  3. Feather m0 (SAMD) sleep and interrupt
6 Posts 2 Posters 848 Views 3 Watching
  • A Offline
    A Offline
    Alpoy
    I've been trying everything I know of to get a feather m0 wake up by interrupt after deep sleep but I can't get it working with the mysensors lib.
    if I remove all mysensors related code sleep and wakeup works just fine :unamused:
    Any help or tip appreciated!
    Here's the code:
    #define MY_RADIO_RFM69
    #define TIME_TO_SLEEP 299
    #define Battery_HIGH 4.2
    #define Battery_LOW 3.2
    #define MY_IS_RFM69HW
    #define MY_RFM69_FREQUENCY RFM69_433MHZ
    #define MY_RFM69_NEW_DRIVER
    #define MY_DEFAULT_ERR_LED_PIN 13
    #define MY_RFM69_RST_PIN 4
    #define MY_RFM69_IRQ_PIN 3
    #define MY_RFM69_CS_PIN 8
    #define MY_NODE_ID 11
    #define MY_SIGNAL_REPORT_ENABLED
    #define MY_TRANSPORT_WAIT_READY_MS 15000
    #define REEDSWITCHPIN 6
    volatile bool SLEEP_FLAG = true; // Use sleeproutines or not
    bool debug = true;
    int bootCycles = 0;
    String wakeupReason = "none";
      pinMode(REEDSWITCHPIN, INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(REEDSWITCHPIN), EIC_ISR, FALLING);
      delay(100);
      sleepSetup();
      delay(5000);
      Serial.println("Going to sleep in 60 seconds...");
      delay(60000);
      if (debug) Serial.print("REEDSWITCHPIN State: ");
      if (debug) Serial.println(REEDSWITCHPIN);
      sleepRoutine();
    void sleepRoutine() {
        PORT->Group[g_APinDescription[LED_BUILTIN].ulPort].OUTCLR.reg = (uint32_t)(1<<g_APinDescription[LED_BUILTIN].ulPin); // set pin mode to low
        transportDisable(); // Disable rfm69
        __DSB();
        if (debug) Serial.println("ZzZ (WFI)");
        USBDevice.detach();
        delay(5000);
        __WFI();  // Sleep
        delay(1000);
        PORT->Group[g_APinDescription[LED_BUILTIN].ulPort].OUTTGL.reg = (uint32_t)(1<<g_APinDescription[LED_BUILTIN].ulPin);  // toggle output of built-in LED pin
        USBDevice.attach();
        delay(10000);
        if (debug) Serial.println("Out of ZzZ (WFI)");
        //transportReInitialise(); // Enable rfm69
        delay(100);
    void EIC_ISR(void) {
      //SLEEP_FLAG ^= true;  // toggle SLEEP_FLAG by XORing it against true
      wakeupReason = "INTERRUPT";
    void sleepSetup() {
      SYSCTRL->XOSC32K.reg |=  (SYSCTRL_XOSC32K_RUNSTDBY | SYSCTRL_XOSC32K_ONDEMAND); // set external 32k oscillator to run when idle or sleep mode is chosen
      REG_GCLK_CLKCTRL  |= GCLK_CLKCTRL_ID(GCM_EIC) |  // generic clock multiplexer id for the external interrupt controller
                           GCLK_CLKCTRL_GEN_GCLK1 |  // generic clock 1 which is xosc32k
                           GCLK_CLKCTRL_CLKEN;       // enable it
      while (GCLK->STATUS.bit.SYNCBUSY);              // write protected, wait for sync
      EIC->WAKEUP.reg |= EIC_WAKEUP_WAKEUPEN4;        // Set External Interrupt Controller to use channel 4 (pin 6)
      PM->SLEEP.reg |= PM_SLEEP_IDLE_CPU;  // Enable Idle0 mode - sleep CPU clock only
      SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;   // Enable Standby or "deep sleep" mode
      if (debug) Serial.println("EO sleepsetup");
    skywatchS 1 Reply Last reply
    • A Alpoy
      Here's the code:
      bool debug = true;
      int bootCycles = 0;
        delay(100);
        sleepSetup();
        delay(5000);
        delay(60000);
        sleepRoutine();
          __DSB();
          USBDevice.detach();
          delay(5000);
          __WFI();  // Sleep
          delay(1000);
          USBDevice.attach();
          delay(10000);
          delay(100);
      void sleepSetup() {
      skywatchS Offline
      skywatchS Offline
      skywatch
      @Alpoy void presentation() is empty - That could have an effect as the node is probably going round and round in circles trying to find the gateway. We will only know if you would post your debg output to see what is really going on here. ;)
      • A Offline
        A Offline
        Alpoy
        Indeed you're right :) I have removed more and more coded to eliminate any causes and reduced it all to the bare minimum, nothing changed. Anyways, I added this to the above code:
        #define CHILD_ID_MBXTRIP 52
        MyMessage MbxTrip(CHILD_ID_MBXTRIP, V_TRIPPED);
          sendSketchInfo("Mbx", "2.0");
          present(CHILD_ID_MBXTRIP, S_DOOR);
        And here's the debug output:
        11:54:19.036 -> 3084 TSM:FPAR:OK
        11:54:19.036 -> 3084 TSM:ID
        11:54:19.036 -> 3084 TSM:ID:OK
        11:54:19.036 -> 3084 TSM:UPL
        11:54:19.106 -> 3153 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        11:54:19.748 -> 3399 TSF:MSG:READ,0-0-11,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        11:54:19.748 -> 3399 TSF:MSG:PONG RECV,HP=1
        11:54:19.748 -> 3399 TSM:UPL:OK
        11:54:19.748 -> 3399 TSM:READY:ID=11,PAR=0,DIS=1
        11:54:19.748 -> 3475 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        11:54:19.748 -> 3714 TSF:MSG:READ,0-0-11,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        11:54:19.763 -> 3801 TSF:MSG:SEND,11-11-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
        11:54:20.561 -> 4370 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        11:54:22.599 -> 6437 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=11,pt=0,l=3,sg=0,ft=0,st=OK:Mbx
        11:54:22.972 -> 7006 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
        11:54:23.576 -> 7573 TSF:MSG:SEND,11-11-0-0,s=52,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
        11:54:23.576 -> 7574 MCO:REG:REQ
        11:54:24.110 -> 8142 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        11:54:24.538 -> 8383 TSF:MSG:READ,0-0-11,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        11:54:24.538 -> 8383 MCO:PIM:NODE REG=1
        11:54:24.538 -> 8383 MCO:BGN:STP
        11:54:24.538 -> EO sleepsetup
        11:54:24.538 -> 8484 MCO:BGN:INIT OK,TSP=1
        11:54:29.540 -> Going to sleep in 60 seconds...
        11:55:29.782 -> REEDSWITCHPIN State: 6
        11:55:29.782 -> 73484 TSF:TDI:TSL
        11:55:29.782 -> ZzZ (WFI)
        Now, when I make D6 (REEDSWITCHPIN) go LOW by conneting to GND nothing happens (doesn't wake up). But removing all mysensors code makes it work
        • A Offline
          A Offline
          Alpoy
          I've forgotten to add a digitalRead in the code above on the REEDSWITCHPIN State but it's "1".
          • A Offline
            A Offline
            Alpoy
            I may have solved/found a workaround for this, changing the interrupt to trigger on "LOW" instead of "FALLING" works for some reason :man-shrugging:
            • A Alpoy
              skywatchS Offline
              skywatchS Offline
              skywatch
              @Alpoy Well done! - That is interesting! - I never used a SAMD, but at least you have a way to make it work! Maybe I should try one someday....
