  3. Watchdog on Ethernet Gateway
ethernetgatewayattiny45watchdog
32 Posts 9 Posters 24.6k Views 1 Watching
  • tekkaT tekka
    Here a simple sketch:
    #include <avr\wdt.h>
      // set watchdog to 8s
      wdt_enable(WDTO_8S);
      // watchdog reset
      wdt_reset();
      // do some stuff that does not take longer than 8s
     // else watchdog will trigger
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    yes, got that far ;) I thought you meant you had it working on a gateway.
    Working with the (as @axillent said) the gateway, with all of its nuances and making it extensible for (the majority?) of the standard sensor sketches would be the challenge.
    axillentA 1 Reply Last reply
      axillentA
      axillentA
      axillent
      @BulldogLowell setting watchdog to timeout after 8 seconds can support you in most situations without a need to dig into library source
      But you will be not guaranteed from all cases, it is possible that your arduino will be reset in normal situation where reset is not needed. But actually the same will happen if you will attach external watchdog as you state in you first post here
      sense and drive
      • axillentA axillent
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        I have a lot more flexibility with hardware, i believe.... there is an (8s) limit on the Atmel watchdog, no?
        axillentA Dan S.D 2 Replies Last reply
          axillentA
          axillentA
          axillent
          it is a limit of atmega328, other MCU can differ
          but it is still possible to organize longer period by activating WDT ISR handler
          this will be not the best practice but it will work
          the best practice is to set very short timeout and to put wdt_reset() at all required points
          sense and drive
            What happens with watchdog while sleeping?
              axillentA
              axillentA
              axillent
              it depends on what do you want :)
              if i'm not mistaken LowPower library you are using is using watchdog while sleeping
              actually watchdog is only one timer running while POWER_DOWN
              it is a common way to wake up because of watchdog event from the deepest sleep if you need to wake up by time, not by external event
              sense and drive
              • G
                G
                Gambituk
                Hi, i would be interested in any more updates along this line. In my case my gateway is mostly stable as far as i can tell. several weeks without issues. My problem is that most of my nodes seem to lockup, so i would be totally interested in making them more robust either by software or if necessary with external chip as overlord watchdog
                  Dan S.D
                  Dan S.D
                  Dan S.
                  @BulldogLowell Any progress on this? My Ethernet gateway is quite reliable after solving power supply issues and implementing soft spi. But about once a month it stops and rebooting it makes it operative again. The failure seems to be periodic--once a month. May be a clue there--something reaching a limit? At any rate, any failure rate where I can't start it up without physically rebooting is too much.
                    maha
                    millis() has a rollover after approximately 50 days. Could that be something?
                    Dan S.D 1 Reply Last reply
                    • M maha
                      Dan S.D
                      Dan S.D
                      Dan S.
                      @maha Don't know. But your question did trigger the thought of using milils() to periodically trigger a reboot. Rather than check for a lockup with a watchdog routine I may try just rebooting it at a shorter time interval, e.g., every 2 weeks, than I have experienced the lockups using millis to measure the interval.
                      • Dan S.D
                        Dan S.D
                        Dan S.
                        Added a 8 sec Watchdog to my ethernet gateway and it's up and running now. Time will tell if it cures the occaisional lockups by automatically resetting. Will report back the results
                          FYI: Watchdog reset is automatically called by process() nowadays in the development-branch.
                          https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.cpp#L509
                            Dan S.D
                            Dan S.D
                            Dan S.
                            @hek I assume this is with the intent to allow a watchdog reset on sensor sketches in the future, but does not apply to the Ethernet gateway sketch?
                              Dan S.D
                              Dan S.D
                              Dan S.
                              @hek Please disregard my prior message. I looked further and see that the watchdog reset is part of the sensor wait routine and is in the current 1.4 version of MySensors.cpp
                              • Dan S.D
                                Dan S.D
                                Dan S.
                                It's been over 6 weeks since I added an 8 sec watchdog to my Ethernet gateway (to Vera) and have not had to reboot the gateway since then. Before adding the watchdog, the most it ever lasted before without rebooting was 4 weeks. So for now I have to assume that the watchdog is doing its job and automatically restoring the gateway. If so, then it is providing the gateway dependability that I wanted. Time will tell.
                                • Dan S.D Dan S.
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @Dan-S.
                                  great news, thanks for the update!
                                  can you share how you set it up? Are you using the stock gateway code?
                                    @Dan-S.
                                    Dan S.D
                                    Dan S.D
                                    Dan S.
                                    @BulldogLowell
                                    I got my basic info and code for a watchdog timer from a pdf by Nicolas Larson titled "Basic Watchdog Timer" at this site:
                                    http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB4QFjAA&url=http%3A%2F%2Fforum.arduino.cc%2Findex.php%3Faction%3Ddlattach%3Btopic%3D63651.0%3Battach%3D3585&ei=lc6ZVYiiM8PigwTVx4HYCQ&usg=AFQjCNEBfr1yZ_g44GdxaNVmH4zKyTz3nA&bvm=bv.96952980,d.eXY
                                    Yes, I am using the stock gateway code with the watchdog code outlined in the pdf added. His code includes a lot of details in the setup that can probably be streamlined but I liked operating at the elementary level to better see what is going on.
                                    Will post the whole gateway sketch. What's the best way to go about posting it?
                                    DwaltD 1 Reply Last reply
                                    • Dan S.D Dan S.
