  3. Adjust time?
Adjust time?
19 Posts 8 Posters 11.0k Views 1 Watching
    No, it doesn't.
    • M moffen666
      This is from the Domoticz forum:
      At the moment this is used:
      case I_TIME:
      //send time in seconds from 1970 with timezone offset
      time_t atime = mytime(NULL);
      struct tm ltime;
      localtime_r(&atime, &ltime);
      sstr << mktime(&ltime);
      SendCommand(node_id, child_sensor_id, message_type, I_TIME, sstr.str());
      I would expect it to be local time now
      If your gateway system set to the correct timezone ?
      Does the serial gateway modify the time before sending it to the nodes/sensors?
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      UTC is the convention for time sync. UTC-local offset has to be adjusted in the callback function.
      (I'm adding this because I had the same issue/request for MYSController: one can choose UTC or local time for sync...)
      AWIA 1 Reply Last reply
        moffen666
        Thx tekka
        Im way in over my head here, but do I adjust the callback function in my Irrigation controller sketch.
        The time reported from my sensors in the webUI is correct its only the time on my LCD in the irrigation controller that's off -2h.
        Regards
        • M moffen666
          Thx tekka
          Regards
          @moffen666 when doen right, it should be fixed in the gateway. Otherwise you need to adjust in all sensors and run into problemen when daylight-saving changes.
          • tekkaT tekka
            AWIA
            AWIA
            AWI
            I am a little confused and running into the time difference issue. What is the 'standard' for the controller to report time?
              If we want to be able to use the same (unmodified) sketch all over the world, I'd put my vote for letting the controller sending out local time (time adjusted).
              I do it like that in the Vera plugin anyway.
                AWIA
                AWIA
                AWI
                @moffen666 @hek Solved in latest beta of Domoticz thanks to very quick reaction of @GizMoCuz . Domoticz was sending UTC
                • C
                  C
                  chefkooch
                  I've got the same problem with Fhem. Does anybody know where to change that in the fhem Module?
                    moffen666
                    Amazing, what a great community here and over at Domoticz....
                    Thank you all so much, just makes me glad!
                    Regards
                    • TheoLT
                      TheoLT
                      TheoL
                      wrote on last edited by TheoL
                      Is there a Domoticz fix for this? Because if it's returning UTC, you cannot use the time correctly through out the year. UTC doesn't have summer and winter time correction. This means that you have to recalibrate the time in your sensor, depening on the current date. In my opinion things like that should be handled by the Home Automation Server. But that's just my opinion ;)
                      Ow. Responded to quick. Didn't saw the response of @AWI. I second @moffen666 I love the MySensor and Domoticz community
