  3. How To: Make a Simple/Cheap Scene Controller (with video)
62 Posts 19 Posters 48.8k Views 15 Watching
  • petewillP petewill
    @AWI & @hek thanks, yeah, I have been wanting to play with capacitive touch too! Someday soon hopefully :)
    msebbe
    Cool! What do you think about a battery version of this? (short battery life?)
    • HoffanH
      HoffanH
      Hoffan
      @petewill
      Where did you get your touchpad?
        AWIA
        AWIA
        AWI
        wrote on last edited by AWI
        @petewill To get you started with capacitive: the ones with the TTPxxx chip in 4/8/16 button versions like have pins with leds for every button. Can also generate an interrupt at keypress (so no need to poll the keyboard in low-power applications). And can can also be used with a simple serial protocol (only 2/3 pins needed). I would be happy to supply the code (but don't want to mess-up your great topic any further ;-) )
        • petewillP
          petewillP
          petewill
          @DrJeff Yes, that would be great! Someday...
          @msebbe Yes, this version would have short battery life because it's not sleeping. But, if @AWI posts his code a battery version sounds possible.
          @Hoffan you can get them here: http://www.ebay.com/itm/171505110526?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
          @AWI That would be great if you could supply the code for a capacitive sleeping node! If you could supply the wiring diagram and parts list also I will add it to the first post as another option (giving credit to you of course). Thanks!
          • Tomasz PazioT
            Tomasz PazioT
            Tomasz Pazio
            @petewill really nice thing which can also be a nice solution for "old" people leaving with us.
            I was thinking to use matrix keypad which I own.
            Any help from community? probably analog input should be used as digital input because of missing inputs on nano...
            link
            AWIA petewillP 2 Replies Last reply
            • Tomasz PazioT Tomasz Pazio
              link
              AWIA
              AWIA
              AWI
              @Tomasz-Pazio The keyboard you mention is a standard 4 x 4 matrix keyboard. You can wire it with 8 pins for which you can also use the analog pins. These can be addressed by A0, A1, etc. The library @petewill used in the sketch can handle this keyboard.
                link
                petewillP
                petewillP
                petewill
                @Tomasz-Pazio You will also need to adjust the code as mine is specifically designed to use 4 buttons. It shouldn't be too difficult to modify though.
                • AWIA
                  AWIA
                  AWI
                  Not even close to @petewill 's great build descriptions but here my version the "touch" version which can be battery operated. The used keyboard uses around 150uA. The touch panel generates an interrupt which wakes the arduino, reads the key and swiches a scene.
                  upload-10b4b56c-4f8e-4f43-ac06-69217e48adcb
                  The code below toggles between 'Scene ON' and 'Scene OFF' and stores the last state in EEPROM.
                  All credits to @petewill
                   * Version 1.0 - PeteWill
                   *   	   1.1 - AWI
                   * A simple scene controller for use with MySensors.  8 scenes can be executed
                   *  with an 8 key keypad, make sure to attach the pins and fill keyPins[] resp.
                   * Watch a how to video here: https://youtu.be/KMGj5Bi7vL0
                  #define SN "Scene Controller"
                  #define SV "1.0"
                  #define NODE_ID 14 // or set to AUTO if you want gw to assign a NODE_ID for you.
