1.1k Posts 105 Posters 790.4k Views 98 Watching
  • FanfanF
    FanfanF
    Fanfan
    My 3V Node (Atmega328P 1MHz), embedded NRF24L01+ with ceramic antenna, ATSHA256, AT25DF512, BME208, LED, Battery monitoring, ICSP, FTDI, Castelizable, Breadboardable. 0_1560175339322_IMG_20190610_155632461.jpg
    monteM 1 Reply Last reply
    • FanfanF Fanfan
      monteM
      monteM
      monte
      @fanfan nice! How is the signal compared to stock nrf24 modules? How much for antenna?
      FanfanF 1 Reply Last reply
      • monteM monte
        FanfanF
        FanfanF
        Fanfan
        @monte A little bit less, but not a lot. I still need to improve the PCB (better castelization tracks, remove diodes, ...) and this should be ready to be copied/used.
        • berkseoB
          berkseoB
          berkseo
          Today finished with the HW part of the new device
          https://youtu.be/X1_tU14Vo5A
            Great idea @sundberg84
            This prompted me to finally get started on something that I've put off for far too long, especially considering how little work it was.
            I'm still using dupont wires to connect my radios, despite better solutions such as the easypcb being available. But this quick little trick makes it easier to switch the radio modules.
            https://youtu.be/Jeg0kS9AcgY
            You'll need:
            • Dupont female-female wires (I use 10cm), https://www.aliexpress.com/item/Free-Shipping-1lot-40pcs-lot-10cm-2-54mm-1pin-femal-to-femal-jumper-wire-Dupont-cable/32329983091.html
            • 4x2 jumper wire connector/header from a 620 pcs kit, https://www.aliexpress.com/item/620-Pcs-1-Set-Jumper-Wire-Cable-Pin-Header-Connector-Kit-Male-Crimp-Female-Pin-Terminal/32816829548.html
            • NRF24L01+ radio module, https://www.aliexpress.com/item/Free-shiping-best-prices-10pcs-lot-NRF24L01-NRF24L01-Wireless-Module-2-4G-Wireless-Communication-Module/674686536.html
            • Small screwdriver
            In the future, I plan to build the other end of the connector for Pro Mini and Rasbperry Pi.
            LaranL
            LaranL
            Laran
            @mfalkvidd
            Looks impressive!
            • berkseoB
              berkseoB
              berkseo
              #805
              Today finished new device:
              2_1561646085870_IMG_20190622_140526.jpg 1_1561646085870_IMG_20190620_111739.jpg 0_1561646085869_IMG_20190620_111730.jpg
              1_1561646101731_IMG_20190624_170037_1.jpg 0_1561646101730_IMG_20190622_140641.jpg
              2_1561646137853_IMG_20190627_012217.jpg 1_1561646137853_IMG_20190627_012203.jpg 0_1561646137853_IMG_20190627_012106.jpg
              Video:
              https://youtu.be/DVpDjXjeUKg
              • franz-unixF
                franz-unixF
                franz-unix
                Today.... This MQ2 gas sensor with Neopixel RGB lamp on top and a capacitive touch button under the circle mark on the front.
                5_1562001267230_DSC_3411.JPG 4_1562001267230_DSC_3410.JPG 3_1562001267230_DSC_3409.JPG 2_1562001267230_DSC_3408.JPG 1_1562001267230_DSC_3407.JPG 0_1562001267230_DSC_3405.JPG
                It is part of the d-diot project. The files of the 3d-printable case are available in Thingiverse.
                The firmware is available here, the wiki page is under construction.
                In the next weeks I will try to print it in wood... Just to increase the WAF :wink:
                • berkseoB
                  berkseoB
                  berkseo
                  #807
                  My new micro-sensor water leak ready. Powered by NRF52832-CIAA
                  7_1562099024631_photo_2019-07-02_19-55-19.jpg 6_1562099024631_photo_2019-07-02_19-51-25.jpg 5_1562099024631_photo_2019-07-02_19-49-52.jpg 4_1562099024631_photo_2019-07-02_19-49-51.jpg 3_1562099024631_photo_2019-07-02_19-49-51 (2).jpg 2_1562099024630_photo_2019-07-02_19-49-50.jpg 1_1562099024630_photo_2019-07-01_02-46-18.jpg 0_1562099024629_photo_2019-07-01_02-45-11.jpg
                  cr2032, ... ~3μA consumption
                  S 1 Reply Last reply
                  • bjacobseB
                    bjacobseB
                    bjacobse
                    Love to to watch all you creative designs :-)
                    • berkseoB
                      berkseoB
                      berkseo
                      Pro version of water leak sensor, for very very hard to reach and remote places :). Version with amplifier.
