1.1k Posts 105 Posters 792.8k Views 98 Watching
  • kalinaK kalina
    @monte Not certainly in that way. In this project, everything is open source with the exception of the board with an ethernet (based on STM32). The ethernet board was developed by my partners and they are not ready to share it yet. But I hope I can persuade them to do it :-)1.jpg
    monteM
    monteM
    monte
    @kalina I see. I have the same STM32 chip and was going to use it in one of my next projects, so I asked to get some inspiration :)
      @kalina I like how it both consolidates and reduces wall-wart clutter all in one stroke. :-)
      I don't see any antennas though. Where do they go? And does having multiple radios packed close together like that create any noteworthy EMI? I knew a guy who had set up an RFM69 hat on his Raspberry Pi but later found that the raspberry Pi produced a lot of RF noise/EMI that reduced the effective range of his gateway. I don't know whether or not that might happen in your case, but I thought I'd mention it to help with your troubleshooting in the event you notice any unexpected range reduction.
      kalinaK
      kalinaK
      kalina
      #1034
      @NeverDie EMI is a big topic. I think there will be no problems. I am going to do some tests of communication
      quality for various modules and antennas. As for the antennas, I am going to fixed them to the body through the holes, but I have not yet decided on the location. As for connection antenna to the module you can see the on photo ...
      • berkseoB
        berkseoB
        berkseo
        #1035
        Hello everyone. I want to show you my new device, battery powered air quality sensor. The device also has light, temperature, humidity, and atmospheric pressure sensors. I am currently testing the software.
        NeverDieN berkseoB 2 Replies Last reply
        • berkseoB berkseo
          #1036
          @berkseo I'm curious: which air quality sensor did you opt to build into your device, and what about it did you prefer over the other available air quality sensors that you might have picked, but didn't? Two or three years ago I looked into a few different sensors, but they looked bigger that what you've settled on and their capabilities were pretty narrow. Hopefully the sensor offerings have gotten better since then.
          berkseoB 1 Reply Last reply
            berkseoB
            berkseoB
            berkseo
            @NeverDie sgp40 sensor is used, I also test the bme680, but the results are worse there.
            • berkseoB berkseo
              berkseoB
              berkseoB
              berkseo
              • H
                H
                hlehoux
                wrote on last edited by hlehoux
                #1039
                My first RFM69 Battery sensor: an ultrasonic sonar to measure the level of my fuel tank (don't laugh, winters can be cold in Burgundy :-) )
                Many thanks to @sundberg84 and @mfalkvidd for advice to the Newbie i am and to @Gerator for the RFM69 gateway
                • H hlehoux
                  Nice work @hlehoux!
                  Electronics and fuel sounds like a scary combination to me 😨
                  H 1 Reply Last reply
                    Nice work @hlehoux!
                    H
                    H
                    hlehoux
                    #1041
                    @mfalkvidd You're right: For production i'm going to build isolation for the sensor not to be in contact
                    Anyway: The flash point of domestic fuel oil is 55 ° C, which means that fuel oil cannot ignite below this temperature. In addition, in its liquid form, fuel oil is non-flammable at room temperature.
                    • K
                      K
                      KooLru
                      • Temperature and humidity sensor AHT-10
                      • NRF52823 module
                      • Power board CR2477
                        Connected via MYSX connectors
                        Firmware based on NodeManager library
                      • franz-unixF
                        franz-unixF
                        franz-unix
                        Hi guys,
                        my last creation: the d-diot hub v.3.0
                        20210123_205004.jpg 20210124_120658.jpg 20210124_120759.jpg 20210124_120909.jpg 20210214_100204.jpg 20210214_100225.jpg 20210214_100243.jpg 20210123_204437_HDR.jpg 20210123_204535.jpg
                        The hub A (wood) is a dual MySensors gateway (RFM69 and NRF24) based on two ESP8266 modules and a BLE gateway + RGB controller thanks to an ESP32 module and ESPHome firmware.
                        The hub B (grey and red) is an IR gateway and RC 433 Mhz gateway based on ESP32 modules with an ESPHome firmware. The hub B has also an integrated step-up and step-down voltage regulator based on Arduino Nano.
                        To allow the maximum flexibility in placement inside the house, each module can be build as a stand-alone piece of hardware or combined in a single device (see pictures).
                        The hub is meant to be used with Home Assistant, the case is 3d printable and as usual, if someone is interested, there is a dedicated wiki page with all the details and the build instructions.
                        • K
                          K
                          KooLru
                          I2S/IIC to MYSX converter
                          Configurable via jumper matrix
                          • K KooLru
                            sundberg84S
                            sundberg84S
                            @KooLru - very clever sollution for the lines.
                            • berkseoB berkseo
                              My new project of a temperature and humidity sensor with an electronic ink display 1.02 Inch ( GDEW0102T4 ), very low power consumption, very small device.
                              https://youtu.be/2zTEHTAr7lk
                              nagelcN
                              nagelcN
                              nagelc
                              wrote on last edited by nagelc
                              #1046
                              @berkseo
                              Hey. Our own berkseo is on Hackaday. Congrats!
                              https://hackaday.com/2021/03/11/nrf52-weather-station-gives-forecast-with-style/
                              • nagelcN nagelc
                                @berkseo
                                berkseoB
                                berkseoB
                                berkseo
                                @nagelc
                                Wow, this is unexpected.
                                • nagelcN
                                  nagelcN
                                  nagelc
                                  I made a simple board to use as a CR2032 battery simulator. It is actually two identical pcb's back to back. I added pins for applying power and another set for measuring current. Now I need a better ammeter. The uA scale works well when sleeping, but the mA scale doesn't seem to pick up the awake current.
                                  electrikE 1 Reply Last reply
                                  • nagelcN nagelc
                                    electrikE
                                    electrikE
                                    electrik
                                    @nagelc Nice!
                                    What is the PCB you are measuring on? I'm actually looking for a NRF5 board to use with a coin cell.
                                    • nagelcN nagelc
                                      I am testing a node with a DigiPyro, PYD 1598 motion detector. It is advertised to be low power and runs from 1.8 to 3.6 volts, so should run well with a coin cell. They have to be programmed with several options and I have not found a lot of documentation. I went with what seemed like the most sensitive choices and it seems to work so far. More research needed . ...
                                      https://www.excelitas.com/product/pyd-1588-pyd-1598-low-power-digipyros
                                      I bought a couple of these from DigiKey for around $4 each. Now they are more than $12 each and there is no stock. So, these may not be as good a choice as they seemed at first. We'll see . ...
                                      nagelcN
                                      nagelcN
                                      nagelc
                                      @electrik
                                      It's actually at this link posted earlier in the thread: What did you build today (Pictures) ?:
                                      I mostly use it with BME280 modules for temperature and humidity, but I have tried some other I2C modules in it.
                                      I'm still experimenting with the motion detector. That will probably get it's own board at some point. It doesn't really fit the enclosure I designed this board for.
                                      • berkseoB
                                        berkseoB
                                        berkseo
                                        #1051
                                        I think this open source project is finished. This is a small air quality sensor. Quite a useful thing turned out for our not simple time.
                                        https://github.com/smartboxchannel/EFEKTA-EINK213-AIR-QUALITY-SENSOR-NRF52840-V2-ED3
                                        • K
                                          K
                                          KevinT
                                          Finished my Garage Door Node.
                                          It has open/close magnetic reed switch sensors, a DS18B20 temperature sensor, a PIR motion sensor and a bjt to trigger the door to open/close/stop.
                                          K 1 Reply Last reply
