  3. How To: Make a Simple/Cheap Scene Controller (with video)
62 Posts 19 Posters 48.8k Views 15 Watching
  • AWIA AWI
    Not even close to @petewill 's great build descriptions but here my version the "touch" version which can be battery operated. The used keyboard uses around 150uA. The touch panel generates an interrupt which wakes the arduino, reads the key and swiches a scene.
    upload-10b4b56c-4f8e-4f43-ac06-69217e48adcb
    The code below toggles between 'Scene ON' and 'Scene OFF' and stores the last state in EEPROM.
    All credits to @petewill
     * Version 1.0 - PeteWill
     *   	   1.1 - AWI
     * A simple scene controller for use with MySensors.  8 scenes can be executed
     *  with an 8 key keypad, make sure to attach the pins and fill keyPins[] resp.
     * Watch a how to video here: https://youtu.be/KMGj5Bi7vL0
    #define SN "Scene Controller"
    #define SV "1.0"
    #define NODE_ID 14 // or set to AUTO if you want gw to assign a NODE_ID for you.
    const byte KEYPAD_CHILD_ID = 0 ;
    MyMessage scene_on(KEYPAD_CHILD_ID, V_SCENE_ON);
    MyMessage scene_off(KEYPAD_CHILD_ID, V_SCENE_OFF);
    const int DV = 2;									//DataValid (=key pressed) pin goes there
    const int DV_int = DV-2;							//DataValid interrupt on pin 3 => 1
    const unsigned long SLEEP_TIME = 3600000 ;			// sleep for an hour (or more if you want to)
    volatile boolean DVint = false ; 					// interrupt flag, set by interrupt
    const byte keyPins[] = {A0, A1, A2, A3, 3, 4, 5, 6};// keypad pins, (8 pin keyboard)
    byte keyState[8]  ;									// hold current keystate (copy of EEPROM)
    void setup(){
    	gw.begin(NULL, NODE_ID);
    	gw.sendSketchInfo(SN, SV);
    	gw.present(KEYPAD_CHILD_ID, S_SCENE_CONTROLLER);
    	pinMode(DV,INPUT);          					// Data Valid (interrupt)
    	for (int i=0 ; i < sizeof(keyPins); i++){
    		keyState[i] = gw.loadState(i) ; 			// load last Scenestates from EEPROM
    // loop only if interrupt, else sleep
    void loop(){
        // if so get a key value and send to MySensosrs network
    	byte key = fetchData();    						// if so fetch key
        Serial.println(key);							// serial print as binary
    	if (key > 0){									// (key-1) is used as index
    		boolean keyVal = !gw.loadState(key-1);		// use lastState from EEPROM and toggle
    		gw.saveState(key-1, keyVal);				// save new state to EEPROM
    		if (keyVal) gw.send(scene_on.set(key-1));	// set the Scene On or Off
    		else gw.send(scene_off.set(key-1));
        DVint=false;									// reset interrupt flag
    	gw.sleep(DV_int, RISING, SLEEP_TIME);			// node wakes up on key interrupt or time
    	Serial.println(" key pressed or time trigger ");
    // interrupt routine, only sets flag
    void intrp(){DVint = true;};
    // fetch serial data, only highest number key is returned
    byte fetchData(){
    	int Key=0;                        				// default key = 0 (nothing pressed)
    	for (byte i = 0 ; i < sizeof(keyPins) ; i++){	// check each key,
    		if(digitalRead(keyPins[i]) == HIGH) Key=i+1;// set key if pressed (now only highest key)
    	return Key;										// return Key (0 if no key pressed)
    petewillP
    petewillP
    petewill
    @AWI Excellent, thanks for adding the code for the capacitive touch, battery operated sensor! I added a link to your post in my initial post.
