1.1k Posts 105 Posters 792.8k Views 98 Watching
  • kalinaK
    kalinaK
    kalina
    #1029
    Oh yes, I forgot to share photos of my new project - Multinetwork Mysensors Gateway. The main idea of this gateway is that it can at the same time serve up to four different networks (Lora - RFM9X, 2.4 GHz - NRF24 and ISM band RFM69). These networks can be assembled in separate modules and each user can build own set of modules. The incoming stream will be connected via Ethernet on various ports, for example, the gate will have the IP address 192.168.1.128, and each subnet will be served on ports 5003 - the first subnet, 5004 - the second, and so on ...
    monteM 1 Reply Last reply
    • kalinaK kalina
      monteM
      monteM
      monte
      @kalina looking great! Is it opensource?
      kalinaK 1 Reply Last reply
      • monteM monte
        kalinaK
        kalinaK
        kalina
        #1031
        @monte Not certainly in that way. In this project, everything is open source with the exception of the board with an ethernet (based on STM32). The ethernet board was developed by my partners and they are not ready to share it yet. But I hope I can persuade them to do it :-)1.jpg
        NeverDieN monteM 2 Replies Last reply
        • kalinaK kalina
          @kalina I like how it both consolidates and reduces wall-wart clutter all in one stroke. :-)
          I don't see any antennas though. Where do they go? And does having multiple radios packed close together like that create any noteworthy EMI? I knew a guy who had set up an RFM69 hat on his Raspberry Pi but later found that the raspberry Pi produced a lot of RF noise/EMI that reduced the effective range of his gateway. I don't know whether or not that might happen in your case, but I thought I'd mention it to help with your troubleshooting in the event you notice any unexpected range reduction.
          • kalinaK kalina
            monteM
            monteM
            monte
            @kalina I see. I have the same STM32 chip and was going to use it in one of my next projects, so I asked to get some inspiration :)
              kalinaK
              kalinaK
              kalina
              #1034
              @NeverDie EMI is a big topic. I think there will be no problems. I am going to do some tests of communication
              quality for various modules and antennas. As for the antennas, I am going to fixed them to the body through the holes, but I have not yet decided on the location. As for connection antenna to the module you can see the on photo ...
              • berkseoB
                berkseoB
                berkseo
                #1035
                Hello everyone. I want to show you my new device, battery powered air quality sensor. The device also has light, temperature, humidity, and atmospheric pressure sensors. I am currently testing the software.
                NeverDieN berkseoB 2 Replies Last reply
                • berkseoB berkseo
                  #1036
                  @berkseo I'm curious: which air quality sensor did you opt to build into your device, and what about it did you prefer over the other available air quality sensors that you might have picked, but didn't? Two or three years ago I looked into a few different sensors, but they looked bigger that what you've settled on and their capabilities were pretty narrow. Hopefully the sensor offerings have gotten better since then.
                  berkseoB 1 Reply Last reply
                    berkseoB
                    berkseoB
                    berkseo
                    @NeverDie sgp40 sensor is used, I also test the bme680, but the results are worse there.
                    • berkseoB berkseo
                      berkseoB
                      berkseoB
                      berkseo
                      • H
                        H
                        hlehoux
                        wrote on last edited by hlehoux
                        #1039
                        My first RFM69 Battery sensor: an ultrasonic sonar to measure the level of my fuel tank (don't laugh, winters can be cold in Burgundy :-) )
                        Many thanks to @sundberg84 and @mfalkvidd for advice to the Newbie i am and to @Gerator for the RFM69 gateway
                        • H hlehoux
                          Nice work @hlehoux!
                          Electronics and fuel sounds like a scary combination to me 😨
                          H 1 Reply Last reply
                            Nice work @hlehoux!
                            H
                            H
                            hlehoux
                            #1041
                            @mfalkvidd You're right: For production i'm going to build isolation for the sensor not to be in contact
                            Anyway: The flash point of domestic fuel oil is 55 ° C, which means that fuel oil cannot ignite below this temperature. In addition, in its liquid form, fuel oil is non-flammable at room temperature.
                            • K
                              K
                              KooLru
                              • Temperature and humidity sensor AHT-10
                              • NRF52823 module
                              • Power board CR2477
                                Connected via MYSX connectors
                                Firmware based on NodeManager library
                              • franz-unixF
                                franz-unixF
                                franz-unix
                                Hi guys,
                                my last creation: the d-diot hub v.3.0
                                20210123_205004.jpg 20210124_120658.jpg 20210124_120759.jpg 20210124_120909.jpg 20210214_100204.jpg 20210214_100225.jpg 20210214_100243.jpg 20210123_204437_HDR.jpg 20210123_204535.jpg
                                The hub A (wood) is a dual MySensors gateway (RFM69 and NRF24) based on two ESP8266 modules and a BLE gateway + RGB controller thanks to an ESP32 module and ESPHome firmware.
                                The hub B (grey and red) is an IR gateway and RC 433 Mhz gateway based on ESP32 modules with an ESPHome firmware. The hub B has also an integrated step-up and step-down voltage regulator based on Arduino Nano.
                                To allow the maximum flexibility in placement inside the house, each module can be build as a stand-alone piece of hardware or combined in a single device (see pictures).
                                The hub is meant to be used with Home Assistant, the case is 3d printable and as usual, if someone is interested, there is a dedicated wiki page with all the details and the build instructions.
                                • K
                                  K
                                  KooLru
                                  I2S/IIC to MYSX converter
                                  Configurable via jumper matrix
                                  • K KooLru
                                    sundberg84S
                                    sundberg84S
                                    @KooLru - very clever sollution for the lines.
                                    • berkseoB berkseo
                                      My new project of a temperature and humidity sensor with an electronic ink display 1.02 Inch ( GDEW0102T4 ), very low power consumption, very small device.
                                      https://youtu.be/2zTEHTAr7lk
                                      nagelcN
                                      nagelcN
                                      nagelc
                                      wrote on last edited by nagelc
                                      #1046
                                      @berkseo
                                      Hey. Our own berkseo is on Hackaday. Congrats!
                                      https://hackaday.com/2021/03/11/nrf52-weather-station-gives-forecast-with-style/
                                      • nagelcN nagelc
                                        @berkseo
                                        berkseoB
                                        berkseoB
                                        berkseo
                                        @nagelc
                                        Wow, this is unexpected.
                                        • nagelcN
                                          nagelcN
                                          nagelc
                                          I made a simple board to use as a CR2032 battery simulator. It is actually two identical pcb's back to back. I added pins for applying power and another set for measuring current. Now I need a better ammeter. The uA scale works well when sleeping, but the mA scale doesn't seem to pick up the awake current.
                                          electrikE 1 Reply Last reply
