Where did everyone go?
There are many examples where of the shelf equipment downstairs make the cut. Of course if you only want temperature, or door switches, then zigbee devices are easier to implement. But if you want specialized Sensors, for measuring depth of water in a well, automate an existing garage door, automated the chicken coop, etc. Then mysensors is there to the rescue. Because you can't find any of the shelf non cloud solutions for that.
Perhaps we are behaving like old farts in the core ;) , but it's not intentionally. As mentioned a lot of times, we are using our spare time for the project, but the spare time is limited..
@tbowmo
take my statemant as it is: my opinion, mixed with my experiences here in the forum. its a rather cheap argument, that btw. is always the second one that comes arround in discussions, to remind at the brave coders, doing all that in their freetime.
I did not say anything harsh in that direction. never.
nevertheless I agree with @NeverDie pointing out the big pro's of mysensors. but there has to be some limitation: all that only applies, when you want to rebuild some of the non-cloud systems with ONE (maybe in ver 3.0 two) physical layer. and the next limitation is the number of gateways that come into account when you want to scale things up (in a distance AND number of gateways point of view).
and if we get into alternatives, like homie, the advantages of mysensors decrease to a single point: radio.referring to @NeverDie 's comment on the forum: its very hard to agree, because if you get your feature-request answered with "..pay somebody and you get what you want..." is not my definition of super-helpful, super-friendly
@tbowmo
My reaction was mainly towards the part of your statement "very snobbish and autocratic".
I haven't seen a response about paying someone to do a feature request (I've been away from the forum, so maybe I have missed something?).
You are absolutely free to create a PR for any feature requests. We might fight back a bit ;) but we need to have a good use case for the features that make it into the core of the project, otherwise we get the project filled with features that is only used by 1 or 2 persons..
as an "advanced hobbiest" i can tell why i am not getting really warm with mysensors.. I have a gateway and two nodes. One node (RFID garage opener) is working now but has range issues that i can not reach the gateway in the place i need it. And the other is a temperature sensor to play. So it works, but in real it does not, and to be honest the functionality is just nice to have for the moment :-D
In my case i got stuck in details with my configuration. The one night a month i have to code is not enough to solve it. (and of course i am not a professional)In the first view does mysensors look very cool. It wants to be an easy to use arduino library. A lot of examples for different gateways and nodes. Seems to be easy, "build = fun", no?
No, it is not that easy.
Mysensors is a framework. It hijacks already base functions of arduino.
As soon as you leave the application which is given in the example something does not work. And than you have to dick deep in the functionality of the mysensor framework and it is not easy to collect all necessary information in the documentation - at least for me. ;-)examples:
- Standard EEPROM functions are hijacked and can not be used as you are used to.
- pin configuration is done in the framework. If your other things connected to the MCU need also a special treatment (RST-pin) you need to find out how
- took me a while to release that there is a completely new version 2.0 of the radio-driver which worked for me instantly and i still no not know why the same code does not work with the standard version.. And you should use the newest development branch, not the released one ;-)
- the examples are not consistent to each other and are not even compatible in all cases...
So i think it is difficult to catch the user or it is not clear which kind of user is addressed.
The normal arduino dummy user can use it for the very simple examples. As soon he wants to combine function and the issues come, he will get stucked. And of course you get the same function in the meanwhile out of the box from a lot of cheap commercial products. Maybe you have different systems running but for that money you can buy every two years new things. And most people use a Controller which can handle directly the different systems and the configration there is easier. The Controllers made big improvements in user friendly configuration!
The advanced user is getting rare. And honestly the mysensor framework is so big with all that #define-cases for the different platforms and configurations that it takes a while to go through and find your adaption. This users have already made their own private libraries which will not work directly on the mysesnors framework. They switch to a different system or maybe start extract the things they need from mysensors.
And than i also have the impression that the help in the forum is "superficial". Not because the forum does not want to help.
The problems occur in the system and it is not easily clear why something does not work without taking the time and go thorugh everything.
It is open source and the documentation is suffering. The contributors have limited time and nobody can expect to get a 24/7 full support.
Everything okay, please do not misunderstand me, i really appreciate the work behind mysensors and i can only imagine complicated it is to keep such a system administrated.But to come back to the beginning it is the question which user should be addressed.
For the dummy user the documentation should be reduced but therefor everything should be consistent and straight. As the Controller software does, the work should focus on not technical functionality for easy configuration and usage.For the advanced user the documentation should go more in detail in general in one place and the code should focus on a layer structure to make it easier to operate on different systems or exchange modules/versions (maybe without the arduino framework as base or an approach as FreeRTOS).
And i am not sure if it is just me, but i could imagine it would help to make it easier to get part of the active community and bring improved code or new functions back in the mysensors-core.greeting from Germany
JensP.S.: i am sorry that i did not gender everything and always wrote "he" as "the user". Should of course also be a woman or girl or ...
I have said this before (I do not know where) but here it is again.
