  3. implementing multiple sensors
83 Posts 28 Posters 99.2k Views 15 Watching
    We've actually thought about doing a sketch-generator also. It's down there on the list. And it would be a web-thing (hopefully with OTA update) :)
    greglG 1 Reply Last reply
      greglG
      greglG
      gregl
      @hek Phew... cause you are a great programmer!!!
      OTA!!.... now your showing off ;-)
      • liningerL
        liningerL
        lininger
        A few people have asked about the hardware I used.
        A quick write up on what hardware I used for the blinds-light-temp-servo project.
        My binds are 1” not the 2” that you see in the projects listed in the forums. The standard servos will not fit inside the 1” blinds, so I had to use the mini servos. My concern was that the mini servos would not have the torque necessary to operate the tilt mechanism. But for at least the 45x38 blinds I have the mini servo worked great, not sure about larger size blinds.
        I removed the tilt wand and mechanism completely and connected the servo directly to the hex rod. I used a piece of 2” foam insulation and cut out a cavity for the servo and used it as the mounting bracket.
        I purchased a Nano IO shield from imall.iteadstudio.com, which I plan to use when I assemble the parts into a final enclosure and mount it inside the cabinet. With the Light and Temp sensors mounted inside the window frame.
        I use PLEG to control the blinds.
        Parts used:
        http://www.ebay.com/itm/291084936296?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 – used to connect the servo to the hex rod. Note I had to cut off some of the hex rod so the servo would sit inside the head rail.
        http://www.ebay.com/itm/SG90-Tower-Pro-mini-servo-Universal-S-type-connector-4-0-to-6-0-volts-/261184708931?pt=Model_Kit_US&hash=item3ccfd26143
        I tried to upload a 5 second video of the binds in operation, but the file is too large.
          Cool! Just upload the video to youtube and post the link here (it will be embedded automatically).
          • liningerL
            liningerL
            lininger
            Two short videos
            1. During development
            2. In production
            http://tinypic.com/r/2dcfn9w/8
            http://tinypic.com/r/w05r21/8
            • HoffanH
              HoffanH
              Hoffan
              Can anyone see if i have missed something here in the code, It was working great before i copy/past the DHT sensor to the code; ande after that
              it will not really work anymore, Its 4 Binary Buttons, 1 relay And 1 DHT sensor Combo
                      #include <Relay.h>
                      #include <Sensor.h>
                      #include <EEPROM.h>
                      #include <RF24.h>
                      #define RELAY_1  7  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                      #define NUMBER_OF_RELAYS 2
                      #define RELAY_ON 0
                      #define RELAY_OFF 1
                      #define BUTTON_PIN1  3  // Arduino Digital I/O pin for button/reed switch
                      #define BUTTON_PIN2  4  // Arduino Digital I/O pin for button/reed switch
                      #define BUTTON_PIN3  5  // Arduino Digital I/O pin for button/reed switch
                      #define BUTTON_PIN4  6  // Arduino Digital I/O pin for button/reed switch
                      #define CHILD_ID_HUM 0
                      #define CHILD_ID_TEMP 1
                      #define HUMIDITY_SENSOR_DIGITAL_PIN 8
                      Sensor gw;
                      Bounce debouncer1 = Bounce();
                      Bounce debouncer2 = Bounce();
                      Bounce debouncer3 = Bounce();
                      Bounce debouncer4 = Bounce();
                      int oldValue1=-1;
                      int oldValue2=-1;
                      int oldValue3=-1;
                      int oldValue4=-1;
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                      boolean metric = true;
                        gw.begin();
                        pinMode(BUTTON_PIN1,INPUT);
                        digitalWrite(BUTTON_PIN1,HIGH);
                        pinMode(BUTTON_PIN2,INPUT);
                        digitalWrite(BUTTON_PIN2,HIGH);
                        pinMode(BUTTON_PIN3,INPUT);
                        digitalWrite(BUTTON_PIN3,HIGH);
                        pinMode(BUTTON_PIN4,INPUT);
                        digitalWrite(BUTTON_PIN4,HIGH);
                        debouncer1.attach(BUTTON_PIN1);
                        debouncer1.interval(5);
                        debouncer2.attach(BUTTON_PIN2);
                        debouncer2.interval(5);
                        debouncer3.attach(BUTTON_PIN3);
                        debouncer3.interval(5);
                        debouncer4.attach(BUTTON_PIN4);
                        debouncer4.interval(5);
                        // If S_LIGHT is used, remember to update variable type you send in below.
