  3. multiple DS18D20 does not report temperature
27 Posts 4 Posters 13.6k Views 2 Watching
  • Tomasz PazioT
    Tomasz PazioT
    Tomasz Pazio
    so something wrong with presenting readings :( what to check on vera side?
      If you continue monitoring the nodes log. Does it send anything after the log you posted above?
      • Tomasz PazioT
        Tomasz PazioT
        Tomasz Pazio
        no, only this one, and nothing else.
          That seems wrong.
          What if you update the libraries and sketch to latest on github. There was an update to the Onewire/Dallas library recently to make in none-blocking...
          • Tomasz PazioT
            Tomasz PazioT
            Tomasz Pazio
            log is now different
            send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
            send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
            read: 0-0-3 s=255,c=3,t=6,pt=0,l=1,sg=0:M
            send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
            send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
            send: 3-3-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
            send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
            but still no readings on vera :(
              I cannot see any temp readings in the debug log...
              Are you powering your 9 Dallas sensors directly from the Arduino or separately? I'm not sure how much they draw but 9 is quite much...
              • Tomasz PazioT
                Tomasz PazioT
                Tomasz Pazio
                Now trying with one and two. No more.
                • Tomasz PazioT
                  Tomasz PazioT
                  Tomasz Pazio
                  There are two parts of issue:
                  problem with no data on vera was on this part:
                  #if COMPARE_TEMP == 1
                  my reading is now -127.00
                  changed to -200 and now I can see the data on vera.
                  however this is not correct data because should be something like 27 Celsius.
                  so there is something with conversion as well :(
                    -127 means something is wrong when reading your dallas sensors. It is a an error code. So you actually only have an issue with your temp sensors.
                    • Tomasz PazioT
                      Tomasz PazioT
                      Tomasz Pazio
                      when I use Example for Dallas multiple sensors it works fine.
                      when I use example for one-wire temperature sensor ds18.... it works fine as well
                      so i can reed but can not use Mysensors sketch :(
                        Very strange. Are you using the same OneWire library in both cases?
                        • Tomasz PazioT
                          Tomasz PazioT
                          Tomasz Pazio
                          yes the same.
                          • Tomasz PazioT
                            Tomasz PazioT
                            Tomasz Pazio
                            any idea?
                              No, must be hundreds of users running Dallas sensors here. Trying to figure out if anything has changed in the library/dependencies but I don't see anything except the thing I mentioned earlier here.
                              And you can get the sensor running without MySensors library loaded...
                              Guess I have to hook up a Dallas sensor myself to check (tomorrow or so..)
                              • rvendrameR
                                rvendrameR
                                rvendrame
                                Are you powering your Dallas sensor using the 'one-wire' method? Is your arduino 5V or 3.3V?
                                ESP8266 GW + mySensors 2.3.2
                                Alexa / Google Home
                                • Tomasz PazioT
                                  Tomasz PazioT
                                  Tomasz Pazio
                                  wrote on last edited by Tomasz Pazio
                                  #22
                                  exactly like o the example so power from arduino 5V (not parasite)
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    Can you post the serial monitor logs, from both gateway and node?
                                    Alexa / Google Home
                                    • Tomasz PazioT
                                      Tomasz PazioT
                                      Tomasz Pazio
                                      @rvendrame, why You need log from gateway? When no values are sent from node than nothing on Vera. When use some dummy values which are visible in node log - than those values are in Vera.
                                        Ok, tried latest from 1.5 branch and it works fine here with 2 hooked up DS18D20.
                                        sensor started, id=200, parent=0, distance=1
                                        send: 200-200-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
                                        send: 200-200-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                                        send: 200-200-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                        send: 200-200-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                        send: 200-200-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:27.9
                                        send: 200-200-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:28.0
                                        send: 200-200-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:31.5
                                        send: 200-200-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:32.0
                                        • Tomasz PazioT
                                          Tomasz PazioT
                                          Tomasz Pazio
                                          removed all Arduino related stuff from PC
                                          Installed new IDE and libs from https://github.com/mysensors/Arduino/archive/master.zip
                                          now I have progress, there are no readings no mater on which sketch hahaha.
