  3. Freedomotic
  4. Freedomotic
Freedomotic
Scheduled Pinned Locked Moved Freedomotic
automationserialgatewaycontroller
72 Posts 15 Posters 55.6k Views 4 Watching
  • D
    dzairo
    Hi.
    I download and try your freedomotic .. Install MySensor Plugin ..
    But show : Plugin started failed , see log for detail.
    Is possible make tutorial for WIndows 7 user ?
    What all need install , download and set..
    regards.
    • freedomoticF
      freedomoticF
      freedomotic
      Hi @dzairo
      I need more info, for example your configuration data. Probably your serial port is not set correctly.
      Start Freedomotic, go to Plugins->Configure (in Main menu), select MySensors and set your gateway port.
      If you can start freedomotic from command line as "java -jar freedomotic.jar" so you can see all error messages.
      I'm improving documentation and log messages.
      Thanks for support
      Freedomotic Iot & Smart Spaces framework
      http://www.freedomotic.com
      • freedomoticF freedomotic
        Hi @asterisco
        can you post a complete console log? If you double click on plugin icon (to stop it) and do the same to restart it do you receive the same error? Thanks for support
        asterisco
        @asterisco said:
        my sensors is reciving a command while is not running. Turn on the plugin first.
        quite similar errors with the plugin started or stoped
        plugin stoped: my sensors is reciving a command while is not running. Turn on the plugin first.
        ** plugin started:** Succesfull test receives a command while is not ruuning. Turn on the plugin firsr
        the logs appear and disappear as quikly thar they are almost imposible to read and i de log file is empty
        bye
        • freedomoticF
          freedomoticF
          freedomotic
          Hi @asterisco
          I uploaded a new version with improved log messages. Can you remove the old plugin folder and reinstall it?
          Are you using the last dailybuild?
            Martin Guttesen
            I get an exception when i try to use mysensor plugin
            Windows 8.1
            INFO <AWT-EventQueue-0> [Plugin] Starting plugin MySensors
            Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: com/freed
            omotic/objects/EnvObjectPersistence
            at com.freedomotic.plugins.devices.mysensors.MySensors.loadConfiguredObj
            ects(MySensors.java:227)
            at com.freedomotic.plugins.devices.mysensors.MySensors.onStart(MySensors
            .java:65)
            at com.freedomotic.api.Protocol$1.run(Protocol.java:133)
            at org.apache.shiro.subject.support.SubjectRunnable.doRun(SubjectRunnabl
            e.java:120)
            at org.apache.shiro.subject.support.SubjectRunnable.run(SubjectRunnable.
            java:108)
            at org.apache.shiro.subject.support.DelegatingSubject.execute(Delegating
            Subject.java:391)
            at com.freedomotic.security.AuthImpl2.executePrivileged(AuthImpl2.java:1
            86)
            at com.freedomotic.security.AuthImpl2.pluginExecutePrivileged(AuthImpl2.
            java:177)
            at com.freedomotic.api.Protocol.start(Protocol.java:151)
            at com.freedomotic.jfrontend.PluginJList$1$1.actionPerformed(PluginJList
            .java:116)
            at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
            at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
            at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
            at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
            at javax.swing.AbstractButton.doClick(Unknown Source)
            at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
            at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown
            Source)
            at java.awt.Component.processMouseEvent(Unknown Source)
            at javax.swing.JComponent.processMouseEvent(Unknown Source)
            at java.awt.Component.processEvent(Unknown Source)
            at java.awt.Container.processEvent(Unknown Source)
            at java.awt.Component.dispatchEventImpl(Unknown Source)
            at java.awt.Container.dispatchEventImpl(Unknown Source)
            at java.awt.Component.dispatchEvent(Unknown Source)
            at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
            at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
            at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
            at java.awt.Window.dispatchEventImpl(Unknown Source)
            at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
            at java.awt.EventQueue.access$200(Unknown Source)
            at java.awt.EventQueue$3.run(Unknown Source)
            at java.security.AccessController.doPrivileged(Native Method)
            at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Sour
            ce)
            ce)
            at java.awt.EventQueue$4.run(Unknown Source)
            ce)
            at java.awt.EventQueue.dispatchEvent(Unknown Source)
            at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
            at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
            at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
            at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
            at java.awt.EventDispatchThread.run(Unknown Source)
            Caused by: java.lang.ClassNotFoundException: com.freedomotic.objects.EnvObjectPe
            rsistence
            at java.net.URLClassLoader$1.run(Unknown Source)
            at java.net.URLClassLoader.findClass(Unknown Source)
            at java.lang.ClassLoader.loadClass(Unknown Source)
            at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
            ... 48 more
            • freedomoticF
              freedomoticF
              freedomotic
              Thanks for your report.