    • B
      B
      brom_snor
      Hi Petewill
      I 'd like to build your Scene Controller but I am missing the keypad.h library. Where can I get it?
      greetings
      Brom_Snor
      petewillP 1 Reply Last reply
      • B brom_snor
        Hi Petewill
        greetings
        Brom_Snor
        petewillP
        petewillP
        petewill
        @brom_snor
        Sorry about that. I thought it was part of the default libraries. I must have downloaded it a while ago. This one should work: http://playground.arduino.cc/Code/Keypad
        • F
          F
          Fred LaR
          Hi all - Another capacitive version with an "out of the bottle" keypad - 4 buttons. Like AWI's version, also toggles between 'Scene ON' and 'Scene OFF', but states are kept in a variable (keyState) - LEDs added for better toogle visibility. Capacitive routine found at http://www.arduino.cc/playground/Code/CapacitiveSensor
          Great post from @petewill and nice version from AWI. Thanks!
          #define SV "1.2"
          #define NODE_ID 20 // or set to AUTO if you want gw to assign a NODE_ID for you.
          const byte KEYPAD_CHILD_ID = 1 ;
          long time = 0;
          long debounce = 800;
          const byte keyLeds[] = {14, 15, 16, 17}; //LEDs to turn on/off
          const byte keyPins[] = {2, 3, 4, 5}; //capacitive keys
          byte keyState = B1111; //save LEDs states
          Serial.begin(9600);
          for (byte i = 0 ; i < sizeof(keyLeds) ; i++)
          { pinMode(keyLeds[i], OUTPUT);
          uint8_t pinRead;
          pinRead = readCapacitivePin(keyPins[i]);
          if (pinRead > 2 && millis() - time > debounce) {
          digitalWrite(keyLeds[i], bitRead(keyState,i));
          if (bitRead(keyState,i) == 1){
          gw.send(scene_on.set(keyPins[i]));
          bitWrite(keyState, i, 0);} else
          {gw.send(scene_off.set(keyPins[i]));
          bitWrite(keyState, i, 1);}
          time = millis();
          // — readCapPin found at http://www.arduino.cc/playground/Code/CapacitiveSensor
          uint8_t readCapacitivePin(int pinToMeasure) {
          // Variables used to translate from Arduino to AVR pin naming
          volatile uint8_t* port;
          volatile uint8_t* ddr;
          volatile uint8_t* pin;
          // Here we translate the input pin number from
          // Arduino pin number to the AVR PORT, PIN, DDR,
          // and which bit of those registers we care about.
          byte bitmask;
          port = portOutputRegister(digitalPinToPort(pinToMeasure));
          ddr = portModeRegister(digitalPinToPort(pinToMeasure));
          bitmask = digitalPinToBitMask(pinToMeasure);
          pin = portInputRegister(digitalPinToPort(pinToMeasure));
          // Discharge the pin first by setting it low and output
          *port &= ~(bitmask);
          *ddr |= bitmask;
          delay(1);
          // Make the pin an input with the internal pull-up on
          *ddr &= ~(bitmask);
          *port |= bitmask;
          // Now see how long the pin to get pulled up. This manual unrolling of the loop
          // decreases the number of hardware cycles between each read of the pin,
          // thus increasing sensitivity.
          uint8_t cycles = 17;
          if (*pin & bitmask) { cycles = 0;}
          else if (*pin & bitmask) { cycles = 1;}
          else if (*pin & bitmask) { cycles = 2;}
          else if (*pin & bitmask) { cycles = 3;}
          else if (*pin & bitmask) { cycles = 4;}
          else if (*pin & bitmask) { cycles = 5;}
          else if (*pin & bitmask) { cycles = 6;}
          else if (*pin & bitmask) { cycles = 7;}
          else if (*pin & bitmask) { cycles = 8;}
          else if (*pin & bitmask) { cycles = 9;}
          else if (*pin & bitmask) { cycles = 10;}
          else if (*pin & bitmask) { cycles = 11;}
          else if (*pin & bitmask) { cycles = 12;}
          else if (*pin & bitmask) { cycles = 13;}
          else if (*pin & bitmask) { cycles = 14;}
          else if (*pin & bitmask) { cycles = 15;}
          else if (*pin & bitmask) { cycles = 16;}
          // Discharge the pin again by setting it low and output
          // It’s important to leave the pins low if you want to
          // be able to touch more than 1 sensor at a time – if
          // the sensor is left pulled high, when you touch
          // two sensors, your body will transfer the charge between
          // sensors.
