  3. Freedomotic
  4. Freedomotic
Freedomotic
Scheduled Pinned Locked Moved Freedomotic
automationserialgatewaycontroller
72 Posts 15 Posters 55.5k Views 4 Watching
  • freedomoticF
    freedomoticF
    freedomotic
    Hi all,
    thanks for your explanations. I have some questions:
    1. when the controller assigned an ID, this is stored on the node. If the controller restarts, is this address maintained in the node? or does the node detect this restarting and ask again a new address?
    2. is the address changed only after a specific request by the node?
      Hope my questions are clear. Every freedomotic object must have a fixed address, so if it assign an ID, this shouldn't change at any restarting of software or node.
      Thanks for your support.
    Freedomotic Iot & Smart Spaces framework
    http://www.freedomotic.com
      1. yes node remembers id and won't ask again.
      2. Normally the node wont ask again (unless you clear the eeprom).
      • NuubiN
        NuubiN
        Nuubi
        (might be a silly question..) How do you clean the eeprom? Is it not enought to write another sketch to the chip?
          I've created a ClearEpromConfig in examples.
          • D
            diamantmatch
            hey,
            i really feel like i'm just nagging about things here.. sorry about that.
            i can not seem to get the sensor to listen to the serial output from the plugin..
            i suspect the plugin from not transmitting a newline, every string transmitted should end with \n
            • freedomoticF
              freedomoticF
              freedomotic
              wrote on last edited by freedomotic
              #33
              Hi @diamantmatch,
              I implemented a first draft of Auto-ID feature.
              If you want you can test it using the attached file (you must extract thejar in it), substituting the old in the plugin folder. Starting Freedomotic from command line you can see all plugin activity.
              I'm reviewing the entire plugin, to improve it and support an increasing number of devices.
              Let me know and thanks for support mysensors-3.0.zip
              • A
                Aloha
                Hi Mauro,
                I read somewhere there's currently no web frontend. Is this still the case? And if so, how do you access freedomotic remotely?
                / Thomas
                • freedomoticF
                  freedomoticF
                  freedomotic
                  Hi Thomas,
                  the web client is under development. We hope to realease soon a first demo. If you are interested you can take a look at our repository https://github.com/freedomotic (Polymer). Now is it possible to interact remotely using our REST API (under development). It's the base to create customized clients in every programming languages. More info at http://freedomotic.com/content/plugins/restapi-v3
                  Remember that Freedomotic is a "framework" to create custom iot/home/building automations solutions.
                  Thanks for your interest
                  Mauro
                  • freedomoticF freedomotic
                    Hi Vincent,
                    please can you give me more details? What's the expected reply from the controller (freedomotic)?
                    And your sensor request? I developed the plugin by simulating devices communications. Maaybe something is not complete.
                    asterisco
                    @freedomotic
                    Hi freedomotic, I'm traying to test you plug-in in freedomotic, but dont make it works. Could you please give me a mini setup advise, for example for a** RelayActuator** using Lights General Switch. I set
                    protocolo: mysensors
                    dirección: 7;1 //static ip because i don`t use AUTO mode (or should I use AUTO mode? to make it works)
                    actions: turn on/of MySensors light
                        <property name="serial.port" value="COM5"/>
                        <property name="serial.baudrate" value="115200"/>
                        <property name="serial.databits" value="8"/>
                        <property name="serial.parity" value="0"/>
                        <property name="serial.stopbits" value="1"/>
                    There is allways the same message:
                    my sensors is reciving a command while is not running. Turn on the plugin first.
                    but the plugin is turned on, what im doing wrong???
                    thanks
                    • freedomoticF
                      freedomoticF
                      freedomotic
                      Hi @asterisco
                      can you post a complete console log? If you double click on plugin icon (to stop it) and do the same to restart it do you receive the same error? Thanks for support
                      A 1 Reply Last reply
                      • D
                        dzairo
                        Hi.
                        I download and try your freedomotic .. Install MySensor Plugin ..
                        But show : Plugin started failed , see log for detail.
                        Is possible make tutorial for WIndows 7 user ?
                        What all need install , download and set..
                        regards.
                        • freedomoticF
                          freedomoticF
                          freedomotic
                          Hi @dzairo
                          I need more info, for example your configuration data. Probably your serial port is not set correctly.
                          Start Freedomotic, go to Plugins->Configure (in Main menu), select MySensors and set your gateway port.
                          If you can start freedomotic from command line as "java -jar freedomotic.jar" so you can see all error messages.
                          I'm improving documentation and log messages.
                          Thanks for support
                            Hi @asterisco
                            asterisco
                            quite similar errors with the plugin started or stoped
                            plugin stoped: my sensors is reciving a command while is not running. Turn on the plugin first.
