  3. Dimmer sensor
Dimmer sensor
24 Posts 9 Posters 17.4k Views 3 Watching
  • ferpandoF Offline
    ferpandoF Offline
    ferpando
    Anyone has made a dimmer controlled by a sensor?
    I'm planning on building some and I'd like some advice.
    I thought of using the servo sketch but this would create a blinds device in Vera.
    I'd like to use the dimmer device. Is it possible?
    Does anyone have a circuit dimmer for arduino to adapt?
    Thanks in advance
    • W Offline
      W Offline
      wmylionel
      Check this out,
      http://www.instructables.com/id/safe-and-simple-AC-PWM-Dimmer-for-arduino-Raspberr/all/?lang=pt
      • B Offline
        B Offline
        blacey
        Checkout http://forum.micasaverde.com/index.php/topic,23342.0.html for a thread on a PWM dimmer for LED strips including the initial sketch.
        Here is the next gen mysensors.org board that I am working on and will support up to 4 channels and power sensing - http://forum.micasaverde.com/index.php/topic,23342.msg176334.html#msg176334
        Cheers,
        Bruce
        C 1 Reply Last reply
        • ferpandoF Offline
          ferpandoF Offline
          ferpando
          @wmylionel
          I'll take a look.
          I was looking at this one:
          link
          B 1 Reply Last reply
          • ferpandoF ferpando
            @wmylionel
            I'll take a look.
            link
            B Offline
            B Offline
            blacey
            @ferpando
            Ah, ok. @axillent is working on an AC PWM dimmer as part of the mysensors.org PCB kit. You can ping him via IM if you want the details. The main board will be able to connect to a sensor and an actuator (e.g. dimmer) to achieve your goal of having an autonomous dimmer that is activated by a discrete sensor.
            • B blacey
              Cheers,
              Bruce
              C Offline
              C Offline
              C4Vette
              @blacey
              You're sketch looks really nice and I would like to use it but I started already with the 1.4 libraries. Any chance you will rewrite it for 1.4? I've had a look at it but it's to complicated for me to understand.
              hekH 1 Reply Last reply
              • C C4Vette
                @blacey
                hekH Offline
                hekH Offline
                wrote on last edited by hek
                @C4Vette
                I did a quick 1.4 conversion just now.
                Note that I haven't verified it with any real hardware or anything.
                I will include it in the examples folder for 1.4 when someone has verified it.
                https://codebender.cc/example/MySensor/DimmableLEDActuator
                C boblasureB 2 Replies Last reply
                  @C4Vette
                  C Offline
                  C Offline
                  C4Vette
                  wrote on last edited by C4Vette
                  @hek
                  That is great! Thank you very much, it worked first time. I have a LED-strip with a 50N06 FET connected to 12v and a 10K pull-down on the gate. Flawless!
                  Well, maybe one tiny little thing: when the dimmer is at 100% and I press the minus it always goes to 80% instead of 90%.
                  But this is not something in the sketch but in the library.
                  About the part:
                  // hek comment: Is this really nessesary?
                  gw.send( dimmerMsg.set(currentLevel) );
                  I left that out and there is no difference at all
                  Edit: I tried about every markdown possibility there is to create a code-block but it doesn't work. Sorry.
                    @C4Vette
                    boblasureB Offline
                    boblasureB Offline
                    boblasure
                    wrote on last edited by boblasure
                    @hek * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
                    How do you add more outputs to this? I would like to add PWM 5 and 6 to this. I am using the EasyIot controller. @blacey
                    • hekH Offline
                      hekH Offline
                      That was actually a @blacey comment.
                      • boblasureB boblasure
                        B Offline
                        B Offline
                        blacey
                        @boblasure So you effectively want 3 children, one for each PWM? You will need to extend the sketch to handle two additional pins/children. @korttoma has already done the work...
                        Here is his sketch that handles four channels.
                        https://codebender.cc/sketch:44740
                        boblasureB 1 Reply Last reply
                        • B blacey
                          boblasureB Offline
                          boblasureB Offline
                          boblasure
                          @blacey Awesome, thanks for that! And thanks to @korttoma
                          • jeylitesJ Offline
                            jeylitesJ Offline
                            jeylites
                            • M Offline
                              M Offline
                              mainali
                              Can this dimmer sketch be used to control the speed of a fan ? If yes then what are the changes I need to do to this sketch. As part of a project I am working on, I intend to control a AC 230V fan using arduino. I was planning to create a sketch which explicitly controls a AC FAN.
                              By doing this am I reinventing the wheel or someone has done this already which I can use.
                              jeylitesJ 1 Reply Last reply
                              • M mainali
                                jeylitesJ Offline
                                jeylitesJ Offline
                                jeylites
                                @mainali http://forum.mysensors.org/topic/647/mysensored-230v-motion-sensor-with-light-level/6
                                • M Offline
                                  M Offline
                                  mainali
                                  I have the dimmer circuit with me already. I am looking for the sketch to integrate this with the sensor and send message to the gateway using MQTT for controlling the speed of the fan.
                                  Note: I am using a custom controller build using Ruby on Rails(WIP). and ruby-mqtt to send message to the MQTT gateway which is running mysensor code.
                                  • M mainali
                                    jeylitesJ Offline
                                    jeylitesJ Offline
                                    jeylites
                                    @mainali I don't think I have what you're looking for :( ...
                                    • K Offline
                                      K Offline
                                      korttoma
                                      Would this be of any help? ->
                                      https://codebender.cc/sketch:44734
                                      • Tomas
                                      • M Offline
                                        M Offline
                                        mainali
                                        I have kind of implemented the fan control with a new message type V_FAN, but anyways I will check this out and revert after testing
                                        • M Offline
                                          M Offline
                                          mainali
                                          Can the dimmer led actuator example be used to dim a AC 60w incandescent bulb connected 220v connection. If yes what are the modification needed.
                                          when it comes to controlling the speed of a FAN or dimming a normal tungsten filament bulb. I have found so many answers but not a single one which explains all.
                                          ferpandoF 1 Reply Last reply
