  3. Watchdog on Ethernet Gateway
ethernetgatewayattiny45watchdog
32 Posts 9 Posters 24.6k Views 1 Watching
  • axillentA axillent
    @BulldogLowell why not to play around with your own copy of the sources?
    with success you can be a contributor of this nice feature
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    OK, I'll give it a stab.
    @tekka said:
    What works best in my experience is to set the wdt to 8s and reset the wdt timer at the beginning of the main loop (as long as it takes max. 8s).
    you mean generally, or you are using it already on this application?
    tekkaT 1 Reply Last reply
      tekkaT
      tekkaT
      tekka
      @BulldogLowell both, i'm using the wdt with Optiboot and MYSBootloader. Reading MCUSR during bootloading will give a hint on the reset cause...
      • tekkaT tekka
        tekkaT
        tekkaT
        tekka
        Here a simple sketch:
        #include <avr\wdt.h>
          // set watchdog to 8s
          wdt_enable(WDTO_8S);
          // watchdog reset
          wdt_reset();
          // do some stuff that does not take longer than 8s
         // else watchdog will trigger
        • tekkaT tekka
            // watchdog reset
            wdt_reset();
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          yes, got that far ;) I thought you meant you had it working on a gateway.
          Working with the (as @axillent said) the gateway, with all of its nuances and making it extensible for (the majority?) of the standard sensor sketches would be the challenge.
          axillentA 1 Reply Last reply
            axillentA
            axillentA
            axillent
            @BulldogLowell setting watchdog to timeout after 8 seconds can support you in most situations without a need to dig into library source
            But you will be not guaranteed from all cases, it is possible that your arduino will be reset in normal situation where reset is not needed. But actually the same will happen if you will attach external watchdog as you state in you first post here
            sense and drive
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              I have a lot more flexibility with hardware, i believe.... there is an (8s) limit on the Atmel watchdog, no?
              axillentA Dan S.D 2 Replies Last reply
                axillentA
                axillentA
                axillent
                it is a limit of atmega328, other MCU can differ
                but it is still possible to organize longer period by activating WDT ISR handler
                this will be not the best practice but it will work
                the best practice is to set very short timeout and to put wdt_reset() at all required points
                sense and drive
                  What happens with watchdog while sleeping?
                    axillentA
                    axillentA
                    axillent
                    it depends on what do you want :)
                    if i'm not mistaken LowPower library you are using is using watchdog while sleeping
                    actually watchdog is only one timer running while POWER_DOWN
                    it is a common way to wake up because of watchdog event from the deepest sleep if you need to wake up by time, not by external event
                    sense and drive
                    • G
                      G
                      Gambituk
                      Hi, i would be interested in any more updates along this line. In my case my gateway is mostly stable as far as i can tell. several weeks without issues. My problem is that most of my nodes seem to lockup, so i would be totally interested in making them more robust either by software or if necessary with external chip as overlord watchdog
                        Dan S.D
                        Dan S.D
                        Dan S.
                        @BulldogLowell Any progress on this? My Ethernet gateway is quite reliable after solving power supply issues and implementing soft spi. But about once a month it stops and rebooting it makes it operative again. The failure seems to be periodic--once a month. May be a clue there--something reaching a limit? At any rate, any failure rate where I can't start it up without physically rebooting is too much.
                          maha
                          millis() has a rollover after approximately 50 days. Could that be something?
                          Dan S.D 1 Reply Last reply
                          • M maha
                            Dan S.D
                            Dan S.D
                            Dan S.
                            @maha Don't know. But your question did trigger the thought of using milils() to periodically trigger a reboot. Rather than check for a lockup with a watchdog routine I may try just rebooting it at a shorter time interval, e.g., every 2 weeks, than I have experienced the lockups using millis to measure the interval.
                            • Dan S.D
                              Dan S.D
                              Dan S.
                              Added a 8 sec Watchdog to my ethernet gateway and it's up and running now. Time will tell if it cures the occaisional lockups by automatically resetting. Will report back the results
                                FYI: Watchdog reset is automatically called by process() nowadays in the development-branch.
                                https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.cpp#L509
                                  Dan S.D
                                  Dan S.D
                                  Dan S.
                                  @hek I assume this is with the intent to allow a watchdog reset on sensor sketches in the future, but does not apply to the Ethernet gateway sketch?
                                    Dan S.D
                                    Dan S.D
                                    Dan S.
                                    @hek Please disregard my prior message. I looked further and see that the watchdog reset is part of the sensor wait routine and is in the current 1.4 version of MySensors.cpp
                                    • Dan S.D
                                      Dan S.D
                                      Dan S.
                                      It's been over 6 weeks since I added an 8 sec watchdog to my Ethernet gateway (to Vera) and have not had to reboot the gateway since then. Before adding the watchdog, the most it ever lasted before without rebooting was 4 weeks. So for now I have to assume that the watchdog is doing its job and automatically restoring the gateway. If so, then it is providing the gateway dependability that I wanted. Time will tell.
                                      • Dan S.D Dan S.
                                        BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        @Dan-S.
                                        great news, thanks for the update!
                                        can you share how you set it up? Are you using the stock gateway code?
                                          @Dan-S.
                                          Dan S.D
                                          Dan S.D
                                          Dan S.
                                          @BulldogLowell
                                          I got my basic info and code for a watchdog timer from a pdf by Nicolas Larson titled "Basic Watchdog Timer" at this site:
                                          http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB4QFjAA&url=http%3A%2F%2Fforum.arduino.cc%2Findex.php%3Faction%3Ddlattach%3Btopic%3D63651.0%3Battach%3D3585&ei=lc6ZVYiiM8PigwTVx4HYCQ&usg=AFQjCNEBfr1yZ_g44GdxaNVmH4zKyTz3nA&bvm=bv.96952980,d.eXY
                                          Yes, I am using the stock gateway code with the watchdog code outlined in the pdf added. His code includes a lot of details in the setup that can probably be streamlined but I liked operating at the elementary level to better see what is going on.
                                          Will post the whole gateway sketch. What's the best way to go about posting it?
                                          DwaltD 1 Reply Last reply
