  3. Scene Controller problem
15 Posts 4 Posters 5.5k Views 1 Watching
  • V
    V
    vampircik
    AWIA 1 Reply Last reply
    • V vampircik
      AWIA
      AWIA
      AWI
      @vampircik Try setting the baud rate to 115200 to get any info on the serial port... (unless you changed the baud rate in the sketch). From what I see in the screen dump you are typing "serial.println" in the serial monitor. I guess what @hek meant was to add Serial.println() messages in the the sketch you are running.. ;-)
      • V
        V
        vampircik
        Serial.println() messages why?
        • mikeeM
          mikeeM
          mikee
          I had same problem with mega (clone) - tried to program relay and temp node on mega - all over "check wire", and when i switched to uno did compile.
          • V
            V
            vampircik
            I installed on Megu examples from libraries all work on the screen shows all. but this sketch nehochet.I wanted to know.
              The error message you see means that mysensors-library is unable to initialise the radio. Did you enabled soft-spi according to the instructions on the build page?
              • V
                V
                vampircik
                I need to do with these files?MySensors / утилиты / RF24_config.h. I know a little something but there is a great desire to understand.
                • V
                  V
                  vampircik
                  how to turn it on SOFTSPI in RF24_config.h.?
                    To enable soft-spi you just have to edit RF24_config.h which can be found in your XXX/libraries/MySensors/utility folder. Just remove the commented slashes (//) before "#define SOFTSPI".
                    NOTE: This change must be reverted back when you have compiled and uploaded code to your scene controller. The normal sensors don't need SOFTSPI enabled.
                    • V
                      V
                      vampircik
                      Thanks it worked. you are super