              I'll take a look ASAP.
                sdndba
                Hi @freedomotic
                I've read over all the posts and would like to get an update on the status of the plugin, also would like to know where to get the latest version. If I can get this installed I can help you test in on a very large system with over 50 nodes with various sensors on a ranch. Thanks,
                • freedomoticF
                  freedomoticF
                  freedomotic
                  Hi @sdndba
                  thanks for your offer. We are working on a new version. When it is available I'll post here.
                  Happy new year!!!
                  • freedomoticF
                    freedomoticF
                    freedomotic
                    Hello
                    @sdndba you can try a new version (in attachment)
                    Download from http://teamcity.codebetter.com/guestAuth/repository/download/bt1177/.lastSuccessful/freedomotic-5.6.0-{build.number}.zip
                    Extract it, then extract the plugin into freedomotic_folder/plugins/devices.
                    Let me know
                    Thanks for supportmysensors.zip
                    BobCB 1 Reply Last reply
                      Hello
                      Let me know
                      BobCB
                      BobCB
                      BobC
                      @freedomotic Good morning and thanks to all for the hard work you put in.
                      I went to Domotic website - downloaded the zip files , all fine but when trying to load the Mysensors plugin it was unavailable!!
                      I'm just starting with win 7 but will upgrade to pi when I get a bit of experience.
                      Any idea whrn the plugin will be available?
                      thanks
                      • freedomoticF
                        freedomoticF
                        freedomotic
                        Hi @BobC
                        we are working on the plugin but we need some testers. Nobody is helping us now. Did you try the post attached zip file? If you want we can collaborate. Thanks
                        • freedomoticF
                          freedomoticF
                          freedomotic
                          We are very glad to announce that Freedomotic is on Canonical Ubuntu Snappy Official Page ("Our Partners" section). A great result for our efforts!
                          http://www.ubuntu.com/things
                          • Roberto BrunialtiR
                            Roberto BrunialtiR
                            Roberto Brunialti
                            Hi, what about the mysensor plugin? I would like to try the freedomotic frontend with raspberrypi as a (serial)gateway. Are there any tutorials about?
                            thanks
                            • freedomoticF
                              freedomoticF
                              freedomotic
                              Hi Roberto
                              thanks for your interest. The plugin is in stand-by because I don't have any hardware for tests. I asked some help on this forum with no success. If you want we can collaborate. I tried a first draft using a fake serial connection on Windows. Let me know your idea with Raspi. Bye
                              • freedomoticF
                                freedomoticF
                                freedomotic
                                Hi @Roberto-Brunialti
                                are you still interested?
                                  Roberto BrunialtiR
                                  Roberto Brunialti
                                  Yes, I' am. Still to understand the needs in terms of sensors, gw and so on...
                                  Never used before mysensor, but i've got 4 sensordend boards.
                                  I should be able to setup a gw with nrf+ in a raspberry 2.
                                  • V
                                    V
                                    virgus1970
                                    Hi, Freedomotic!
                                    I'm too interesting in testing hardware (sensors & rellays) with MySensor Plugin on Pi B+. Do You need one more tester?
                                    • freedomoticF
                                      freedomoticF
                                      freedomotic
                                      Of course @virgus1970 , I need all possible testers.
                                      I'm updating the plugin to start testing. For now you can install Freedomotic on your raspberry and try it. The plugin works with the upcoming version 5.6 you can download from http://teamcity.codebetter.com/guestAuth/repository/download/bt1177/.lastSuccessful/freedomotic-5.6.0-{build.number}.zip
                                      • V
                                        V
                                        virgus1970
                                        Ok. I'm going to start next week & will keep You up to date
                                        • freedomoticF
                                          freedomoticF
                                          freedomotic
                                          Hi, in attachment the new development version. You need to download freedomotic from the previous link (teamcity), extract the plugin zip to freedomotic_root/plugins/devices folder and then modify your serial port name in mysensors-manifest.xml.
                                          Start Freedomotic and double click on Mysensors icon.
                                          mysensors.zip
                                          barduinoB 1 Reply Last reply
