  3. best way to develop for stable and development branch
6 Posts 3 Posters 2.4k Views 2 Watching
  • FotoFieberF
    FotoFieberF
    FotoFieber
    In my actual setup I user Arduino IDE 1.6 and mysensors with the 1.4 API (Mac OSX)
    Now I like to play with the development branch. This should not affect my stable sketches.
    Which is the best way to do this?
    Ideas:
    • cp config-files at startup to set different sketchbook folders
    • install IDE multiple times :-1:
    • change to a more professional IDE
    It would be cool to have all libraries in the project folder and no dependencies between them (as it usual in eclipse or visual studio).
    Any ideas appreciated...
    FotoFieber
      If you use git, all you have to do is
      git checkout master
      or
      git checkout development
      to switch between branches.
      I have a soft folder link from the git project to Documents/Arduino.
      • FotoFieberF
        FotoFieberF
        FotoFieber
        If I use github, I can not use the two branches at the same time, isn't it? (Development branch for sketch A and stable branch for sketch B.) I would have to check in and check out between editing sketch A and B? Or do I miss something?
          No, you are right. You cannot work on them simultaneously using the same Arduino IDE.
          • FotoFieberF
            FotoFieberF
            FotoFieber
            Found the Eclipse Arduino Plugin
            Libraries are on a project base and you can have multiple open projects.
            Usage is not straight forward but I think I will get used to it.
            • blaceyB
              blaceyB
              blacey
              Checkout git stash and git merge...
