  3. ESP8266 Gateway (RFM69) Soft WDT reset every 5 - 10 min
14 Posts 5 Posters 1.4k Views 5 Watching
  • OumuamuaO
    OumuamuaO
    Oumuamua
    Hi Stefan,
    I'm also facing a similar problem (here), but starting with the second sensor added (not 60 as you).
    Do you know what is the reset cause? Mine is rst cause:4, boot mode:(3,7)
    In my case I need to switch off all sensors and turn them on only after rebooting the gateway.
    Will follow this post to check if there is any help for me.
      Stefan_NE
      I don't have a solution yet. It's almost impossible to shut down all my sensors. What I can say for sure is that there is a lot of traffic on the gateway.
      My solution is to redesign the entire environment. I have built a gateway with a Raspberry Pi 3B and RFM69 (new driver) and I am moving the most important devices first. I adapted the code (new rfm69 driver and less traffic).
      During the last days I have done traffic test with very high load on the Pi, very stable.
      The first 15 devices are running on the new gateway today. So far very good.
      On the old gateway the error is still present without the 15 devices.
      I am curious with which device is disconnected from the ESP gateway the error will go.
      Have a nice Day Stefan
      TRS-80T 1 Reply Last reply
        Sasquatch
        wrote on last edited by Sasquatch
        Try adding 220-470uf capacitor across radio supply pins, had similar problem with my gateway(NodeMCU) and RFM69HW during node OTA firmware updates.
        You know you can map serial port to VM, right?
        OumuamuaO 1 Reply Last reply
        • S Sasquatch
          OumuamuaO
          OumuamuaO
          Oumuamua
          @Sasquatch
          Hi Sasquatch,
          I'm new to mysensors and arduino and not an electrical engineer. Could you the scheme on how to add the capacitor? I really appreciate any "for dummy" explanation.
            Sasquatch
            https://www.mysensors.org/uploads/57c1a2411730a6c715b6b1b0/image/RFM69.png
            Solder it between GND and 3v3 pins.
            sorry, can't find a picture on internet and can't take picture of mine atm.
            • S Sasquatch
              OumuamuaO
              OumuamuaO
              Oumuamua
              @Sasquatch
              Thanks! It helped!!
              • OumuamuaO Oumuamua
                @Sasquatch
                Hi Sasquatch,
                TRS-80T
                TRS-80T
                TRS-80
                @Oumuamua said in ESP8266 Gateway (RFM69) Soft WDT reset every 5 - 10 min:
                We got into pretty good discussion of capacitors in my evidence based testing thread. I had read a lot that one larger + one smaller cap actually works the best. I am no EE either, so I tested several different combinations, the results you can see there along with a very big close up picture I took of how to solder the caps onto the radio.
                • S Stefan_NE
                  TRS-80T
                  TRS-80T
                  TRS-80
                  @Stefan_NE said in ESP8266 Gateway (RFM69) Soft WDT reset every 5 - 10 min:
                  What I can say for sure is that there is a lot of traffic on the gateway...
                  It sounds to me like you are on the right track. Proceeding in an organized methodical fashion. I am sure you will get it sorted out this way. And thanks for sharing your progress in the meantime, it will likely help others later.
                  I am not even up to that many nodes myself yet either, so I'd be interested in anyone's feedback who is, because I do plan to have that many nodes (or more) "some day."
                  So I got wondering if there have already been any forum threads about large numbers of nodes, and I found this one where some "back of envelope" calculations stated that some thousands (actually 10s of thousands) of nodes were (at least theoretically) possible...
                    Stefan_NE
                    I have installed 2 new Gateway with a Raspberry Pi and RFM69. During the last days I have moved one device after the other to the new gateways. Of course I have adapted all devices with a new firmware. The two old ESP8266 gateways were in monitoring,. What I noticed was that the less devices and less traffic, the less reboots could be detected, regardless of the Mysensor version started at 1.5 to 2.32. . The new RPi gateways are running very cool so far. The best thing is that you can monitor everything, traffic to the LAN and traffic to the RFM69.
                    Have a nice day
                    Stefan
                      Sasquatch
                      just a thought, since resets are happening under heavy trafffic:
                      What is your serial speed? 9600 could lead to buffer overflows under heavy traffic