                  const byte KEYPAD_CHILD_ID = 0 ;
                  MyMessage scene_on(KEYPAD_CHILD_ID, V_SCENE_ON);
                  MyMessage scene_off(KEYPAD_CHILD_ID, V_SCENE_OFF);
                  const int DV = 2;									//DataValid (=key pressed) pin goes there
                  const int DV_int = DV-2;							//DataValid interrupt on pin 3 => 1
                  const unsigned long SLEEP_TIME = 3600000 ;			// sleep for an hour (or more if you want to)
                  volatile boolean DVint = false ; 					// interrupt flag, set by interrupt
                  const byte keyPins[] = {A0, A1, A2, A3, 3, 4, 5, 6};// keypad pins, (8 pin keyboard)
                  byte keyState[8]  ;									// hold current keystate (copy of EEPROM)
                  void setup(){
                  	gw.begin(NULL, NODE_ID);
                  	gw.sendSketchInfo(SN, SV);
                  	gw.present(KEYPAD_CHILD_ID, S_SCENE_CONTROLLER);
                  	pinMode(DV,INPUT);          					// Data Valid (interrupt)
                  	for (int i=0 ; i < sizeof(keyPins); i++){
                  		keyState[i] = gw.loadState(i) ; 			// load last Scenestates from EEPROM
                  // loop only if interrupt, else sleep
                  void loop(){
                      // if so get a key value and send to MySensosrs network
                  	byte key = fetchData();    						// if so fetch key
                      Serial.println(key);							// serial print as binary
                  	if (key > 0){									// (key-1) is used as index
                  		boolean keyVal = !gw.loadState(key-1);		// use lastState from EEPROM and toggle
                  		gw.saveState(key-1, keyVal);				// save new state to EEPROM
                  		if (keyVal) gw.send(scene_on.set(key-1));	// set the Scene On or Off
                  		else gw.send(scene_off.set(key-1));
                      DVint=false;									// reset interrupt flag
                  	gw.sleep(DV_int, RISING, SLEEP_TIME);			// node wakes up on key interrupt or time
                  	Serial.println(" key pressed or time trigger ");
                  // interrupt routine, only sets flag
                  void intrp(){DVint = true;};
                  // fetch serial data, only highest number key is returned
                  byte fetchData(){
                  	int Key=0;                        				// default key = 0 (nothing pressed)
                  	for (byte i = 0 ; i < sizeof(keyPins) ; i++){	// check each key,
                  		if(digitalRead(keyPins[i]) == HIGH) Key=i+1;// set key if pressed (now only highest key)
                  	return Key;										// return Key (0 if no key pressed)
                  petewillP 1 Reply Last reply
                  • Tomasz PazioT
                    Tomasz PazioT
                    Tomasz Pazio
                    ok easy.... two changes and 32 scenes can be managed :)
                    const byte ROWS = 4;
                    const byte COLS = 4;
                    byte rowPins[ROWS] = {3, 4, 5, 6};
                    byte colPins[COLS] = {A0, A1, A2, A3};
                    char keys[ROWS][COLS] = {{'1','2','3','A'},
                                             {'4','5','6','B'},
                                             {'7','8','9','C'},
                                             {'*','0','#','D'}};
                     keyInt = keyInt + 100;
                    • AWIA AWI
                       *   	   1.1 - AWI
                      #define SV "1.0"
                      void setup(){
                      void loop(){
                      byte fetchData(){
                      petewillP
                      petewillP
                      petewill
                      @AWI Excellent, thanks for adding the code for the capacitive touch, battery operated sensor! I added a link to your post in my initial post.
                      • B
                        B
                        brom_snor
                        Hi Petewill
                        I 'd like to build your Scene Controller but I am missing the keypad.h library. Where can I get it?
                        greetings
                        Brom_Snor
                        • B brom_snor
                          Hi Petewill
                          greetings
                          Brom_Snor
                          petewillP
                          petewillP
                          petewill
                          @brom_snor
                          Sorry about that. I thought it was part of the default libraries. I must have downloaded it a while ago. This one should work: http://playground.arduino.cc/Code/Keypad
                          • F
                            F
                            Fred LaR
                            Hi all - Another capacitive version with an "out of the bottle" keypad - 4 buttons. Like AWI's version, also toggles between 'Scene ON' and 'Scene OFF', but states are kept in a variable (keyState) - LEDs added for better toogle visibility. Capacitive routine found at http://www.arduino.cc/playground/Code/CapacitiveSensor
                            Great post from @petewill and nice version from AWI. Thanks!
                            #define SV "1.2"
                            #define NODE_ID 20 // or set to AUTO if you want gw to assign a NODE_ID for you.
                            const byte KEYPAD_CHILD_ID = 1 ;
                            long time = 0;
                            long debounce = 800;
                            const byte keyLeds[] = {14, 15, 16, 17}; //LEDs to turn on/off
                            const byte keyPins[] = {2, 3, 4, 5}; //capacitive keys
                            byte keyState = B1111; //save LEDs states
                            Serial.begin(9600);
                            for (byte i = 0 ; i < sizeof(keyLeds) ; i++)
                            { pinMode(keyLeds[i], OUTPUT);
                            uint8_t pinRead;
                            pinRead = readCapacitivePin(keyPins[i]);
                            if (pinRead > 2 && millis() - time > debounce) {
                            digitalWrite(keyLeds[i], bitRead(keyState,i));
                            if (bitRead(keyState,i) == 1){
                            gw.send(scene_on.set(keyPins[i]));
                            bitWrite(keyState, i, 0);} else
                            {gw.send(scene_off.set(keyPins[i]));
                            bitWrite(keyState, i, 1);}
                            time = millis();
                            // — readCapPin found at http://www.arduino.cc/playground/Code/CapacitiveSensor
                            uint8_t readCapacitivePin(int pinToMeasure) {
                            // Variables used to translate from Arduino to AVR pin naming
                            volatile uint8_t* port;
                            volatile uint8_t* ddr;
                            volatile uint8_t* pin;
                            // Here we translate the input pin number from
                            // Arduino pin number to the AVR PORT, PIN, DDR,
                            // and which bit of those registers we care about.
