  3. Commenting and chat seem to be broken
22 Posts 6 Posters 2.8k Views 6 Watching
    Hmmm.. Firefox seems to work. I'm running the most current version of Chrome, so I guess some problem with it. I'll wipe this computer in case it's a virus....
      @NeverDie kill it with fire 😁
      • TheoLT
        TheoLT
        TheoL
          @mfalkvidd said in Commenting and chat seem to be broken:
          I nuked it from orbit. It's the only way to be sure.... :wink:
          Reporting back: Rechecked just now, though, after wiping and re-installing Windows 10 fresh, and the same problem persists when using Chrome and trying to comment on lcduino. Mysterious! At least Firefox is a workaround.
          Nca78N 1 Reply Last reply
            @NeverDie said in Commenting and chat seem to be broken:
            Do you really do that just for a problem on one website with one browser ? That's a bit extreme :D
            • Nca78N Nca78
              @Nca78 said in Commenting and chat seem to be broken:
              Yup. I really did, but only because it looked like something a virus might do: force some bogus login to steel a password. Not that a mysensors password has monetary value, but an indiscriminate virus wouldn't know that.
                Hmm.. something seems to be broken (for me as well). The "Login" button should not be present if you are logged in to the forum. Clicking it seems to generate a js-error.
                This all might be triggered by some new cross-site security feature of chrome and it could take some time for me to figure out a solution.
                • mfalkviddM
                  Not sure if it is related, but https://www.mysensors.org/build/raspberry is pretty broken. Code is not formatted as code, but some of the regular text is formatted as code instead. Images are missing. I'll take a look later.
                  This screen shot was taken with Safari on ipad.
                  hekH 1 Reply Last reply
                  • TheoLT
                    TheoLT
                    TheoL
                    Not sure if it helps. But chrome changed things for CORS. If the CURS headers aren't set correctly you can not use a rest api anymore.
                      wrote on last edited by hek
                      @mfalkvidd
                      I fixed the raspberry article, the updated markup-parser seems a bit more picky about newlines before/after headers and code-blocks for some reason.
                      Edit: Correction, the bare <br> html-elements all over the article needs to be separated with newlines
                      • BearWithBeardB
                        BearWithBeardB
                        BearWithBeard
                        wrote on last edited by BearWithBeard
                        Hmm, I also have an issue, although it's likely unrelated. Every few minutes, there are three or four consecutive polling requests - some of which are also quite slow (>500ms) - by the sockets.io script that are all responded with a 405 (method not allowed). Right after that, it switches protocol from HTTP2 to HTTP1.1 and sends another few requests, which now are all responded with a 200 (OK).
                        It doesn't break anything as far as I can tell. It shows a "Looks like your connection was lost" modal in the bottom right corner and the forum's navigation bar shifts to the side (and sometime appears as if I'm logged out). After a few seconds, it's all back to normal. It just happens very frequently since a few weeks or so.
                        I'm using Firefox (86), but I have seen it happen in Chromium-based browsers as well.
                          Yeah, noticed that as well an hour ago. It was actually caused by an exception/crash of the forum. I think I pinpointed the problem and fixed it. Need to keep an eye on the logs over the day.
                            No forum crashes/restart for 2 hours. Seems fixed.
                            mfalkviddM BearWithBeardB 2 Replies Last reply
                              Great work @hek
                                Fixed the rate limit when fetching data from github (now 5000 requestst vs 60 per day). Should fix the fetch problem we saw on the main site @mfalkvidd.
                                  BearWithBeardB
                                  BearWithBeardB
                                  BearWithBeard
                                  @hek Can confirm. Didn't get any 405 responses nor pesky modals over the last few hours. Thank you!
                                  • BearWithBeardB BearWithBeard
                                    @BearWithBeard
                                    Good!
                                    Still investigating the comment problems on openhardware.io. Might need to do manual restarts of the forum to test things later on.
                                      Ok, could not find the root cause for why the embedded forum thread on openhardware.io couldn't detect if user has a valid session/is logged in to the forum.
                                      Did a workaround by adding a "Comment" button which redirect user to the thread on the forum.
                                      12.5k