One of the reasons that MySensors didn't become as popular as other frameworks is because it somewhat matured before YouTubers were popular. Today, fewer people like to read, and most like to watch a YouTube video sitting on the toilet. The YouTubers not only provide step by step instructions, they do live streams and then there are Discord servers.I myself manage a small discord server on Home Automation and I see everyday newbies coming in and they are looking for a magical cheap solution which somehow works.
The barrier for entry into MySensors is big (involves a lot more wires, it does not seem sexy, no one talks about it on YouTube). On the other hand, everyone has an ISP given All-In-One router+AP+DHCP server and ESPs simply connect to them. Everyday Amazon, AliExpress etc are flooding the market with Wifi based products, so the time for feeling of gratification is very small. You buy, plug in, use the app and it worksThat said, we do have a dedicated MySensors channel on our discord server and I have been pushing (literally) people to try MySensors. Serious DIYers are still interested and I have successfully introduced 4 people to it, 2 have started using it.
I won't call the Mysensors a stagnant or dying breed but the concept of forums in my opinion is. Forums are still the most structured support system (I am not saying otherwise) but many people want instant answers, - they do not want to make the effort asking a good question. And across many forums which have been there for a few years, a common answer is "search before you ask".
This is my two cents on this topic
I am new here at MySensors. But I have my own ideas and do not want to adapt to a given middleware or networking. My reason to be here is the know-how presented by the many contributors of the forum.
I like the idea of Arduino very much. Having your basic routines running on nearly any hardware is really a nice thing. And after a first look into MySensors software, I also like it. Though I will not use it, because I have other ideas on microcontroller communication.
Do we really need to go with the "mainstream"? I think, the mainstream of software development has become a kind of "gaming" in the last years. It seems not to be necessary to know anything about programming, just be able to move your mouse and make some drags and drops her and there. Being an expert based on the knowledge of other people (companies).
As long as here are real experts talking about details of microcontrollers and their application, I will stay here.
I can only speak from my own experience, MySensors filled the gap at a time when commercial offerings still hadn't taken off, and as has been mentioned already, proprietary protocols and internet reliance put me off then and still does.
The combination of Domoticz and Mysensors suited my own needs of data acquisition rather than control, and although I've considered modifying and incorporating commercial devices since, they ultimately hit the brick wall of what CAN be done rather than what I need.
Hobbyist interest will come and go, but the forum inactivity is probably more testament to MySensors reliability for the vast majority who once flooded the place, and any new users find most of the answers they need here, so never pose a question
If it ain't broke don't fix it sort of idea - eg I had put off updating the IDE and MySensors until around a month back, a bit of a headache when I did, but it was soon sorted and back to silently doing what I need.Is there competition with the huge variety of plug and go devices in elegant cases now available ? I suggest not.
For those wanting off the shelf solutions with limits there is a product, but why would I want 5 individual devices in a single space rather than the one currently, or the mobile apps for each, or the app to save me walking 3m to switch the light on/off ?
Domoticz and MySensors are not flawless, neither the Pi3 nor the Arduino are the latest MCUs, but the combo is plenty capable of doing what I require, and for an old fart like me, plenty. ;) -
yes, that's the point: who is the user? And than focus on how to satisfy the user ;-)
I do not think that it is wrong or less valueable to set up an easy to use software that every dummy-youtuber can describe in a 5minutes clip.
Let me compare again with the development on the controller side.
When i started to search for home automation FHEM was very famous as one example. Such a strong system. It has been the first possibility to handle the different devices. If you have been able to get something work after hours of searching through the forum and editing various config files, it felt so cool, you are a hacker. Not every newbie could do...
Now you find approaches which are so easy to use via a webinterface. You get ready to use packages for different linux distributions and find most devices in auto configuration. That is contamporary and sexy.In the end even the experts take it. Why not, they can spend the time in hacking on other cool stuff.
And of course in the background are still the cool hacker working on the code or developing extensions ;-) but the user just uses it and does not be able to program.
Because so many user use it also more pro's work on it and because the youtuber can get 10 minutes fame even more user use it and so on and so.. -
I suppose the abundance of similar but non-identical mysensor solutions might cause people to wonder which one to build. I say that, having recently moved from Windows over to Linux, where there is a similar hyper-abundance of distros to sort through before picking one.
To me it is a lack of time. Still have tons of projects not finished. Right now really focused more on making the whole eco system Usable. As far as I can tell not one single HA system is usable for a mere mortal. It's either centered around a mobile phone, which is a no-no for me. It's not reliable in terms of battery can be low while you want to turn something on or off and the screen is too small for eco systems that cover an entire house. And when they're not centered around a mobile phone everything is glued together with scripts. It's all too complicated. I think I can make it more simple xd
@TheoL Yes,, it's strange how home automation can get so complicated when it seems like it should be easy. I happen to think this is where mysensors has the upper hand, because if you can imagine the solution, then you can program it with real programming languages. Ultimately, with systems that are "dumbed down" and meant to be simple, you end up fighting with the limitations of whatever simplifying framework is used to make it simple, and, ironically, all the workarounds make it complex. With those you either have to settle for less than what you wanted, or else you end up with an unwieldy system because it lacks the expressive power to easily capture what you want.