                            byte bitmask;
                            port = portOutputRegister(digitalPinToPort(pinToMeasure));
                            ddr = portModeRegister(digitalPinToPort(pinToMeasure));
                            bitmask = digitalPinToBitMask(pinToMeasure);
                            pin = portInputRegister(digitalPinToPort(pinToMeasure));
                            // Discharge the pin first by setting it low and output
                            *port &= ~(bitmask);
                            *ddr |= bitmask;
                            delay(1);
                            // Make the pin an input with the internal pull-up on
                            *ddr &= ~(bitmask);
                            *port |= bitmask;
                            // Now see how long the pin to get pulled up. This manual unrolling of the loop
                            // decreases the number of hardware cycles between each read of the pin,
                            // thus increasing sensitivity.
                            uint8_t cycles = 17;
                            if (*pin & bitmask) { cycles = 0;}
                            else if (*pin & bitmask) { cycles = 1;}
                            else if (*pin & bitmask) { cycles = 2;}
                            else if (*pin & bitmask) { cycles = 3;}
                            else if (*pin & bitmask) { cycles = 4;}
                            else if (*pin & bitmask) { cycles = 5;}
                            else if (*pin & bitmask) { cycles = 6;}
                            else if (*pin & bitmask) { cycles = 7;}
                            else if (*pin & bitmask) { cycles = 8;}
                            else if (*pin & bitmask) { cycles = 9;}
                            else if (*pin & bitmask) { cycles = 10;}
                            else if (*pin & bitmask) { cycles = 11;}
                            else if (*pin & bitmask) { cycles = 12;}
                            else if (*pin & bitmask) { cycles = 13;}
                            else if (*pin & bitmask) { cycles = 14;}
                            else if (*pin & bitmask) { cycles = 15;}
                            else if (*pin & bitmask) { cycles = 16;}
                            // Discharge the pin again by setting it low and output
                            // It’s important to leave the pins low if you want to
                            // be able to touch more than 1 sensor at a time – if
                            // the sensor is left pulled high, when you touch
                            // two sensors, your body will transfer the charge between
                            // sensors.
                            *ddr |= bitmask;
                            return cycles;
                            DrJeffD petewillP 2 Replies Last reply
                            • F Fred LaR
                              #define SV "1.2"
                              long time = 0;
                              Serial.begin(9600);
                              uint8_t pinRead;
                              time = millis();
                              byte bitmask;
                              *ddr |= bitmask;
                              delay(1);
                              *ddr &= ~(bitmask);
                              *port |= bitmask;
                              // sensors.
                              *ddr |= bitmask;
                              return cycles;
                              DrJeffD
                              DrJeffD
                              DrJeff
                              @Fred-LaR WOW!
                              You just perked up my intrest got to try this one!
                                msebbe
                                Anybody made some Nice enclosure for this?
                                • F Fred LaR
                                  #define SV "1.2"
                                  long time = 0;
                                  Serial.begin(9600);
                                  uint8_t pinRead;
                                  time = millis();
                                  byte bitmask;
                                  *ddr |= bitmask;
                                  delay(1);
                                  *ddr &= ~(bitmask);
                                  *port |= bitmask;
                                  // sensors.
                                  *ddr |= bitmask;
                                  return cycles;
                                  petewillP
                                  petewillP
                                  petewill
                                  @Fred-LaR That's a great idea. Nice!
                                  • Michal MormonM
                                    Michal MormonM
                                    Michal Mormon
                                    My domoticz found S_SCENE_CONTROLLER sensor but there is not any devices for such a hardware. Do you know how can I control scene with it?
                                    mfalkviddM M 2 Replies Last reply
                                    • Michal MormonM Michal Mormon
                                      @Michal-Mormon which version of Domoticz are you using?
                                      • Michal MormonM
                                        Michal MormonM
                                        Michal Mormon
                                        Domoticz v.2.4633
                                        • Michel - ItM
                                          Michel - ItM
                                          Michel - It
                                          lua script?