                        gw.sendSensorPresentation(BUTTON_PIN1, S_DOOR);
                        gw.sendSensorPresentation(BUTTON_PIN2, S_DOOR);
                        gw.sendSensorPresentation(BUTTON_PIN3, S_DOOR);
                        gw.sendSensorPresentation(BUTTON_PIN4, S_DOOR);
                        gw.sendSketchInfo("4Door2Relay", "1.0");
                        gw.sendSensorPresentation(CHILD_ID_HUM, S_HUM);
                        gw.sendSensorPresentation(CHILD_ID_TEMP, S_TEMP);
                        metric = gw.isMetricSystem();
                        for (int i=0; i<NUMBER_OF_RELAYS;i++) {
                          gw.sendSensorPresentation(RELAY_1+i, S_LIGHT);
                        // Fetch relay status
                          digitalWrite(RELAY_1+i, RELAY_OFF);
                          pinMode(RELAY_1+i, OUTPUT);
                          // Request/wait for relay status
                          gw.getStatus(RELAY_1+i, V_LIGHT);
                          setRelayStatus(gw.getMessage()); // Wait here until status message arrive from gw
                      *  Example on how to asynchronously check for new messages from gw
                         debouncer1.update();
                         debouncer2.update();
                         debouncer3.update();
                         debouncer4.update();
                        // Get the update value
                        int value = debouncer1.read();
                        if (value != oldValue1) {
                           // Send in the new value
                           gw.sendVariable(BUTTON_PIN1, V_TRIPPED, value==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
                           oldValue1 = value;
                      value = debouncer2.read();
                      if (value != oldValue2) {
                      gw.sendVariable(BUTTON_PIN2, V_TRIPPED, value==HIGH ? "1" : "0"); // Change to V_LIGHT if you use S_LIGHT in presentation above
                      oldValue2 = value;
                      value = debouncer3.read();
                      if (value != oldValue3) {
                      gw.sendVariable(BUTTON_PIN3, V_TRIPPED, value==HIGH ? "1" : "0"); // Change to V_LIGHT if you use S_LIGHT in presentation above
                      oldValue3 = value;
                       value = debouncer4.read();
                      if (value != oldValue4) {
                      gw.sendVariable(BUTTON_PIN4, V_TRIPPED, value==HIGH ? "1" : "0"); // Change to V_LIGHT if you use S_LIGHT in presentation above
                      oldValue4 = value;
                        if (isnan(temperature)) {
                          lastTemp = temperature;
                          if (!metric) {
                          gw.sendVariable(CHILD_ID_TEMP, V_TEMP, temperature, 1);
                            Serial.print("T: ");
                        if (isnan(humidity)) {
                            lastHum = humidity;
                            gw.sendVariable(CHILD_ID_HUM, V_HUM, humidity, 1);
                            Serial.print("H: ");
                            Serial.println(humidity);
                        if (gw.messageAvailable()) {
                          message_s message = gw.getMessage();
                          setRelayStatus(message);
                      void setRelayStatus(message_s message) {
                        if (message.header.messageType==M_SET_VARIABLE &&
                            message.header.type==V_LIGHT) {
                           int incomingRelayStatus = atoi(message.data);
                           // Change relay state
                           digitalWrite(message.header.childId, incomingRelayStatus==1?RELAY_ON:RELAY_OFF);
                           Serial.print("Incoming change for relay on pin:");
                           Serial.print(message.header.childId);
                           Serial.println(incomingRelayStatus);
              • BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @Hoffan said:
                #include <Relay.h>
                #include <Sensor.h>
                #include <EEPROM.h>
                #include <RF24.h>
                    #define RELAY_ON 0
                    #define RELAY_OFF 1
                    Sensor gw;
                    int oldValue1=-1;
                    int oldValue2=-1;
                    int oldValue3=-1;
                    int oldValue4=-1;
                    DHT dht;
                    float lastTemp;
                    float lastHum;
                      gw.begin();
                         oldValue1 = value;
                    oldValue2 = value;
                    oldValue3 = value;
                    oldValue4 = value;
                        if (!metric) {
                          lastHum = humidity;
                can you elaborate on "doesn't work" ?
                do you have sensors on the Vera UI?
