  3. Antenna 101
Antenna 101
27 Posts 9 Posters 23.0k Views 3 Watching
  • D Offline
    Damme
    Code Contributor
    wrote on last edited by Damme
    Hello guys!
    I am no expert at antennas but I realize some of you have really bad reception.
    I got ~450 meters between my nrf24l01+ap and a regular nrf24l01, and this through the house (concrete + wood) and through a forest.
    There are some things to take in count;
    Antenna orientation, if your gateway (with external antenna) is pointing straight up you have a vertical polarization of your transmission, this basically means that your nodes will work best if they also are vertical.
    The radiation-pattern from the external antenna looks like this: http://commons.wikimedia.org/wiki/File:Short_dipole_radiation_pattern.gif
    This means in a ideal location with no walls and you were floating in space you basically don't have any reception at all straight above or below the gateway. but since radio waves also reflect from objects you just have very poor reception in the real world.
    And looking at the radiation-pattern you'll see that you have the best reception in the blue circles. (and the antennas on your internet router should be pointing straight up if you dont have a multi floor building.)
    And because the radio waves reflect, the distance to cables, metal and ground-plane on a pcb matters a lot, if you have wrong distance, you can cancel out the signal almost completely, and you could actually amplify the signal in one direction by having the correct distance. (1/2 wave length = ~61mm if I'm not totally lost today) This is how parabolics works.
    Well this is just a very short beginners knowledge and please, correct me and fill in missing facts. I just wanted to get the topic started.. :)
    //Damme
    D C D 4 Replies Last reply
    • E Offline
      E Offline
      epierre
      yes, for my rfxtrx I changed from 1/8 wave to 1/4, but still I had to put a quatetwave on the sensors tjat were poorly emitting...
      ffor nrf24 the long antennae works best for me !
      z-wave - Vera -> Domoticz
      • D Damme
        Hello guys!
        //Damme
        daulagari
        @Damme
        On:
        Just wondering, what is a "nrf24l01+ap", is that something like the NRF24L01+PA+LNA SMA Antenna Wireless Transceiver communication module you can find in the shop?
        That description says "This allowed you to use the wireless communication up to 1000 meters! (No barrier)"
        The datasheet of the nRF24L01+ says:
        Sensitivity (0.1% BER) @2Mbps = -82 dBm
        Sensitivity (0.1% BER) @1Mbps = -85 dBm
        Sensitivity (0.1% BER) @250kbps = -94 dBm
        It is not clear to me what the PA delivers, but assuming the link is symmetric, that also does not matter as the link is then very likely limited by the upstream, the path from the normal unit to the one with the PA and LNA.
        Say the output is the normal unit is 0 dBm, the LNA adds 3 dB noise figure (NF) and you are using 1Mbps then the link budget is 88 dB.
        From WiFi I know that for two units that are about one meter apart from each other, the receiver sees something like -20..30 dBm while the transmitter is transmitting at 15 dBm, so 35..45 dB lost in the first meter. After that, the loss in ideal free-space is 6 dB when the distance is doubled; for other environments this is 10 or more dB.
        2^(88/6) = 26007, so 26 km?!
        2^(88/10) = 446, so 446 meter, that's your ~450 meter ;-)
        • D Damme
          Hello guys!
          //Damme
          C Offline
          C Offline
          clippermiami
          @Damme
          I'd give real money for anything approach half of that :). The besI I've been able to get so far between a NRF24L01+PA and a NRF24L01 is about 15 feet through a single interior wall!. I've tried everything I can think of, I'm on the verge of just chucking this entire experiment as fun but not so much :)
          I've played with antenna orientation on the sensor and the GW with no difference. I've played with different radios on the sensor, I've moved the sensor radio off the board (ground plane) on a cable, etc., The only time I got anything approaching useful range was to put a NRF24L01+PA+SMA on the sensor and then I was able to get communications from the street, about 30 meters -- It might be further but that proved it was possible so I didn't bother going further away. But of course battery consumption skyrocketed.
          I've tried additional capacitance on the radio, I soldered a 220 UF cap directly on the Vcc and Gnd pins of the module with no change so I suspect that has nothing to do with it.
