1.1k Posts 105 Posters 798.2k Views 98 Watching
    @kalina I like how it both consolidates and reduces wall-wart clutter all in one stroke. :-)
    I don't see any antennas though. Where do they go? And does having multiple radios packed close together like that create any noteworthy EMI? I knew a guy who had set up an RFM69 hat on his Raspberry Pi but later found that the raspberry Pi produced a lot of RF noise/EMI that reduced the effective range of his gateway. I don't know whether or not that might happen in your case, but I thought I'd mention it to help with your troubleshooting in the event you notice any unexpected range reduction.
    kalinaK
    kalinaK
    kalina
    #1034
    @NeverDie EMI is a big topic. I think there will be no problems. I am going to do some tests of communication
    quality for various modules and antennas. As for the antennas, I am going to fixed them to the body through the holes, but I have not yet decided on the location. As for connection antenna to the module you can see the on photo ...
    • berkseoB
      berkseoB
      berkseo
      #1035
      Hello everyone. I want to show you my new device, battery powered air quality sensor. The device also has light, temperature, humidity, and atmospheric pressure sensors. I am currently testing the software.
      NeverDieN berkseoB 2 Replies Last reply
      • berkseoB berkseo
        #1036
        @berkseo I'm curious: which air quality sensor did you opt to build into your device, and what about it did you prefer over the other available air quality sensors that you might have picked, but didn't? Two or three years ago I looked into a few different sensors, but they looked bigger that what you've settled on and their capabilities were pretty narrow. Hopefully the sensor offerings have gotten better since then.
        berkseoB 1 Reply Last reply
          berkseoB
          berkseoB
          berkseo
          @NeverDie sgp40 sensor is used, I also test the bme680, but the results are worse there.
          • berkseoB berkseo
            berkseoB
            berkseoB
            berkseo
            • H
              H
              hlehoux
              wrote on last edited by hlehoux
              #1039
              My first RFM69 Battery sensor: an ultrasonic sonar to measure the level of my fuel tank (don't laugh, winters can be cold in Burgundy :-) )
              Many thanks to @sundberg84 and @mfalkvidd for advice to the Newbie i am and to @Gerator for the RFM69 gateway
              • H hlehoux
                Nice work @hlehoux!
                Electronics and fuel sounds like a scary combination to me 😨
                H 1 Reply Last reply
                  Nice work @hlehoux!
                  H
                  H
                  hlehoux
                  #1041
                  @mfalkvidd You're right: For production i'm going to build isolation for the sensor not to be in contact
                  Anyway: The flash point of domestic fuel oil is 55 ° C, which means that fuel oil cannot ignite below this temperature. In addition, in its liquid form, fuel oil is non-flammable at room temperature.
                  • K
                    K
                    KooLru
                    • Temperature and humidity sensor AHT-10
                    • NRF52823 module
                    • Power board CR2477
                      Connected via MYSX connectors
                      Firmware based on NodeManager library
                    • franz-unixF
                      franz-unixF
                      franz-unix
                      Hi guys,
                      my last creation: the d-diot hub v.3.0
                      20210123_205004.jpg 20210124_120658.jpg 20210124_120759.jpg 20210124_120909.jpg 20210214_100204.jpg 20210214_100225.jpg 20210214_100243.jpg 20210123_204437_HDR.jpg 20210123_204535.jpg
                      The hub A (wood) is a dual MySensors gateway (RFM69 and NRF24) based on two ESP8266 modules and a BLE gateway + RGB controller thanks to an ESP32 module and ESPHome firmware.
                      The hub B (grey and red) is an IR gateway and RC 433 Mhz gateway based on ESP32 modules with an ESPHome firmware. The hub B has also an integrated step-up and step-down voltage regulator based on Arduino Nano.
                      To allow the maximum flexibility in placement inside the house, each module can be build as a stand-alone piece of hardware or combined in a single device (see pictures).
                      The hub is meant to be used with Home Assistant, the case is 3d printable and as usual, if someone is interested, there is a dedicated wiki page with all the details and the build instructions.
                      • K
                        K
                        KooLru
                        I2S/IIC to MYSX converter
                        Configurable via jumper matrix
                        • K KooLru
                          sundberg84S
                          sundberg84S
                          @KooLru - very clever sollution for the lines.
                          • berkseoB berkseo
                            My new project of a temperature and humidity sensor with an electronic ink display 1.02 Inch ( GDEW0102T4 ), very low power consumption, very small device.
                            https://youtu.be/2zTEHTAr7lk
                            nagelcN
                            nagelcN
                            nagelc
                            wrote on last edited by nagelc
                            #1046
                            @berkseo
                            Hey. Our own berkseo is on Hackaday. Congrats!
                            https://hackaday.com/2021/03/11/nrf52-weather-station-gives-forecast-with-style/
                            • nagelcN nagelc
                              @berkseo
                              berkseoB
                              berkseoB
                              berkseo
                              @nagelc
                              Wow, this is unexpected.
                              • nagelcN
                                nagelcN
                                nagelc
                                I made a simple board to use as a CR2032 battery simulator. It is actually two identical pcb's back to back. I added pins for applying power and another set for measuring current. Now I need a better ammeter. The uA scale works well when sleeping, but the mA scale doesn't seem to pick up the awake current.
                                electrikE 1 Reply Last reply
                                • nagelcN nagelc
                                  electrikE
                                  electrikE
                                  electrik
                                  @nagelc Nice!
                                  What is the PCB you are measuring on? I'm actually looking for a NRF5 board to use with a coin cell.
                                  • nagelcN nagelc
                                    I am testing a node with a DigiPyro, PYD 1598 motion detector. It is advertised to be low power and runs from 1.8 to 3.6 volts, so should run well with a coin cell. They have to be programmed with several options and I have not found a lot of documentation. I went with what seemed like the most sensitive choices and it seems to work so far. More research needed . ...
                                    https://www.excelitas.com/product/pyd-1588-pyd-1598-low-power-digipyros
                                    I bought a couple of these from DigiKey for around $4 each. Now they are more than $12 each and there is no stock. So, these may not be as good a choice as they seemed at first. We'll see . ...
                                    nagelcN
                                    nagelcN
                                    nagelc
                                    @electrik
                                    It's actually at this link posted earlier in the thread: What did you build today (Pictures) ?:
                                    I mostly use it with BME280 modules for temperature and humidity, but I have tried some other I2C modules in it.
                                    I'm still experimenting with the motion detector. That will probably get it's own board at some point. It doesn't really fit the enclosure I designed this board for.
                                    • berkseoB
                                      berkseoB
                                      berkseo
                                      #1051
                                      I think this open source project is finished. This is a small air quality sensor. Quite a useful thing turned out for our not simple time.
                                      https://github.com/smartboxchannel/EFEKTA-EINK213-AIR-QUALITY-SENSOR-NRF52840-V2-ED3
                                      • K
                                        K
                                        KevinT
                                        Finished my Garage Door Node.
                                        It has open/close magnetic reed switch sensors, a DS18B20 temperature sensor, a PIR motion sensor and a bjt to trigger the door to open/close/stop.
                                        K 1 Reply Last reply
                                        • K KevinT
                                          K
                                          K
                                          KevinT
                                          nagelcN 1 Reply Last reply
