  3. Watchdog on Ethernet Gateway
ethernetgatewayattiny45watchdog
32 Posts 9 Posters 24.6k Views 1 Watching
  • axillentA axillent
    @BulldogLowell wdt_enable alone cannot be sufficient
    first of all you need a bootloader having watchdog support
    official bootloader is not working with watchdog
    optiboot is working
    other alternative is to kill a bootloader but you will need ISP programmer to download sketches
    second wdt_reset need to be embedded into many places across sketch and library sources
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    OK, so for now it's a hardware plan!
    axillentA 1 Reply Last reply
      axillentA
      axillentA
      axillent
      @BulldogLowell why not to play around with your own copy of the sources?
      with success you can be a contributor of this nice feature
      sense and drive
        optiboot is working
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        It's in general good practice to enable the watchdog to avoid deadlocks. What works best in my experience is to set the wdt to 8s and reset the wdt timer at the beginning of the main loop (as long as it takes max. 8s).
        Important: Avoid blocking functions and delay() - substitute delay() for mysensors::wait(), where the wdt is reset.
        The problems with the ethernet shield W5100 are discussed everywhere, resetting the arduino won't help in that case, but rather implementing an external watchdog that power-cycles the shield...
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          OK, I'll give it a stab.
          you mean generally, or you are using it already on this application?
          tekkaT 1 Reply Last reply
            tekkaT
            tekkaT
            tekka
            @BulldogLowell both, i'm using the wdt with Optiboot and MYSBootloader. Reading MCUSR during bootloading will give a hint on the reset cause...
            • tekkaT tekka
              tekkaT
              tekkaT
              tekka
              Here a simple sketch:
              #include <avr\wdt.h>
                // set watchdog to 8s
                wdt_enable(WDTO_8S);
                // watchdog reset
                wdt_reset();
                // do some stuff that does not take longer than 8s
               // else watchdog will trigger
              • tekkaT tekka
                  // watchdog reset
                  wdt_reset();
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                yes, got that far ;) I thought you meant you had it working on a gateway.
                Working with the (as @axillent said) the gateway, with all of its nuances and making it extensible for (the majority?) of the standard sensor sketches would be the challenge.
                  axillentA
                  axillentA
                  axillent
                  @BulldogLowell setting watchdog to timeout after 8 seconds can support you in most situations without a need to dig into library source
                  But you will be not guaranteed from all cases, it is possible that your arduino will be reset in normal situation where reset is not needed. But actually the same will happen if you will attach external watchdog as you state in you first post here
                  sense and drive
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    I have a lot more flexibility with hardware, i believe.... there is an (8s) limit on the Atmel watchdog, no?
                    axillentA Dan S.D 2 Replies Last reply
                      axillentA
                      axillentA
                      axillent
                      it is a limit of atmega328, other MCU can differ
                      but it is still possible to organize longer period by activating WDT ISR handler
                      this will be not the best practice but it will work
                      the best practice is to set very short timeout and to put wdt_reset() at all required points
                      sense and drive
                        What happens with watchdog while sleeping?
                          axillentA
                          axillentA
                          axillent
                          it depends on what do you want :)
                          if i'm not mistaken LowPower library you are using is using watchdog while sleeping
                          actually watchdog is only one timer running while POWER_DOWN
                          it is a common way to wake up because of watchdog event from the deepest sleep if you need to wake up by time, not by external event
                          sense and drive
                          • G
                            G
                            Gambituk
                            Hi, i would be interested in any more updates along this line. In my case my gateway is mostly stable as far as i can tell. several weeks without issues. My problem is that most of my nodes seem to lockup, so i would be totally interested in making them more robust either by software or if necessary with external chip as overlord watchdog
                              Dan S.D
                              Dan S.D
                              Dan S.
                              @BulldogLowell Any progress on this? My Ethernet gateway is quite reliable after solving power supply issues and implementing soft spi. But about once a month it stops and rebooting it makes it operative again. The failure seems to be periodic--once a month. May be a clue there--something reaching a limit? At any rate, any failure rate where I can't start it up without physically rebooting is too much.
                                maha
                                millis() has a rollover after approximately 50 days. Could that be something?
                                Dan S.D 1 Reply Last reply
                                • M maha
                                  Dan S.D
                                  Dan S.D
                                  Dan S.
                                  @maha Don't know. But your question did trigger the thought of using milils() to periodically trigger a reboot. Rather than check for a lockup with a watchdog routine I may try just rebooting it at a shorter time interval, e.g., every 2 weeks, than I have experienced the lockups using millis to measure the interval.
                                  • Dan S.D
                                    Dan S.D
                                    Dan S.
                                    Added a 8 sec Watchdog to my ethernet gateway and it's up and running now. Time will tell if it cures the occaisional lockups by automatically resetting. Will report back the results
                                      FYI: Watchdog reset is automatically called by process() nowadays in the development-branch.
                                      https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.cpp#L509
                                        Dan S.D
                                        Dan S.D
                                        Dan S.
                                        @hek I assume this is with the intent to allow a watchdog reset on sensor sketches in the future, but does not apply to the Ethernet gateway sketch?
                                          Dan S.D
                                          Dan S.D
                                          Dan S.
                                          @hek Please disregard my prior message. I looked further and see that the watchdog reset is part of the sensor wait routine and is in the current 1.4 version of MySensors.cpp