          • C Offline
            C Offline
            clippermiami
            @Damme
            After your discussion of the antenna It occurred to me that the one thing I had not changed was the GW radio. I had one spare NRF24L01+PA+SMA so I swapped it in the GW. That appears to be the fix --- I can now see the sensor module all the way out in the yard at the far end of the house, through outside walls and a half dozen interior walls. I doubt i'll get the ~450 meters you describe but its a LOT better than the 10 feet I was getting :)
            I've found a NRF24L01 without the PA but with a SMA antenna so I think i'll see about adopting that for the sensors, especially the battery sensors. No amplifier but it is a 2-3 dBi antenna and every little dBi helps :)
            Y 1 Reply Last reply
            • C clippermiami
              @Damme
              Y Offline
              Y Offline
              @clippermiami @hek This is one for the troubleshooting section! Could have saved you (and us ;-) ) a lot of time!
              M C 2 Replies Last reply
              • Y Yveaux
                M Offline
                M Offline
                marceltrapman
                @Yveaux I can split it up but you have to tell me at which point.
                Fulltime Servoy Developer
                • M marceltrapman
                  Y Offline
                  Y Offline
                  @marceltrapman I mean there's a toubleshooting section in the regular MySensors site (Building stuff -> Miscellaneous -> Troubleshooting).
                  There could also be some help when your sensors aren't performing as expected (very short range etc.).
                  E.g.
                  • Exchange the nRF24 module of both gateway & sensor with known-good or new ones.
                  • Try different antenna orientation
                  • ...Whatever else comes from this thread...
                  • Y Yveaux
                    C Offline
                    C Offline
                    clippermiami
                    @Yveaux I honestly wish it had occurred to me too. But it didn't. Now as luck would have it, it looks like the USB port on my Vera Lite, where I have the Arduino, has packed it in. I can't even get it to recognize a flash drive any longer. So now I'm stuck until I solve that problem :-(
                    I have ordered some NRF24L01 units with SMA antennas, no Amps however, for use on battery sensors ... +2-3 dBi may help
                    • Z Offline
                      Z Offline
                      Zeph
                      wrote on last edited by Zeph
                      @Damme
                      I understand the radiation pattern from the external antenna and the polariztion, that's pretty standard.
                      But what is the pattern from the two on-PCB antenna types? (sometimes referred to as zigzag and question mark or seven; I wouldn't assume they have the same pattern). Where are the (relative) peaks and nulls, what is the polarization?
                      Anybody have any idea?
                      @clippermiami
                      I'm glad you finally resolved it, after gamely trying every suggestion that we could come up with.
                      I'll be curious to know if the non-PA external antenna helps. In theory it should have a bit of gain (when oriented for the same polarization) but some have reported it working less well than the on-PCB antennas.
                      • A Offline
                        A Offline
                        a-lurker
                        wrote on last edited by a-lurker
                        There are all sorts of magical antenna shapes - a few examples here:
                        http://www.ti.com/lit/an/swra351a/swra351a.pdf
                        The PCBs with the zigzag shape
                        http://www.barefootelectronics.com/nordicc.png
                        are probably a "meandering inverted F antenna" similar to this one:
                        http://www.ti.com/lit/an/swra117d/swra117d.pdf
                        The PCBs with the seven shaped antenna is probably just a 1/4 wave monopole bent to make it less sensitive to polarization?
                        http://www.barefootelectronics.com/NordicA.jpg
                        Hard to say what the rubber ducks use unless pulled apart. It's easy to just assume they are all interchangeable. They aren't - they are designed specifically for the frequency to be used. This one is a dipole with the associated doughnut radiation pattern:
                        http://martybugs.net/wireless/rubberducky.cgi
                        D 1 Reply Last reply
                        • A a-lurker
                          Damme
                          Code Contributor
                          @a-lurker Nice post!
                          I can report that I changed the SMA antenna that came with the songle with a +8db gain 2.4ghz wlan antenna and the signal died out completly, I think I'll will dissect the original antenna just to look why the bigger one didnt work at all..
                          maybe that's your problem @clippermiami ? try the old module but with the working antenna.
