  3. multiple DS18D20 does not report temperature
27 Posts 4 Posters 13.6k Views 2 Watching
    That seems wrong.
    What if you update the libraries and sketch to latest on github. There was an update to the Onewire/Dallas library recently to make in none-blocking...
    • Tomasz PazioT
      Tomasz PazioT
      Tomasz Pazio
      log is now different
      send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
      send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
      read: 0-0-3 s=255,c=3,t=6,pt=0,l=1,sg=0:M
      send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
      send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
      send: 3-3-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
      send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
      but still no readings on vera :(
        I cannot see any temp readings in the debug log...
        Are you powering your 9 Dallas sensors directly from the Arduino or separately? I'm not sure how much they draw but 9 is quite much...
        • Tomasz PazioT
          Tomasz PazioT
          Tomasz Pazio
          Now trying with one and two. No more.
          • Tomasz PazioT
            Tomasz PazioT
            Tomasz Pazio
            There are two parts of issue:
            problem with no data on vera was on this part:
            #if COMPARE_TEMP == 1
            my reading is now -127.00
            changed to -200 and now I can see the data on vera.
            however this is not correct data because should be something like 27 Celsius.
            so there is something with conversion as well :(
              -127 means something is wrong when reading your dallas sensors. It is a an error code. So you actually only have an issue with your temp sensors.
              • Tomasz PazioT
                Tomasz PazioT
                Tomasz Pazio
                when I use Example for Dallas multiple sensors it works fine.
                when I use example for one-wire temperature sensor ds18.... it works fine as well
                so i can reed but can not use Mysensors sketch :(
                  Very strange. Are you using the same OneWire library in both cases?
                  • Tomasz PazioT
                    Tomasz PazioT
                    Tomasz Pazio
                    yes the same.
                    • Tomasz PazioT
                      Tomasz PazioT
                      Tomasz Pazio
                      any idea?
                        No, must be hundreds of users running Dallas sensors here. Trying to figure out if anything has changed in the library/dependencies but I don't see anything except the thing I mentioned earlier here.
                        And you can get the sensor running without MySensors library loaded...
                        Guess I have to hook up a Dallas sensor myself to check (tomorrow or so..)
                        • rvendrameR
                          rvendrameR
                          rvendrame
                          Are you powering your Dallas sensor using the 'one-wire' method? Is your arduino 5V or 3.3V?
                          ESP8266 GW + mySensors 2.3.2
                          Alexa / Google Home
                          • Tomasz PazioT
                            Tomasz PazioT
                            Tomasz Pazio
                            wrote on last edited by Tomasz Pazio
                            #22
                            exactly like o the example so power from arduino 5V (not parasite)
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              Can you post the serial monitor logs, from both gateway and node?
                              Alexa / Google Home
                              • Tomasz PazioT
                                Tomasz PazioT
                                Tomasz Pazio
                                @rvendrame, why You need log from gateway? When no values are sent from node than nothing on Vera. When use some dummy values which are visible in node log - than those values are in Vera.
                                  Ok, tried latest from 1.5 branch and it works fine here with 2 hooked up DS18D20.
                                  sensor started, id=200, parent=0, distance=1
                                  send: 200-200-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
                                  send: 200-200-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                                  send: 200-200-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                  send: 200-200-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                  send: 200-200-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:27.9
                                  send: 200-200-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:28.0
                                  send: 200-200-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:31.5
                                  send: 200-200-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:32.0
                                  • Tomasz PazioT
                                    Tomasz PazioT
                                    Tomasz Pazio
                                    removed all Arduino related stuff from PC
                                    Installed new IDE and libs from https://github.com/mysensors/Arduino/archive/master.zip
                                    now I have progress, there are no readings no mater on which sketch hahaha.
                                    • clio75C
                                      clio75C
                                      clio75
                                      I have the same problem. No temperature is transported to GW.
                                      This log is from Sensor:
                                      req id
                                      sensor started, id=255, parent=0, distance=1
                                      req id
                                      req id
                                      req id
                                      I have added some exstra lines in serial printout so I know that ds1820 is found and read.
                                      req id
                                      req id
                                      req id
                                      **Sensors found
                                      **req id
                                      temp :
                                      23.80
                                      But This value is not transported to GW.
                                      Any idee ?
                                      Thanx