          *ddr |= bitmask;
          return cycles;
          DrJeffD petewillP 2 Replies Last reply
          • F Fred LaR
            #define SV "1.2"
            long time = 0;
            Serial.begin(9600);
            uint8_t pinRead;
            time = millis();
            byte bitmask;
            *ddr |= bitmask;
            delay(1);
            *ddr &= ~(bitmask);
            *port |= bitmask;
            // sensors.
            *ddr |= bitmask;
            return cycles;
            DrJeffD
            DrJeffD
            DrJeff
            @Fred-LaR WOW!
            You just perked up my intrest got to try this one!
              msebbe
              Anybody made some Nice enclosure for this?
              • F Fred LaR
                #define SV "1.2"
                long time = 0;
                Serial.begin(9600);
                uint8_t pinRead;
                time = millis();
                byte bitmask;
                *ddr |= bitmask;
                delay(1);
                *ddr &= ~(bitmask);
                *port |= bitmask;
                // sensors.
                *ddr |= bitmask;
                return cycles;
                petewillP
                petewillP
                petewill
                @Fred-LaR That's a great idea. Nice!
                • Michal MormonM
                  Michal MormonM
                  Michal Mormon
                  My domoticz found S_SCENE_CONTROLLER sensor but there is not any devices for such a hardware. Do you know how can I control scene with it?
                  mfalkviddM M 2 Replies Last reply
                  • Michal MormonM Michal Mormon
                    @Michal-Mormon which version of Domoticz are you using?
                    • Michal MormonM
                      Michal MormonM
                      Michal Mormon
                      Domoticz v.2.4633
                      • Michel - ItM
                        Michel - ItM
                        Michel - It
                        lua script?
                        • Michel - ItM Michel - It
                          lua script?
                          petewillP
                          petewillP
                          petewill
                          @Michel---It said:
                          lua script?
                          Sorry, not sure what you're asking.
                            Maciej Kulawik
                            @Michal-Mormon
                            S_SCENE_CONTROLLER can send messages V_SCENE_ON and V_SCENE_OFF. If you send those messages for the first time, domoticz will create new switch with the name 'scene'.
                            Michal MormonM 1 Reply Last reply
                            • M Maciej Kulawik
                              @Michal-Mormon
                              Michal MormonM
                              Michal MormonM
                              Michal Mormon
                              @Maciej-Kulawik
                              I found it as 'Scene' switch but this example send only V_SCENE_ON the first time (the switch is still ON later)
                                @Maciej-Kulawik
                                Maciej Kulawik
                                @Michal-Mormon
                                Yes, exactly! It looks like without scene_off sent from scene controller in domoticz it will be one-time action (since if this scene switch is switched on you cannot switch it on again). You can try to setup automatic switching it off in domoticz.
                                • Michal MormonM
                                  Michal MormonM
                                  Michal Mormon
                                  I added 2 lines and works perfect with Domoticz:
                                  MyMessage scene(KEYPAD_CHILD_ID, V_SCENE_ON);
                                  MyMessage scene2(KEYPAD_CHILD_ID, V_SCENE_OFF); //added line
                                  gw.send(scene.set(keyInt));
                                  gw.send(scene2.set(keyInt)); //added line
                                  Michel - ItM 1 Reply Last reply
                                    Michel - ItM
                                    Michel - ItM
                                    Michel - It
                                    @Michal-Mormon awesome!
                                    • DrJeffD
                                      DrJeffD
                                      DrJeff
                                      @petewill Have you updated this code to 2.0 yet? What is different?
                                      hekH petewillP 2 Replies Last reply
                                      • DrJeffD DrJeff
                                        @DrJeff
                                        https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                                        DrJeffD 1 Reply Last reply
                                          @DrJeff
                                          DrJeffD
                                          DrJeffD
                                          DrJeff
                                          @hek
                                          Yes I read but was soooo lazy! I just wanted it already done :grimacing:
                                          I just update one of my old sensors it was a simple single relay. My others are way more complicated! I will give this a try.
