  3. Suspending the node
Suspending the node
7 Posts 2 Posters 948 Views 2 Watching
  • RobertR
    RobertR
    Robert
    I have 10 DHT sensors. From time to time a few lost suggestion, each time the same. In one of them I uploaded a watchdog, it worked a bit and also crashed. The one with the watchdog causes errors. Compilation is going well.
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN 2
    // Set RS485 baud rate to use
    // Enable this if RS485 is connected to a hardware serial port
    //#define MY_RS485_HWSERIAL Serial1
    #define MY_NODE_ID 2
    #include <avr/wdt.h>
    #define DHT_DATA_PIN 3
    #define CHILD_ID_HUM 1
    #define CHILD_ID_TEMP 2
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      wdt_enable(WDTO_2S);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      wdt_reset();
    skywatchS 1 Reply Last reply
    • RobertR Robert
      #define MY_RS485
      DHT dht;
      float lastTemp;
      float lastHum;
          if (!metric) {
            lastHum = humidity;
        wdt_reset();
      skywatchS
      skywatchS
      skywatch
      @Robert In order to use the watchdog you need the correct bootloader, which bootloader are you using?
      Also, if your sensors are connected with dupont connectors then these can work loose over time due to thermal expansion and contraction. Dupont connectors are really for quick development and not as good as a soldered joint for deployment. At a push you could try hot glue to hold them in place.
      • RobertR
        RobertR
        Robert
        Joints should be ok, use thermal glue. I don't know what the bootloader is. This is the arduino pro mini. Atmega 328P 5v 16mhz processor. AVrisp mkII programmer
        • RobertR Robert
          skywatchS
          skywatchS
          skywatch
          @Robert You need to know what bootloader you are using and if it supports the watchdog timer function. The default ones from China generally don't support watchdog , so you will need to burn a bootloader that supports watchdog.
          • RobertR
            RobertR
            Robert
            Which bootloader should I use? Is it necessary in my case? Does users mysensors change the bootloader?
            skywatchS 2 Replies Last reply
            • RobertR Robert
              skywatchS
              skywatchS
              skywatch
              • RobertR Robert
                skywatchS
                skywatchS
                skywatch
                @Robert said in Suspending the node:
                Only you can decide the best one for what you want.
                I would say yes it is if you want WDT to operate.
                That depends on the need case for each individual requirement. Some do, some don't. The ones that do have a specific reason for doing so, like fota or wdt.
                Mysensors has its' own bootloader and I believe that it supports WDT. Optiboot is another popular one but I don't personally know if it supports WDT.
                12.5k