                Try to debug putting Serial.print(Something) in places so you can see how the sketch progresses...
                HoffanH 1 Reply Last reply
                  @Hoffan said:
                  #include <Relay.h>
                  #include <Sensor.h>
                  #include <EEPROM.h>
                  #include <RF24.h>
                      #define RELAY_ON 0
                      #define RELAY_OFF 1
                      Sensor gw;
                      int oldValue1=-1;
                      int oldValue2=-1;
                      int oldValue3=-1;
                      int oldValue4=-1;
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                        gw.begin();
                           oldValue1 = value;
                      oldValue2 = value;
                      oldValue3 = value;
                      oldValue4 = value;
                          if (!metric) {
                            lastHum = humidity;
                  HoffanH
                  HoffanH
                  Hoffan
                  @BulldogLowell
                  Yes all the sensors came up in the Vera UI, And looks like they work for some minutes
                  But when i push å button its looks like all things stop working, and after a reboot on the Arduino its working again for a short time and so on
                  BulldogLowellB 2 Replies Last reply
                  • HoffanH Hoffan
                    @BulldogLowell
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    #37
                    • HoffanH Hoffan
                      @BulldogLowell
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @Hoffan said:
                      @BulldogLowell
                      Try threading in the sensor reads into each block to read and change its state in one block for each sensor/pin.
                      I edited you code so it can be read,,, attached.
                      Remember AutoFormat under Tools in your arduino menu
                          oldValue1 = value;
                          oldValue2 = value;
                          oldValue3 = value;
                          oldValue4 = value;
                      FourSensorTwoRelay.ino
                      • W
                        W
                        waynehead99
                        So I have created a multi sensor that uses the DHT and motion to get Temp/Hum/Motion. Problem I have though is the update of the hum/temp. I have not been able to figure out a way to get a reliable update on those without blasting the GW/Vera with unneeded announcements (disable sleep function and it keeps updating pretty much every second). So right now the script updates the temp/hum only when motion is seen. I have tried a few things with my limited knowledge of arduino and can't get this to work properly. Can someone please take a look at this sketch and tell me what I am missing? If i change the variables for sleep at the end and try to do an interrupt and a sleep delay, i get an error.
                        Motion_Temp_Sensor13b3.ino
                        • W
                          W
                          waynehead99
                          Nobody wants to take a crack at this? I figured this to be a common combo and would really like to get it to work properly.
                          • B
                            B
                            Bandra
                            I'm coming close to finalising my multisensor sketch. I'll post code once I clean it up a little. I have a newborn at home, so if I forget to put code here then somebody please remind me in a little while :)
                            • W waynehead99
                              mikeones
                              @waynehead99 Here is a sketch I run with DHT and motion support.
                              #include <Sleep_n0m1.h>
                              #include <EEPROM.h>
                              #include <RF24.h>
                              #include <Sensor.h>
                              Sensor gw;
                              DHT dht;
                              Sleep sleep;
                              float lastTemp;
                              float lastHum;
                              boolean lastValue = false;
                              boolean metric = false;
                              #define CHILD_ID 2   // Id of the sensor child
                              long previousMillis_T = 0;     // will store last time temp data sent
                              unsigned long startTime_T;
                              unsigned long sensorInterval = 30000; // change this to desired sensor read interval in milliseconds
                                gw.begin();
                                gw.sendSketchInfo("Motion Sensor and DHT", "1.0");
                                gw.sendSensorPresentation(CHILD_ID, S_MOTION);
                                startTime_T = millis();
                                Serial.println("Setup complete");
                                // Read digital motion value
                                if (lastValue != tripped) {
                              	gw.sendVariable(CHILD_ID, V_TRIPPED, tripped?"1":"0");  // Send tripped value to gw
                              	lastValue=tripped;
                              	//Serial.println(tripped);
                                if (millis() - startTime_T >= sensorInterval) {
                              	} else if (temperature) {
                              	  if (!metric) {
                              	//delay(dht.getMinimumSamplingPeriod());
                              	} else if (humidity) {
                              		lastHum = humidity;
                                // Power down the radio.  Note that the radio will get powered back up
                                // on the next write() call.