                      5_1562543076800_photo_2019-07-07_23-57-52.jpg 4_1562543076800_photo_2019-07-07_23-57-51.jpg 3_1562543076800_photo_2019-07-07_23-57-51 (3).jpg 2_1562543076799_photo_2019-07-07_23-57-51 (2).jpg 1_1562543076799_photo_2019-07-07_23-57-18.jpg 0_1562543076798_photo_2019-07-07_23-57-18 (2).jpg
                      2_1562543243269_IMG_20190708_001841.jpg 1_1562543243269_IMG_20190708_001827.jpg 0_1562543243268_IMG_20190708_001811.jpg
                      2_1562543302176_IMG_20190708_021019.jpg 1_1562543302176_IMG_20190708_020546.jpg 0_1562543302175_IMG_20190708_020504.jpg
                      1_1562543394654_IMG_20190708_020335.jpg 0_1562543394654_IMG_20190708_020123.jpg
                      Nca78N B 2 Replies Last reply
                      • berkseoB berkseo
                        @berkseo what's the range improvement with amplifier ?
                        From my experience with nrf24 the amplifier + ceramic antenna was not giving great results.
                        berkseoB 1 Reply Last reply
                        • Nca78N Nca78
                          berkseoB
                          berkseoB
                          berkseo
                          #811
                          @nca78 said in What did you build today (Pictures) ?:
                          A few months ago, when testing, I received about 200 meters of stabilized power from the power bank. While this device was tested for 30 metres. There are problems with receiving the delivery confirmation, the device is guaranteed to transmit, but does not receive the delivery confirmation(sometimes). I think it's linked to my gateway, it has the usual radio module nrf24l01+. Of course we are talking about dc-dc-mode :)
                          • berkseoB berkseo
                            B
                            B
                            boozz
                            wrote on last edited by boozz
                            #812
                            @berkseo
                            I do not want to be too offensive, but it seems to me as if your skills in electronics and 3D-printing is way better developed than your trust in the plumbing :sweat_smile:
                            Now for the serious part: how often do you experience water leaks? And how long do the batteries in this design last?
                            Boozz
                            gohanG berkseoB 2 Replies Last reply
                            • B boozz
                              @berkseo
                              Boozz
                              @boozz serious water leak heppened once in 40 years
                                B
                                B
                                boozz
                                @gohan
                                I was referring to @berkseo 's situation and images/examples. I just wondered why this person would put this amount of effort in creating a device that would probably not be functional at the moment it should be functional. I'm just thinking about corrosion of the pcb, a drained battery, change of properties of the 'sensor' due to time-effects etc.
                                Do not misunderstand me: I'm absolutely enthousiastic about this device (and I'm impressed by how small it is and the design), but I'm a bit concerned about the effects that could negatively affect the behaviour of it.
                                Nca78N berkseoB 2 Replies Last reply
                                • B boozz
                                  @gohan
                                  @boozz said in What did you build today (Pictures) ?:
                                  @gohan
                                  You can see on the picture he already had a leak under his kitchen sink :p
                                  And in some countries pipes installations are not very reliable, for example yesterday evening my dishwasher emptied on the floor because the workers did not glue the PVC pipe angle so it went away. Would have love to be warned at the first drops instead of realizing it much later when walking in water in the middle of the kitchen. I also had problem with drinkable water fountain not stopping when tank was full and emptying the 20l bottle on the floor, leaks of sinks and bathtub in the bathrooms in previous apartment, etc etc
                                  So there's truly a "market" for those sensors, they could also be slightly modified to make rain detection instead and warn you if rain is coming and some windows are still opened (very useful here in tropical weather when you can switch from sunny to tropical rain in a mater of minutes).
                                  And if you use the low power comparator of the nrf5 it uses only a few uA in sleep mode, easily detects a bit of water between the 2 contacts and can last for 1-2 years on button cell.
                                  • Nca78N Nca78
                                    @gohan
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    #816
                                    @nca78 I suspect what @boozz is referring to is not the functionality but the direct effect of water on the device.
                                    Pretty sure a pair of threaded socket bolts could be swapped for the cover screws and permit wall mounting on a couple of threaded SS electrodes to solve it though, and it would still make for a very compact and unobtrusive arrangement.
                                    • K
                                      K
                                      kimot
                                      wrote on last edited by kimot
                                      #817
                                      I think very useful device.
                                      Stainless screw like detectors - no corrosion.
                                      And all the time this device sits in dry area - no corrosion.
                                      But software must call controller ( with battery level for example ) sometimes, say one per a day, to inform it is alive.
                                      And if controller does not receive this message - sends alert.
                                      I am using this for all my nodes - very easy in Domoticz.
                                      If node dies, Domoticz send me e-mail ( and SMS ) with information.
                                      And 40 years with this hoses for example ?
                                      Try it .....
                                      • K kimot
                                        Try it .....
                                        zboblamontZ
                                        zboblamontZ
                                        zboblamont
                                        #818
                                        @kimot I followed your logic until you suggested 40 years in the future with presumably failed wash hand basin umbillicals..
                                        K 1 Reply Last reply
                                        • berkseoB berkseo
                                          sindrome73
                                          @berkseo I'm sorry if I can, but what kind of sensor are you using to detect water ?? I would like to do something like that but with an Arduino pro !!