                            ** plugin started:** Succesfull test receives a command while is not ruuning. Turn on the plugin firsr
                            the logs appear and disappear as quikly thar they are almost imposible to read and i de log file is empty
                            bye
                            • freedomoticF
                              freedomoticF
                              freedomotic
                              Hi @asterisco
                              I uploaded a new version with improved log messages. Can you remove the old plugin folder and reinstall it?
                              Are you using the last dailybuild?
                                Martin Guttesen
                                I get an exception when i try to use mysensor plugin
                                Windows 8.1
                                INFO <AWT-EventQueue-0> [Plugin] Starting plugin MySensors
                                Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: com/freed
                                omotic/objects/EnvObjectPersistence
                                at com.freedomotic.plugins.devices.mysensors.MySensors.loadConfiguredObj
                                ects(MySensors.java:227)
                                at com.freedomotic.plugins.devices.mysensors.MySensors.onStart(MySensors
                                .java:65)
                                at com.freedomotic.api.Protocol$1.run(Protocol.java:133)
                                at org.apache.shiro.subject.support.SubjectRunnable.doRun(SubjectRunnabl
                                e.java:120)
                                at org.apache.shiro.subject.support.SubjectRunnable.run(SubjectRunnable.
                                java:108)
                                at org.apache.shiro.subject.support.DelegatingSubject.execute(Delegating
                                Subject.java:391)
                                at com.freedomotic.security.AuthImpl2.executePrivileged(AuthImpl2.java:1
                                86)
                                at com.freedomotic.security.AuthImpl2.pluginExecutePrivileged(AuthImpl2.
                                java:177)
                                at com.freedomotic.api.Protocol.start(Protocol.java:151)
                                at com.freedomotic.jfrontend.PluginJList$1$1.actionPerformed(PluginJList
                                .java:116)
                                at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
                                at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
                                at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
                                at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
                                at javax.swing.AbstractButton.doClick(Unknown Source)
                                at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
                                at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown
                                Source)
                                at java.awt.Component.processMouseEvent(Unknown Source)
                                at javax.swing.JComponent.processMouseEvent(Unknown Source)
                                at java.awt.Component.processEvent(Unknown Source)
                                at java.awt.Container.processEvent(Unknown Source)
                                at java.awt.Component.dispatchEventImpl(Unknown Source)
                                at java.awt.Container.dispatchEventImpl(Unknown Source)
                                at java.awt.Component.dispatchEvent(Unknown Source)
                                at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
                                at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
                                at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
                                at java.awt.Window.dispatchEventImpl(Unknown Source)
                                at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
                                at java.awt.EventQueue.access$200(Unknown Source)
                                at java.awt.EventQueue$3.run(Unknown Source)
                                at java.security.AccessController.doPrivileged(Native Method)
                                at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Sour
                                ce)
                                ce)
                                at java.awt.EventQueue$4.run(Unknown Source)
                                ce)
                                at java.awt.EventQueue.dispatchEvent(Unknown Source)
                                at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
                                at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
                                at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
                                at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
                                at java.awt.EventDispatchThread.run(Unknown Source)
                                Caused by: java.lang.ClassNotFoundException: com.freedomotic.objects.EnvObjectPe
                                rsistence
                                at java.net.URLClassLoader$1.run(Unknown Source)
                                at java.net.URLClassLoader.findClass(Unknown Source)
                                at java.lang.ClassLoader.loadClass(Unknown Source)
                                at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
                                ... 48 more
                                • freedomoticF
                                  freedomoticF
                                  freedomotic
                                  Thanks for your report.
                                  I'll take a look ASAP.
                                    sdndba
                                    Hi @freedomotic
                                    I've read over all the posts and would like to get an update on the status of the plugin, also would like to know where to get the latest version. If I can get this installed I can help you test in on a very large system with over 50 nodes with various sensors on a ranch. Thanks,
                                    • freedomoticF
                                      freedomoticF
                                      freedomotic
                                      Hi @sdndba
                                      thanks for your offer. We are working on a new version. When it is available I'll post here.
                                      Happy new year!!!
                                      • freedomoticF
                                        freedomoticF
                                        freedomotic
                                        Hello
                                        @sdndba you can try a new version (in attachment)
                                        Download from http://teamcity.codebetter.com/guestAuth/repository/download/bt1177/.lastSuccessful/freedomotic-5.6.0-{build.number}.zip
                                        Extract it, then extract the plugin into freedomotic_folder/plugins/devices.
                                        Let me know
                                        Thanks for supportmysensors.zip
                                        BobCB 1 Reply Last reply
                                          Hello
                                          Let me know
                                          BobCB
                                          BobCB
                                          BobC
                                          @freedomotic Good morning and thanks to all for the hard work you put in.
                                          I went to Domotic website - downloaded the zip files , all fine but when trying to load the Mysensors plugin it was unavailable!!
                                          I'm just starting with win 7 but will upgrade to pi when I get a bit of experience.
                                          Any idea whrn the plugin will be available?
                                          thanks