                                delay(1000); //delay to allow serial to fully print before sleep
                              • W
                                W
                                waynehead99
                                Thanks that worked... and for my understanding... looks like your not really using interrupts at all? Looking at the code makes complete sense to me, and proves I was over thinking things on mine.
                                Thanks again.
                                  mikeones
                                  The sensor is not running on battery power so I did not spend much time with the interrupt/sleep options.
                                  • T
                                    Tibus
                                    is it the same process with the new 1.4 library version?
                                    Could you please give us a exemple here or on github to have multiple sensor type on the same arduino with the new 1.4 library?
                                    if it's the same implementation, we could write multiple "gw.present(ID, XXXX);" and send a message for each child ID type?
                                    Thank's very much.
                                    • T
                                      Tibus
                                      Sorry, I found the new implementation in the "DallasTemperatureSensor" Example
                                      • mountainmanM
                                        mountainmanM
                                        mountainman
                                        wrote on last edited by mountainman
                                        #47
                                        Here is a version I'm currently using that makes use of interrupts so might be more suitable for a battery driven DHT/Motion multi sensor. It also includes the battery monitoring. Any feedback or improvements would be appreciated.
                                        #define CHILD_ID_MOTION 2   // Id of the sensor child
                                        unsigned long SLEEP_TIME = F; // Sleep time between reports (in milliseconds)
                                        int oldValue=-1;
                                        DHT dht;
                                        float lastTemp;
                                        float lastHum;
                                        int oldBatteryPcnt = 0;
                                        int battLoop =0;
                                        // Initialize motion message
                                        MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
                                        boolean pinTriggered=0;//waitTime is number of seconds to hol in while loop
                                        long lastDebounceTime = 0;  // the last time the output pin was toggled
                                        long debounceDelay = 50;    // the debounce time; increase if the output flickers
                                          analogReference(INTERNAL);
                                          gw.begin();
                                          gw.sendSketchInfo("Motion Humidity w/ Batt", "1.0");
                                          gw.present(CHILD_ID_MOTION, S_MOTION);
                                          pinMode(DIGITAL_INPUT_SENSOR,INPUT);      // sets the motion sensor digital pin as input
                                          digitalWrite(DIGITAL_INPUT_SENSOR,HIGH);   // Activate internal pull-up
                                          check_batt();
                                          if (pinTriggered)
                                        	Serial.println(millis()-lastDebounceTime);
                                        	boolean value = digitalRead(DIGITAL_INPUT_SENSOR);
                                        	// If the switch changed, due to noise or pressing
                                        	if (value != oldValue) {
                                        		lastDebounceTime = millis();
                                        		battLoop++;
                                        		oldValue = value;
                                        		Serial.print("Mot: ");
                                        		Serial.println(value);
                                        	pinTriggered=0;
                                        	  if (!metric)
                                        	  battLoop++;
                                        	  lastHum = humidity;
                                        	  battLoop++;
                                        	if (battLoop > 10)
                                        	  check_batt();
                                        	  battLoop=0;
                                          pinTriggered = gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                                        void check_batt()
                                          // get the battery Voltage
                                          Serial.println(sensorValue);
                                          Serial.print(batteryV);
                                          Serial.println(" V");
                                          Serial.print(batteryPcnt);
                                          Serial.println(" %");
                                        	// Power up radio after sleep
                                        	oldBatteryPcnt = batteryPcnt;
                                        T C 2 Replies Last reply
                                        • W
                                          W
                                          waynehead99
                                          How did you get 3 options for the sleep interrupt? Whenever I would try and add the sleep_time option it would give me compile errors.
