  3. Freedomotic
  4. Freedomotic
Freedomotic
Scheduled Pinned Locked Moved Freedomotic
automationserialgatewaycontroller
72 Posts 15 Posters 55.6k Views 4 Watching
  • D
    diamantmatch
    hey,
    i really feel like i'm just nagging about things here.. sorry about that.
    i can not seem to get the sensor to listen to the serial output from the plugin..
    i suspect the plugin from not transmitting a newline, every string transmitted should end with \n
    • freedomoticF
      freedomoticF
      freedomotic
      wrote on last edited by freedomotic
      #33
      Hi @diamantmatch,
      I implemented a first draft of Auto-ID feature.
      If you want you can test it using the attached file (you must extract thejar in it), substituting the old in the plugin folder. Starting Freedomotic from command line you can see all plugin activity.
      I'm reviewing the entire plugin, to improve it and support an increasing number of devices.
      Let me know and thanks for support mysensors-3.0.zip
      Freedomotic Iot & Smart Spaces framework
      http://www.freedomotic.com
      • A
        Aloha
        Hi Mauro,
        I read somewhere there's currently no web frontend. Is this still the case? And if so, how do you access freedomotic remotely?
        / Thomas
        • freedomoticF
          freedomoticF
          freedomotic
          Hi Thomas,
          the web client is under development. We hope to realease soon a first demo. If you are interested you can take a look at our repository https://github.com/freedomotic (Polymer). Now is it possible to interact remotely using our REST API (under development). It's the base to create customized clients in every programming languages. More info at http://freedomotic.com/content/plugins/restapi-v3
          Remember that Freedomotic is a "framework" to create custom iot/home/building automations solutions.
          Thanks for your interest
          Mauro
          • freedomoticF freedomotic
            Hi Vincent,
            please can you give me more details? What's the expected reply from the controller (freedomotic)?
            And your sensor request? I developed the plugin by simulating devices communications. Maaybe something is not complete.
            Thanks for your support.
            asterisco
            @freedomotic
            Hi freedomotic, I'm traying to test you plug-in in freedomotic, but dont make it works. Could you please give me a mini setup advise, for example for a** RelayActuator** using Lights General Switch. I set
            protocolo: mysensors
            dirección: 7;1 //static ip because i don`t use AUTO mode (or should I use AUTO mode? to make it works)
            actions: turn on/of MySensors light
                <property name="serial.port" value="COM5"/>
                <property name="serial.baudrate" value="115200"/>
                <property name="serial.databits" value="8"/>
                <property name="serial.parity" value="0"/>
                <property name="serial.stopbits" value="1"/>
            There is allways the same message:
            my sensors is reciving a command while is not running. Turn on the plugin first.
            but the plugin is turned on, what im doing wrong???
            thanks
            • freedomoticF
              freedomoticF
              freedomotic
              Hi @asterisco
              can you post a complete console log? If you double click on plugin icon (to stop it) and do the same to restart it do you receive the same error? Thanks for support
              A 1 Reply Last reply
              • D
                dzairo
                Hi.
                I download and try your freedomotic .. Install MySensor Plugin ..
                But show : Plugin started failed , see log for detail.
                Is possible make tutorial for WIndows 7 user ?
                What all need install , download and set..
                regards.
                • freedomoticF
                  freedomoticF
                  freedomotic
                  Hi @dzairo
                  I need more info, for example your configuration data. Probably your serial port is not set correctly.
                  Start Freedomotic, go to Plugins->Configure (in Main menu), select MySensors and set your gateway port.
                  If you can start freedomotic from command line as "java -jar freedomotic.jar" so you can see all error messages.
                  I'm improving documentation and log messages.
                  Thanks for support
                    Hi @asterisco
                    asterisco
                    quite similar errors with the plugin started or stoped
                    plugin stoped: my sensors is reciving a command while is not running. Turn on the plugin first.
                    ** plugin started:** Succesfull test receives a command while is not ruuning. Turn on the plugin firsr
                    the logs appear and disappear as quikly thar they are almost imposible to read and i de log file is empty
                    bye
                    • freedomoticF
                      freedomoticF
                      freedomotic
                      Hi @asterisco
                      I uploaded a new version with improved log messages. Can you remove the old plugin folder and reinstall it?
                      Are you using the last dailybuild?
                        Martin Guttesen
                        I get an exception when i try to use mysensor plugin
                        Windows 8.1
                        INFO <AWT-EventQueue-0> [Plugin] Starting plugin MySensors
                        Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: com/freed
                        omotic/objects/EnvObjectPersistence
                        at com.freedomotic.plugins.devices.mysensors.MySensors.loadConfiguredObj
                        ects(MySensors.java:227)
                        at com.freedomotic.plugins.devices.mysensors.MySensors.onStart(MySensors
                        .java:65)
                        at com.freedomotic.api.Protocol$1.run(Protocol.java:133)
                        at org.apache.shiro.subject.support.SubjectRunnable.doRun(SubjectRunnabl
                        e.java:120)
                        at org.apache.shiro.subject.support.SubjectRunnable.run(SubjectRunnable.