@NeverDie I'm actually looking for a team backend and frontend to help me reinvent home automation. And give it back to all people, not only the technical ones. I've done quiet a lot of pocs to test me ideas. Preferably Python back end, so I can do some help in coding xd
Current HA systems are difficult. In comparison to the real world, it means that when you want to change a light bulb, you have to completely rewire the fixture in which the lightbulb you wanted to replace was in.
I think it's too complicated ^^
@TheoL If you're serious about it, I suggest you start a thread by laying out your ideas in the opening post and explain why your new approach is fundamentally better than whatever the existing alternatives are. If people agree with you, then you will have started a movement, and if they don't,... well, better to know that sooner rather than later, right?
@NeverDie said in Where did everyone go?:
I think that's a wrong idea. Automation can not be simple, otherwise it would be made automated from the beginning. The key feature of any automation is to set it up once and then gain the benefits of not doing something again and again, it's basically investing. Why would you expect to gain much, with little investment?
It may be that the field of private home and appliances is wrong for the concept of automation, because automating basic home is not going to produce much benefits in the end, so you either over-invest in terms of money or time, or get very simple system that isn't an automation in it's best meaning. -
It may be that the field of private home and appliances is wrong for the concept of automation, because automating basic home is not going to produce much benefits in the end, so you either over-invest in terms of money or time, or get very simple system that isn't an automation in it's best meaning.@monte As a UX designer I dare to differ. HA anno 2021 is overly complicated. No one needs to know how to wire a light fixture. You just change the light bulb when it's broken. Or if in some cases hire an electrician.
I believe I can design things much much simpler. And make it usable.
@TheoL you can buy philips or ikea zigbee bulbs and not change any wiring. That has some limitation and stability problems though, that's why serious automations require proper wiring and project development.
@monte We must have a conversation in a chat or something. to me Ikea is not usable at all. Usable meaning effictive, efficient and looking good.
@TheoL I am just saying from my experience. At one place I use KNX where it was prewired according to a plan, mysensors and ikea in places that where added after the wiring and walls were finished. I have had issues with Ikea bulbs disconnecting and needing repairing with hub, but in the end it is viable solution if you can't change wiring. I also tried Z-wave and it was much more expensive and worse. For zigbee there are opensourse projects that may work better then proprietary hub, but I didn't bother to try them yet.
But anyway, if you want everything to work reliably and be failproof you should plan everything ahead and know what you are doing and how. And I don't think that it's something particularly bad. Someone has to do work to achieve something great. It either you, or someone who you are paying either with money, or other things like your privacy, for example.
And I am not saying, that this will never change, technology is evolving and becoming more robust and sophisticated, I just don't see it changing drastically in nearest future.
Anyway, if you're going to achieve what you are envisioning, I will be happy for those people who will open wonders of home automation for themselves without doing any research. -
Hi Everyone,
I initially started with a goal and MySensors suited, and was very approachable. I built it and it still works. I didn't need much help.
I had a bunch of fun getting things to work and acquired some skills. The work with MySensors helped me get a job as an embedded software engineer, with my environmental sciences i.e. data analysis background.
Since getting that job, I have moved much more towards minimalism in my private life. As such I am designing simple systems that don't need automating, and asking myself what I need. My current focus during my spare time on ultralight winter backpacking/skitouring as well as vipassana meditation helps me see more clearly what is necessary to be happy. My insight does not bode well for most of current IoT use.
I may make some noise when I have decided that a certain thing is necessary AND I need help OR if I dare to show off ;). Meanwhile, enjoy the peace and quiet.
I think when I do get back into MySensors, it will be when I combine my statistics and firmware knowledge: so-called embedded AI applied to inventory management. That is also the solution to truly devalue a cloud connection, in my opinion. Do the work locally (or on your gateway), and say something, if necessary. We'll see if that tendency/thought makes sense in a few years.
I will also revisit MySensors when I want to build an energy harvesting sensor. This is somewhat proximate. I am not a big fan of batteries.
Thank you for the support and the handy framework. I am grateful for the simple systems that work, and keep working.
Going outside now :).
Kind regards,
Brian -
Let's dig out this thread a little. I am a person who's started my own MySensors based hardware project (GetWired, I wrote about it somewhere on this forum), so I probably can be described as an involved user. Somehow it happened that I haven't become an active user on this forum, on one hand I didn't have to write here, because all problems I've encountered were described earlier. On the other hand, I didn't receive much interest after publishing anything (openhardware designs, project related posts).
In my opinion, MySensors with nRF24 has very strong competition, especially taking into consideration the low reliability of this radio. It's easier and better to buy cheap Shelly or other Sonoff. Using nRF52 would help a lot, but it is much more complicated, at least in my opinion.
Second thing is the development of MySensors has slowed down a lot (last commit March 20th). If so, there is not much to discuss here.
Third thing is connected to the development of my own project. Me and my colleague managed to put it on a successful crowdfunding and build a community elsewhere. All this with no support from this community and especially from the MySensors "authorities". I don't want to complain, I just think such initiatives could meet with higher interest from everyone involved in the development of MySensors, because it would be mutually beneficial.
