  3. multiple DS18D20 does not report temperature
27 Posts 4 Posters 13.6k Views 2 Watching
  • Tomasz PazioT
    Tomasz PazioT
    Tomasz Pazio
    made all accept debug log.
    unfortunately fail, next thing, last update time change only after re-plug arduino, it is not changing recurrently every 30000ms
    • Tomasz PazioT
      Tomasz PazioT
      Tomasz Pazio
      and log
      sensor started, id 3
      send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
      send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
      read: 0-0-3 s=255,c=3,t=6,pt=0,l=1:M
      send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=18,st=ok:Temperature Sensor
      send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
      send: 3-3-0-0 s=0,c=0,t=6,pt=0,l=5,st=ok:1.4.1
      send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
      • Tomasz PazioT
        Tomasz PazioT
        Tomasz Pazio
        Today after vera update I do not have any readings from temp.sensors on onewire eaven one...
        when using "generic " example for arduino all sensors are reported.
        Something wrong with this example :(
          From the log above it looks like at least 2 temp-sensors were found (and presented) to your controller.
          • Tomasz PazioT
            Tomasz PazioT
            Tomasz Pazio
            so something wrong with presenting readings :( what to check on vera side?
              If you continue monitoring the nodes log. Does it send anything after the log you posted above?
              • Tomasz PazioT
                Tomasz PazioT
                Tomasz Pazio
                no, only this one, and nothing else.
                  That seems wrong.
                  What if you update the libraries and sketch to latest on github. There was an update to the Onewire/Dallas library recently to make in none-blocking...
                  • Tomasz PazioT
                    Tomasz PazioT
                    Tomasz Pazio
                    log is now different
                    send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                    send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                    read: 0-0-3 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
                    send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                    send: 3-3-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                    send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                    but still no readings on vera :(
                      I cannot see any temp readings in the debug log...
                      Are you powering your 9 Dallas sensors directly from the Arduino or separately? I'm not sure how much they draw but 9 is quite much...
                      • Tomasz PazioT
                        Tomasz PazioT
                        Tomasz Pazio
                        Now trying with one and two. No more.
                        • Tomasz PazioT
                          Tomasz PazioT
                          Tomasz Pazio
                          There are two parts of issue:
                          problem with no data on vera was on this part:
                          #if COMPARE_TEMP == 1
                          my reading is now -127.00
                          changed to -200 and now I can see the data on vera.
                          however this is not correct data because should be something like 27 Celsius.
                          so there is something with conversion as well :(
                            -127 means something is wrong when reading your dallas sensors. It is a an error code. So you actually only have an issue with your temp sensors.
                            • Tomasz PazioT
                              Tomasz PazioT
                              Tomasz Pazio
                              when I use Example for Dallas multiple sensors it works fine.
                              when I use example for one-wire temperature sensor ds18.... it works fine as well
                              so i can reed but can not use Mysensors sketch :(
                                Very strange. Are you using the same OneWire library in both cases?
                                • Tomasz PazioT
                                  Tomasz PazioT
                                  Tomasz Pazio
                                  yes the same.
                                  • Tomasz PazioT
                                    Tomasz PazioT
                                    Tomasz Pazio
                                    any idea?
                                      No, must be hundreds of users running Dallas sensors here. Trying to figure out if anything has changed in the library/dependencies but I don't see anything except the thing I mentioned earlier here.
                                      And you can get the sensor running without MySensors library loaded...
                                      Guess I have to hook up a Dallas sensor myself to check (tomorrow or so..)
                                      • rvendrameR
                                        rvendrameR
                                        rvendrame
                                        Are you powering your Dallas sensor using the 'one-wire' method? Is your arduino 5V or 3.3V?
                                        ESP8266 GW + mySensors 2.3.2
                                        Alexa / Google Home
                                        • Tomasz PazioT
                                          Tomasz PazioT
                                          Tomasz Pazio
                                          wrote on last edited by Tomasz Pazio
                                          #22
                                          exactly like o the example so power from arduino 5V (not parasite)
