  3. multiple DS18D20 does not report temperature
27 Posts 4 Posters 13.6k Views 2 Watching
    From the log above it looks like at least 2 temp-sensors were found (and presented) to your controller.
    • Tomasz PazioT
      Tomasz PazioT
      Tomasz Pazio
      so something wrong with presenting readings :( what to check on vera side?
        If you continue monitoring the nodes log. Does it send anything after the log you posted above?
        • Tomasz PazioT
          Tomasz PazioT
          Tomasz Pazio
          no, only this one, and nothing else.
            That seems wrong.
            What if you update the libraries and sketch to latest on github. There was an update to the Onewire/Dallas library recently to make in none-blocking...
            • Tomasz PazioT
              Tomasz PazioT
              Tomasz Pazio
              log is now different
              send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
              send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
              read: 0-0-3 s=255,c=3,t=6,pt=0,l=1,sg=0:M
              send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
              send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
              send: 3-3-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
              send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
              but still no readings on vera :(
                I cannot see any temp readings in the debug log...
                Are you powering your 9 Dallas sensors directly from the Arduino or separately? I'm not sure how much they draw but 9 is quite much...
                • Tomasz PazioT
                  Tomasz PazioT
                  Tomasz Pazio
                  Now trying with one and two. No more.
                  • Tomasz PazioT
                    Tomasz PazioT
                    Tomasz Pazio
                    There are two parts of issue:
                    problem with no data on vera was on this part:
                    #if COMPARE_TEMP == 1
                    my reading is now -127.00
                    changed to -200 and now I can see the data on vera.
                    however this is not correct data because should be something like 27 Celsius.
                    so there is something with conversion as well :(
                      -127 means something is wrong when reading your dallas sensors. It is a an error code. So you actually only have an issue with your temp sensors.
                      • Tomasz PazioT
                        Tomasz PazioT
                        Tomasz Pazio
                        when I use Example for Dallas multiple sensors it works fine.
                        when I use example for one-wire temperature sensor ds18.... it works fine as well
                        so i can reed but can not use Mysensors sketch :(
                          Very strange. Are you using the same OneWire library in both cases?
                          • Tomasz PazioT
                            Tomasz PazioT
                            Tomasz Pazio
                            yes the same.
                            • Tomasz PazioT
                              Tomasz PazioT
                              Tomasz Pazio
                              any idea?
                                No, must be hundreds of users running Dallas sensors here. Trying to figure out if anything has changed in the library/dependencies but I don't see anything except the thing I mentioned earlier here.
                                And you can get the sensor running without MySensors library loaded...
                                Guess I have to hook up a Dallas sensor myself to check (tomorrow or so..)
                                • rvendrameR
                                  rvendrameR
                                  rvendrame
                                  Are you powering your Dallas sensor using the 'one-wire' method? Is your arduino 5V or 3.3V?
                                  ESP8266 GW + mySensors 2.3.2
                                  Alexa / Google Home
                                  • Tomasz PazioT
                                    Tomasz PazioT
                                    Tomasz Pazio
                                    wrote on last edited by Tomasz Pazio
                                    #22
                                    exactly like o the example so power from arduino 5V (not parasite)
                                    • rvendrameR
                                      rvendrameR
                                      rvendrame
                                      Can you post the serial monitor logs, from both gateway and node?
                                      Alexa / Google Home
                                      • Tomasz PazioT
                                        Tomasz PazioT
                                        Tomasz Pazio
                                        @rvendrame, why You need log from gateway? When no values are sent from node than nothing on Vera. When use some dummy values which are visible in node log - than those values are in Vera.
                                          Ok, tried latest from 1.5 branch and it works fine here with 2 hooked up DS18D20.
                                          sensor started, id=200, parent=0, distance=1
                                          send: 200-200-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
                                          send: 200-200-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                                          send: 200-200-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                          send: 200-200-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                          send: 200-200-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:27.9
                                          send: 200-200-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:28.0
                                          send: 200-200-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:31.5
                                          send: 200-200-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:32.0
