  3. Watchdog on Ethernet Gateway
ethernetgatewayattiny45watchdog
32 Posts 9 Posters 24.6k Views 1 Watching
  • axillentA axillent
    @BulldogLowell wdt_enable alone cannot be sufficient
    first of all you need a bootloader having watchdog support
    official bootloader is not working with watchdog
    optiboot is working
    other alternative is to kill a bootloader but you will need ISP programmer to download sketches
    second wdt_reset need to be embedded into many places across sketch and library sources
    tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    It's in general good practice to enable the watchdog to avoid deadlocks. What works best in my experience is to set the wdt to 8s and reset the wdt timer at the beginning of the main loop (as long as it takes max. 8s).
    Important: Avoid blocking functions and delay() - substitute delay() for mysensors::wait(), where the wdt is reset.
    The problems with the ethernet shield W5100 are discussed everywhere, resetting the arduino won't help in that case, but rather implementing an external watchdog that power-cycles the shield...
      @BulldogLowell why not to play around with your own copy of the sources?
      with success you can be a contributor of this nice feature
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      OK, I'll give it a stab.
      you mean generally, or you are using it already on this application?
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        @BulldogLowell both, i'm using the wdt with Optiboot and MYSBootloader. Reading MCUSR during bootloading will give a hint on the reset cause...
        • tekkaT tekka
          tekkaT
          tekkaT
          tekka
          Here a simple sketch:
          #include <avr\wdt.h>
            // set watchdog to 8s
            wdt_enable(WDTO_8S);
            // watchdog reset
            wdt_reset();
            // do some stuff that does not take longer than 8s
           // else watchdog will trigger
          • tekkaT tekka
              // watchdog reset
              wdt_reset();
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            yes, got that far ;) I thought you meant you had it working on a gateway.
            Working with the (as @axillent said) the gateway, with all of its nuances and making it extensible for (the majority?) of the standard sensor sketches would be the challenge.
            axillentA 1 Reply Last reply
              axillentA
              axillentA
              axillent
              @BulldogLowell setting watchdog to timeout after 8 seconds can support you in most situations without a need to dig into library source
              But you will be not guaranteed from all cases, it is possible that your arduino will be reset in normal situation where reset is not needed. But actually the same will happen if you will attach external watchdog as you state in you first post here
              sense and drive
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                I have a lot more flexibility with hardware, i believe.... there is an (8s) limit on the Atmel watchdog, no?
                axillentA Dan S.D 2 Replies Last reply
                  axillentA
                  axillentA
                  axillent
                  it is a limit of atmega328, other MCU can differ
                  but it is still possible to organize longer period by activating WDT ISR handler
                  this will be not the best practice but it will work
                  the best practice is to set very short timeout and to put wdt_reset() at all required points
                  sense and drive
                    What happens with watchdog while sleeping?
                      axillentA
                      axillentA
                      axillent
                      it depends on what do you want :)
                      if i'm not mistaken LowPower library you are using is using watchdog while sleeping
                      actually watchdog is only one timer running while POWER_DOWN
                      it is a common way to wake up because of watchdog event from the deepest sleep if you need to wake up by time, not by external event
                      sense and drive
                      • G
                        G
                        Gambituk
                        Hi, i would be interested in any more updates along this line. In my case my gateway is mostly stable as far as i can tell. several weeks without issues. My problem is that most of my nodes seem to lockup, so i would be totally interested in making them more robust either by software or if necessary with external chip as overlord watchdog
                          Dan S.D
                          Dan S.D
                          Dan S.
                          @BulldogLowell Any progress on this? My Ethernet gateway is quite reliable after solving power supply issues and implementing soft spi. But about once a month it stops and rebooting it makes it operative again. The failure seems to be periodic--once a month. May be a clue there--something reaching a limit? At any rate, any failure rate where I can't start it up without physically rebooting is too much.
                            maha
                            millis() has a rollover after approximately 50 days. Could that be something?
                            Dan S.D 1 Reply Last reply
                            • M maha
                              Dan S.D
                              Dan S.D
                              Dan S.
                              @maha Don't know. But your question did trigger the thought of using milils() to periodically trigger a reboot. Rather than check for a lockup with a watchdog routine I may try just rebooting it at a shorter time interval, e.g., every 2 weeks, than I have experienced the lockups using millis to measure the interval.
                              • Dan S.D
                                Dan S.D
                                Dan S.
                                Added a 8 sec Watchdog to my ethernet gateway and it's up and running now. Time will tell if it cures the occaisional lockups by automatically resetting. Will report back the results
                                  FYI: Watchdog reset is automatically called by process() nowadays in the development-branch.
                                  https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.cpp#L509
                                    Dan S.D
                                    Dan S.D
                                    Dan S.
                                    @hek I assume this is with the intent to allow a watchdog reset on sensor sketches in the future, but does not apply to the Ethernet gateway sketch?
                                      Dan S.D
                                      Dan S.D
                                      Dan S.
                                      @hek Please disregard my prior message. I looked further and see that the watchdog reset is part of the sensor wait routine and is in the current 1.4 version of MySensors.cpp
                                      • Dan S.D
                                        Dan S.D
                                        Dan S.
                                        It's been over 6 weeks since I added an 8 sec watchdog to my Ethernet gateway (to Vera) and have not had to reboot the gateway since then. Before adding the watchdog, the most it ever lasted before without rebooting was 4 weeks. So for now I have to assume that the watchdog is doing its job and automatically restoring the gateway. If so, then it is providing the gateway dependability that I wanted. Time will tell.
                                        • Dan S.D Dan S.
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          @Dan-S.
                                          great news, thanks for the update!
                                          can you share how you set it up? Are you using the stock gateway code?
