  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.2k Views 73 Watching
  • 5546dug5
    5546dug5
    5546dug
    @tekka silly ?
    But still last night changed from serial to Ethernet gw using iboard wiz5100 and the h/w changes.
    No issues but for later problems do I ---use myscontroller by way of FTDI connector>usb or
    -- continue to plug the original serial gw into laptop leaving Ethernet still in use ( plugged in).
    tekkaT 1 Reply Last reply
    • 5546dug5 5546dug
      @tekka silly ?
      tekkaT
      tekkaT
      tekka
      @5546dug said:
      @tekka silly ?
      I'm not quite sure I understand your question. Are you having issues with the EthernetGW?
      • 5546dug5
        5546dug5
        5546dug
        @tekka No everything is ok now but there will be problems in the future to sort out if history repeats itself.
        So it is just a learning question for troubleshooting later.
        To "see" Ethernet gw in your gui use FDTI>usb>laptop (with gw still connected to the router) or use the serial gw I had from before connected remotely to laptop via usb..
        As of now I use only Ethernet gw plugged into router and the serial gw is no longer plugged into my vera.
        • C cdr
          @tekka I feel really, really, REALLY stupid;
          I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
          D'OH
          Thanks for your patience and help, everything is working now and I'm really happy!
          :+1:
          N
          N
          NewFolk
          D'OH
          :+1:
          @tekka is there a way to change the default channel in MYSbootloader ?
          • P
            P
            Pendragon
            What ware the designed values for "type" in the fimware_config.csv?
            Can I use this variable for my sensor IDs?
            • rvendrameR
              rvendrameR
              rvendrame
              @tekka, I've being playing with MYSController and MYSBootloader over last days, I'm totally amazed by them ;-) Thank you so much for developing such nice tool!
              If you allow me, I have only one ask for the santa-claus list: Perhaps it is possible for MYSBootloader capture serial output from a node, allowing OTA Serial monitor via MYSController? I know you guys are doing a miracle within 2KB, but who knows...
              Again, thanks a lot!
              ESP8266 GW + mySensors 2.3.2
              Alexa / Google Home
              • N NewFolk
                D'OH
                :+1:
                tekkaT
                tekkaT
                tekka
                Yes, but for that you'll have to re-compile it.
                N 1 Reply Last reply
                • P Pendragon
                  tekkaT
                  tekkaT
                  tekka
                  Yes, but this is only an internal reference and not being used for AutoFW assignment
                    #198
                    This sounds like a great app! What is the current status? I clicked on the link in the OP expecting it would connect with GitHub (where there might be a ReadMe.txt which tells what the current status is), but instad of that it just downloaded the app right then and there! There are now 197 posts on this thread, which is a bit many to sort through to find the status....
                    Move it to Github?
                    • rvendrameR rvendrame
                      tekkaT
                      tekkaT
                      tekka
                      Thanks, I'm glad you like the tools. :)
                      Unfortunately your suggestion is not possible: bootloader and sketch run sequentially, not in parallel, and thus, cannot communicate with each other.
                        Move it to Github?
                        tekkaT
                        tekkaT
                        tekka
                        @NeverDie said:
                        This sounds like a great app! What is the current status? I clicked on the link in the OP expecting it would connect with GitHub (where there might be a ReadMe.txt which tells what the current status is), but instad of that it just downloaded the app right then and there! There are 197 posts on this thread, which is a bit many to sort through to find the status....
                        Move it to Github?
                        The first post is updated once a new version is released :)
                        • tekkaT tekka
                          Move it to Github?
                          #201
                          @tekka said:
                          Move it to Github?
                          So then, as far as status goes, based on the version number, I guess it's still an unstable alpha release? Am I reading between the lines correctly?
                          I did download it, and I can see that the files are from 7/25/2015, but there's no readme or other indication as to its status.
                          I imagine others probably have the same question....
                            @tekka said:
                            Move it to Github?
                            tekkaT
                            tekkaT
                            tekka
                            @NeverDie No, just never felt to change the major version number...I'll add it to the feature requests :)
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              Maybe by re-implementing serial.print methods, in order to first checking which FW is installed, and if MYSBootloader, re-direct the output to a internal radio message? Just brainstorming....
                              Alexa / Google Home
                              • tekkaT tekka
                                N
                                N
                                NewFolk
                                @tekka
                                Could you help me to find where to change channel? It is in MYSBootloaderHW.h ?
                                • P
                                  P
                                  Pendragon
                                  Du you all connect the controller direct to the gateway?
                                  I have a serial gateway which is connected directly to a raspberry running domoticz. I can rum ser2net and then connect the MYSController via ethernet. While ser2net is running, domoticz does not get any data from the gateway.
                                  Has anyone found a solution to use both, MYSController and a controller software (e.g. domoticz) in parallel?
                                  • N NewFolk
                                    @tekka
                                    tekkaT
                                    tekkaT
                                    tekka
                                    No, it's defined in MyConfig.h (see here)
                                      tekkaT
                                      tekkaT
                                      tekka
                                      I like the idea, but again, the bootloader cannot handle that.
                                      However, we may think about implementing an OTA serial monitor in the library, let's say re-routing the serial output and transmit it via a dedicated debug sensor instance back to the GW...@hek, what do you think about that?
                                        Hmm.. One idea is that you could enable nodes to broadcast (they are not being routed/retransmitted) log data as internal (I_LOG) messages.
                                        Gateway would pick up these messages if node is in range and just log them to controller.
                                        • G
                                          G
                                          gonzalonal
                                          wrote on last edited by gonzalonal
                                          #209
                                          Hi Tekka.
                                          Great software, thanks for sharing.
                                          I 've being doing some tests and found a problem that seems to be related to my own sketches.
                                          When I upload through OTA the TimeReporter sketch, it uploads fine, and I am able to change the firmware afterward for another one.
                                          But when I upload my own sketch, It uploads fine, and works fine, but it stops to answer MYScontroller commands, such as reboot or assing firmware. So I am stuck with that sketch in that node. To flash another sketch in that node, I have to reflash MYSBootloader again via usbASP and later on, upload the desire sketch wit MYSController.
                                          Am I skiping something in my code that allows MYSBootloader to respond to MYSController commands?
                                          Could you please upload the TimeReporter.ino sketch as example of a working sketch with MYSController/MYSBootloader?
                                          Thanks, regards!
                                          Gonzalo