                          C Z 2 Replies Last reply
                          • D Damme
                            C Offline
                            C Offline
                            clippermiami
                            @Damme Possible. But now I have another problem, the USB port has died so I no longer have access to the Gateway :-) Yet another opportunity :-)
                            • D Damme
                              Z Offline
                              Z Offline
                              Zeph
                              I don't know why it didn't work, but even it it had, I'd be wary of a +8db gain antenna in this application. The gain comes with the tradeoff of a narrower beam and more directionality, and for home automation I don't want that.
                              • D Offline
                                Damme
                                Code Contributor
                                I have started building up lots of nodes and don't even use a cap any longer. The problem I had with reception is purely because long cables. now I'm using <2cm and have no problems at all.
                                • D Damme
                                  Y Offline
                                  Y Offline
                                  You mean the SPI connection between MPU & nRF24 I assume?
                                  • Y Yveaux
                                    Damme
                                    Code Contributor
                                    @Yveaux yep!
                                    • P Offline
                                      P Offline
                                      petewill
                                      I posted about this earlier but I think it was lost.
                                      Disclaimer: I am no expert but this seems to be working for me... I have been experimenting with adding a wire to my regular nRF24L01 radio chips. I have the chips with the zig zag patteren. Based on some limited reading the wavelength is of 2.4 GHz is 4.92 inches (http://www.antenna-theory.com/definitions/2p4GHzAntenna.php). I did some rough measurements of the zig zag pattern with micrometer and found that the length is about 1.64 inches. So, based on that I soldered a 3.28 inch piece of CAT5e to the end of the zig zag pattern.
                                      I had a new node that I installed on Sunday night that wasn't communicating with the gateway at all. I replaced the nRF24L01 with my modified one on Monday night and it has been communicating perfectly all night.
                                      I should probably note that my new node had the radio zig zag pattern parallel to the ground which may have also caused some of the communication problems. I wasn't able to easily move the orientation because of how it was mounted, so the antenna was a quick test that appears to have solved the problem.
                                      I have another node in which I have achieved similar results in a totally different part of my house.
                                      Note: this also seems to be working for other people. See the comments of this blog post:http://harizanov.com/2013/06/nrf24l01-range-testing/
                                      Based on the above post the PA+SMA antenna still has better range, but the CAT5 hack is much cheaper :)
                                      I'd be interested to hear if this works for anyone else.
                                      Pete
                                      Z 1 Reply Last reply
                                      • P petewill
                                        Pete
                                        Z Offline
                                        Z Offline
                                        Zeph
                                        @petewill
                                        I'm glad you resurfaced that lost discussion.
                                        Did you take a look at the references posted by @a-lurker about magical antenna shapes? A device similar to the zig-zag nRF was well measured in different planes and polarization and it'a all over the board - peaks and nulls in all sorts of directions.
                                        But the zigzag isn't a random thing, it's carefully computed for a given wavelength and impedance. When you are bending and splitting and changing trace widths, the linear length for best matching is no longer as simple to compute as with a simple wire antenna. It's not that they forgot to add the last 3.28 inches, it's that their computations told them they had already reached a good compromise for coverage and making it longer would make it worse.
                                        It's still surprising that soldering a loose wire to some location along the zig-zag so substantially improved your antenna performance. I still suspect some luck was involved, and I would not suggest it unless other solutions didn't work or were not available (eg: changing the antenna orientation). But if it works sometimes (not rarely), then it's useful on the practical level (and a fun puzzle on the theoretic level).
                                        And I'd love to hear the take that better antenna experts than I have on your experience.
                                        I am reminded of my youth, when people would hang aluminum foil fragments on the coat hanger substituting for the broken half of rabbit ears for the TV, and then try all sorts of positions for both ears, seeking better reception. :-) To the degree that this worked (vs just giving a perception of doing something) it was based on doing all that random adjustment while watching the picture and stopping in the best configuration.
                                        P E 2 Replies Last reply
                                        • Z Zeph
                                          @petewill
                                          P Offline
                                          P Offline
                                          petewill
                                          @Zeph Yeah, I'm definitely open to the possibility of dumb luck. I feel that's how I've built my whole sensor network. :) I hope that I will get a better understanding of things as I keep learning but for now it is mostly trial and error.
                                          I have a feeling the bad signal could probably have been corrected by changing the orientation of the radio but soldering one wire was MUCH faster so I thought I'd give it a shot. It has been working flawlessly since I made that change. Luck or whatever, I'm happy... :)
                                          12.2k