                                      @BulldogLowell
                                      DwaltD
                                      DwaltD
                                      Dwalt
                                      @Dan-S. To insert code on the forum, use the </> button above the 'compose box'.
                                        @Dan-S.
                                        Dan S.D
                                        Dan S.D
                                        Dan S.
                                        @BulldogLowell
                                        Here's the code. Should be the same as standard except that I didn't use ip address input.
                                        In
                                         * Copyright (C) 2013 Henrik Ekblad <henrik.ekblad@gmail.com>
                                         * Contribution by a-lurker
                                         * COMPILING WIZNET (W5100) ETHERNET MODULE
                                         * > Edit RF24_config.h in (libraries\MySensors\utility) to enable softspi (remove // before "#define SOFTSPI").
                                         * COMPILING ENC28J60 ETHERNET MODULE
                                         * > Use Arduino IDE 1.5.7 (or later)
                                         * > Disable DEBUG in Sensor.h before compiling this sketch. Othervise the sketch will probably not fit in program space when downloading.
                                         * > Remove Ethernet.h include below and include UIPEthernet.h
                                         * > Remove DigitalIO include
                                         * Note that I had to disable UDP and DHCP support in uipethernet-conf.h to reduce space. (which means you have to choose a static IP for that module)
                                         * VERA CONFIGURATION:
                                         * LED purposes:
                                        #include <DigitalIO.h>     // This include can be removed when using UIPEthernet module
                                        #include <MyGateway.h>
                                        #include <stdarg.h>
                                        //watchdog version of gateway
                                        #include <avr/wdt.h>
                                        // Use this if you have attached a Ethernet ENC28J60 shields
                                        //#include <UIPEthernet.h>
                                        // Use this fo WizNET W5100 module and Arduino Ethernet Shield
                                        #include <Ethernet.h>
                                        #define RADIO_CE_PIN        5  // radio chip enable
                                        #define RADIO_SPI_SS_PIN    6  // radio SPI serial select
                                        #define RADIO_ERROR_LED_PIN 7  // Error led pin
                                        #define RADIO_TX_LED_PIN    9  // the PCB, on board LED
                                        #define IP_PORT 5003        // The port you want to open
                                        //IPAddress myIp (192, 168, 1, 14);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
                                        // Commented out IPAddress to use DHCP router assigned address, Cannot check program with serial monitor with this
                                        //since the DHCP address will not be available till plugged into ethernet.
                                        byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
                                        // a R/W server on the port
                                        EthernetServer server = EthernetServer(IP_PORT);
                                        // No blink or button functionality. Use the vanilla constructor.
                                        MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME);
                                        // Uncomment this constructor if you have leds and include button attached to your gateway
                                        //MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME, INCLUSION_MODE_PIN, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                                        char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
                                        int inputPos = 0;
                                          Ethernet.begin(mac);
                                          // give the Ethernet interface a second to initialize
                                          delay(1000);
                                          gw.begin(RF24_PA_LEVEL_GW, RF24_CHANNEL, RF24_DATARATE, writeEthernet);
                                          server.begin();
                                          //set the watchdog
                                          watchdogSetup();
                                        // This will be called when data should be written to ethernet
                                        void writeEthernet(char *writeBuffer) {
                                          server.write(writeBuffer);
                                        //WatchDog setup function
                                        void watchdogSetup(void)
                                        cli();
                                        wdt_reset();
                                        WDTCSR configuration:
                                        WDIE = 1: Interrupt Enable
                                        WDE = 1 :Reset Enable
                                        WDP3 = 1 :For 8000ms Time-out
                                        WDP2 = 0 :For 8000ms Time-out
                                        WDP1 = 0 :For 8000ms Time-out
                                        WDP0 = 1 :For 8000ms Time-out
                                        // Enter Watchdog Configuration mode:
                                        WDTCSR |= (1<<WDCE) | (1<<WDE);
                                        // Set Watchdog settings:
                                        //no interrupt, reset enable
                                        WDTCSR = (0<<WDIE) | (1<<WDE) |
                                        //8 second timer
                                        (1<<WDP3) | (0<<WDP2) | (0<<WDP1) |
                                        (1<<WDP0);
                                        sei();
                                          // if an incoming client connects, there will be
                                          // bytes available to read via the client object
                                          EthernetClient client = server.available();
                                          if (client) {
                                              // if got 1 or more bytes
                                              if (client.available()) {
                                                 // read the bytes incoming from the client
                                                 char inChar = client.read();
                                                 if (inputPos<MAX_RECEIVE_LENGTH-1) {
                                                   // if newline then command is complete
                                                   if (inChar == '\n') {
                                                      // a command was issued by the client
                                                      // we will now try to send it to the actuator
                                                      inputString[inputPos] = 0;
                                                      // echo the string to the serial port
                                                      Serial.print(inputString);
                                                      gw.parseAndSend(inputString);
                                                      // clear the string:
                                                      inputPos = 0;
                                                     // add it to the inputString:
                                                     inputString[inputPos] = inChar;
                                                     inputPos++;
                                                   inputPos = 0;
                                           gw.processRadioMessage();
                                         //reset watchdog
                                         wdt_reset();
                                        • Dan S.D
                                          Dan S.D
                                          Dan S.
                                          Would not recommend adding the watchdog until you have a relatively stable gateway, e.g. you have addressed any power/radio issues etc. Otherwise you will have the watchdog constantly tripping in response to issues that are best addressed by other means, i.e., proper troubleshooting.