                        java:108)
                        at org.apache.shiro.subject.support.DelegatingSubject.execute(Delegating
                        Subject.java:391)
                        at com.freedomotic.security.AuthImpl2.executePrivileged(AuthImpl2.java:1
                        86)
                        at com.freedomotic.security.AuthImpl2.pluginExecutePrivileged(AuthImpl2.
                        java:177)
                        at com.freedomotic.api.Protocol.start(Protocol.java:151)
                        at com.freedomotic.jfrontend.PluginJList$1$1.actionPerformed(PluginJList
                        .java:116)
                        at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
                        at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
                        at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
                        at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
                        at javax.swing.AbstractButton.doClick(Unknown Source)
                        at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
                        at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown
                        Source)
                        at java.awt.Component.processMouseEvent(Unknown Source)
                        at javax.swing.JComponent.processMouseEvent(Unknown Source)
                        at java.awt.Component.processEvent(Unknown Source)
                        at java.awt.Container.processEvent(Unknown Source)
                        at java.awt.Component.dispatchEventImpl(Unknown Source)
                        at java.awt.Container.dispatchEventImpl(Unknown Source)
                        at java.awt.Component.dispatchEvent(Unknown Source)
                        at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
                        at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
                        at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
                        at java.awt.Window.dispatchEventImpl(Unknown Source)
                        at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
                        at java.awt.EventQueue.access$200(Unknown Source)
                        at java.awt.EventQueue$3.run(Unknown Source)
                        at java.security.AccessController.doPrivileged(Native Method)
                        at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Sour
                        ce)
                        ce)
                        at java.awt.EventQueue$4.run(Unknown Source)
                        ce)
                        at java.awt.EventQueue.dispatchEvent(Unknown Source)
                        at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
                        at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
                        at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
                        at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
                        at java.awt.EventDispatchThread.run(Unknown Source)
                        Caused by: java.lang.ClassNotFoundException: com.freedomotic.objects.EnvObjectPe
                        rsistence
                        at java.net.URLClassLoader$1.run(Unknown Source)
                        at java.net.URLClassLoader.findClass(Unknown Source)
                        at java.lang.ClassLoader.loadClass(Unknown Source)
                        at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
                        ... 48 more
                        • freedomoticF
                          freedomoticF
                          freedomotic
                          Thanks for your report.
                          I'll take a look ASAP.
                            sdndba
                            Hi @freedomotic
                            I've read over all the posts and would like to get an update on the status of the plugin, also would like to know where to get the latest version. If I can get this installed I can help you test in on a very large system with over 50 nodes with various sensors on a ranch. Thanks,
                            • freedomoticF
                              freedomoticF
                              freedomotic
                              Hi @sdndba
                              thanks for your offer. We are working on a new version. When it is available I'll post here.
                              Happy new year!!!
                              • freedomoticF
                                freedomoticF
                                freedomotic
                                Hello
                                @sdndba you can try a new version (in attachment)
                                Download from http://teamcity.codebetter.com/guestAuth/repository/download/bt1177/.lastSuccessful/freedomotic-5.6.0-{build.number}.zip
                                Extract it, then extract the plugin into freedomotic_folder/plugins/devices.
                                Let me know
                                Thanks for supportmysensors.zip
                                BobCB 1 Reply Last reply
                                  Hello
                                  Let me know
                                  BobCB
                                  BobCB
                                  BobC
                                  @freedomotic Good morning and thanks to all for the hard work you put in.
                                  I went to Domotic website - downloaded the zip files , all fine but when trying to load the Mysensors plugin it was unavailable!!
                                  I'm just starting with win 7 but will upgrade to pi when I get a bit of experience.
                                  Any idea whrn the plugin will be available?
                                  thanks
                                  • freedomoticF
                                    freedomoticF
                                    freedomotic
                                    Hi @BobC
                                    we are working on the plugin but we need some testers. Nobody is helping us now. Did you try the post attached zip file? If you want we can collaborate. Thanks
                                    • freedomoticF
                                      freedomoticF
                                      freedomotic
                                      We are very glad to announce that Freedomotic is on Canonical Ubuntu Snappy Official Page ("Our Partners" section). A great result for our efforts!
                                      http://www.ubuntu.com/things
                                      • Roberto BrunialtiR
                                        Roberto BrunialtiR
                                        Roberto Brunialti
                                        Hi, what about the mysensor plugin? I would like to try the freedomotic frontend with raspberrypi as a (serial)gateway. Are there any tutorials about?
                                        thanks
                                        • freedomoticF
                                          freedomoticF
                                          freedomotic
                                          Hi Roberto
                                          thanks for your interest. The plugin is in stand-by because I don't have any hardware for tests. I asked some help on this forum with no success. If you want we can collaborate. I tried a first draft using a fake serial connection on Windows. Let me know your idea with Raspi. Bye
