your Replicator 2 is in many ways better than the current line-up from Makerbot. Mostly because the extruder will last you many thousands of hours and not just 200-500 or whatever they guarantee these days when people come complaining.
                      The biggest joke is perhaps their massive Z18 printer, which costs a fortune, puts out dismal results (at least without a ton of tweaking if at all possible), can't handle ABS and is really slow. Plus having the same lousy extruder. I mean, 200 hours on the Z18 could translate into just 10 reasonably big print jobs. They actually got one at my local Makerspace. :dizzy_face: They could have gotten two ordinary printers for the price of that one ...
                        axillentA
                        axillentA
                        axillent
                        #31
                        @bjornhallberg bad to know that new models are worse
                        actually had no plans to upgrade. For the nearest feature I'm fine with Repl2.
                        it is also important that I made a required tuning and able to recover many things by myself
                        already have an experience and know what to expect
                        I do not think my models complicated but the slicing speed was improved by handred times in the first year of the purchase
                        today i have to wait almost none before printing starts
                        what is even more important - raft support was improved revolutionary. Before it was sucks to print surface on the raft - it became ugly and unacceptable as a from panel. Now all are very different
                        sense and drive
                        • Johnny B GoodJ
                          Johnny B GoodJ
                          Johnny B Good
                          Great project axillent +1
                          -= GreetingZzz and may the sensors be with you =-
                          • Johnny B GoodJ Johnny B Good
                            axillentA
                            axillentA
                            axillent
                            @Johnny-B-Good thanks!
                            sense and drive
                            D 1 Reply Last reply
                              D
                              D
                              Dheeraj
                              @axillent
                              very nice
                              • J Jan Gatzke
                                axillentA
                                axillentA
                                axillent
                                do you mean a .zip file or the inline source?
                                for inline I have to add leading spaces to all lines (it is simple to to in Atmel Studio) and than just past it here
                                sense and drive
                                • S
                                  sharath krishna
                                  @axillent i wanted some more information along with the schematics.. like the wattage of the resistors used and also the type and voltage rating of the capacitors . Please could you provide the same ?
                                  • S sharath krishna
                                    axillentA
                                    axillentA
                                    axillent
                                    @sharath-krishna no problem
                                    all resistors except R4 & R5 are SMD 0603, R4 & R5 are SMD 1206
                                    C8 is 0.47-0.68uF @ 400V for 220V input, or 0.68-1uF @ 250V for 110V
                                    all other capacitors need a rate for 10V and above
                                    sense and drive
                                    T 1 Reply Last reply
                                      Tibus
                                      @axillent thanks for the values but what are the wattage of the resistors?
                                      • S
                                        sharath krishna
                                        @axillent : thanks :+1: and @Tibus i think all only 45 and r4 would be like 0.5w else all 0.25 may be :) i have not worked much with smd tough.
                                        • T Tibus
                                          axillentA
                                          axillentA
                                          axillent
                                          @Tibus I gave you the footprints, for SMD it is equivalent of the wattage)
                                          actually only R4 & R5 a sensitive to the footprints. An even more sensitive to a maximum rating voltage than to the wattage.
                                          I'm using two 1206 in series to be sure that they will hold up to 400V. I made a check of different brands, usually the maximum rated voltage for 1206 is not bellow 200-300V, that means that in series of equal resistors the maximum rated voltage will be 400-600V
                                          all other resistors are under low voltage and very low power dissipation
                                          but if you need wattage just for learning curve, usually 0601 is 0.1W, 1206 is 0.25W
                                          sense and drive
