  3. How to deal with a request for information from controller?
20 Posts 8 Posters 13.3k Views 7 Watching
  • K
    K
    kalle
    Ahh ok, know I understand it - so it looks like you have successfully merged this funktion in the sketch.
    Is it possible to share the sketch which has include the ack?
    Kallle
      marcusvdt
      Yes, I have done it already. Now I need to migrate all enhancements from my "Secret Clap Lights" sketch to the RGB controller sketch developed by Dave. I will share it with you guys once it is done. I'm now working on some enhancements on the Vox Commando part. Not sure yet if all of my ideas will work, but they look promising.
      I'm working to get Vox Commando to be smarter when working with My Sensors.
      The idea consists of making it know in advance what commands make sense for each type of sensor/actuator. Different values will be accepted as phrases and payloads for different devices automatically. No need to create a new command for every new standard sensor that you add to your network.
      It is a hard job it seems, but I think it is possible.
        marcusvdt
        @hek
        I have solved this by implementing a response for messages of type=2 on every sensor that I build, in addition to the processing for type=1 that is already included in the examples. Could you please confirm if this is supported or designed to work like this?
        I'm using my own custom controller that has support to send messages of type=2 (type=request) and it does process the responses from the nodes correctly, because the responses from the nodes are just normal set messages (type=1).
        barduinoB 1 Reply Last reply
        • M marcusvdt
          @hek
          barduinoB
          barduinoB
          barduino
          wrote on last edited by barduino
          @marcusvdt
          Very interesting point!
          I had the exact same though.
          Wouldn't it be nice to have a feature on the controller to request the latest info from the sensor using the request message.
          Most examples I see do not implement this. I wonder if the original idea behind the request message was for inter sensor communication.
          Probably when the sensor is sleeping, an incoming message will be ignored. I wonder if when it wakes up and does the process it picks it up?
          The use case is something like a temperature sensor, sending the datava every 15 minutes and sleeping in between.
          Can you post your latest code snippet?
            marcusvdt
            @barduino
            I'll post it for you tomorrow, but my main concern is to keep the things as much as possible conform the design of this protocol. It's because I don't want that my future version upgrades turn into a nightmare.
            That's why I wanted someone from mysensors staff to tell me about this.
            IMHO, there are many legitimate reasons for a controller needing to request information to sensors.
            In my case, I have light actuators that I designed to work either from a standard wall switch or by commands sent from the controller or by claps. I find the need to request information from the actuator node because sometimes the computer where the controller is running could be unreachable. Also some times the radio can fail. And sometimes I could just want to make sure the current status shown on my controller matches the current status of the actual node. Also, like you said, this allows node to request information from other nodes.
              @marcusvdt
              You are right, the idea (with REQ comands) was to let node requests response with a SET-command back to the requester. The examples does not have this functionality implemented. And as you might have suspected it was mainly thought to be used between sensors. But I haven't really had any use for it myself in my setup (easier to just push messages that do the request-setup).
              But there are use-cases, especially for sleeping nodes that can wake up and request data and go back to sleep when they have received their response.
              • G
                G
                gonzalonal
                Hi, is there any way in which I can identify the message type in my incomingMessage function?
                void incomingMessage(const MyMessage &message)
                	**//I need to identify firstly the command type (REQ, SET,PRESENTATION,etc)**
                	// if(message.type == C_REQ)
                if (message.type == V_LIGHT) // this would be the subtype
                		if ((message.sensor - StartingChildID)  < noZones)
                			Relays[message.sensor - StartingChildID].relayState = message.getBool();
                I need to be able to request values at will from nodes. Mainly for debug purposes.
                Thanks. Regards
                  mGetCommand(message)
                  • G
                    G
                    gonzalonal
                    Shouldn't be nice to have this feature directly emebebed in Mysensors library (as the ack request feature)?
                    I mean, if I send a status request for a sensor through the controller, to ahve the library automaticcaly answer this type of messages.
                    • A
                      alfredocdmiranda
                      @hek Why there is no method getCommand() in MyMessage object like isAck()?
                      hekH 1 Reply Last reply
                      • A alfredocdmiranda
                        @alfredocdmiranda
                        good question. :)
                        • A
                          alfredocdmiranda
                          Is there any chance to create it for next version?
                            @alfredocdmiranda
                            I'll put it on the list.
                            • M marcusvdt
                              Well, it seems nobody has either the motivation or the answer itself... Wonder if I should have posted this question in the Development forum instead...
                              I've been researching and doing some trial and error since I posted the question, and it seems I found a way of doing it. Not sure if this is the correct way because I just did not find any documentation about it, but I'll share my discoveries anyway since it can help others.
                              It seems the ack part is done automatically by the library itself. I've been able to see ack messages returning from the gateway to the controller without doing any treatment myself in my sketch.
                              Regarding how to differentiate "req" messages sent from the controller to a node, I've been able to detect if a message is a "req" one by reading the value of mGetCommand(message) in my sketch. If this is equal to 2, then it is a "req" message, if it is equal to 1, then it is a "set" message.
                              //debug only
                              //Serial.print("message.destination=");
                              //Serial.println(message.destination);
                              //Serial.print("message.type=");
                              //Serial.println(message.type);
                              //Serial.print("message.sensor");
                              //Serial.println(message.sensor);
                              int comando = mGetCommand(message);
                              //Serial.print("comando=");
                              //Serial.println(comando);
                                if (message.type==V_LIGHT) {
                                  //comando=2 means information has been requested from controller, so we will send it back.
                                  //comando=1 means a new status has been received from controller to the node, so we will act as requested.
                                  if (comando==2){
                                    gw.send(lightMsg.set(digitalRead(lightPin)));
                                  if (comando==1){
                                    // Change relay state
                                    setLightState(message.getBool(), false);
                                    Serial.print("Incoming light status:");
                                if (message.type==V_VAR1) {
                                  // Toggle program mode
                                  if (programModeActive == false){     // If we're not in programming mode, turn it on.
                                    programmingmode(1);
                                  } else {                             // If we are in programing mode, turn it off.
                                    programmingmode(0);
                                  Serial.print("Toggled program mode:");
                              And below are the tests that show what I mentioned.
                              Sent this, which sets the light child 99 on node 51 to 1 (on), requesting an ack
                              51;99;1;1;2;1
                              0;0;3;0;9;send: 0-0-51-51 s=99,c=1,t=2,pt=0,l=1,st=ok:1
                              0;0;3;0;9;read: 51-51-0 s=99,c=1,t=2,pt=0,l=1:1
                              51;99;1;1;2;1
                              The last one is the ack itself that returned from the gateway to the controller.
                              Then sent this, which requests the status of light child 99 on node 51, requesting an ack. Should return the ack and the response containing the current status of the light (1).
                              51;99;2;1;2;anything
                              0;0;3;0;9;send: 0-0-51-51 s=99,c=2,t=2,pt=0,l=8,st=ok:anything
                              0;0;3;0;9;read: 51-51-0 s=99,c=2,t=2,pt=0,l=8:anything
                              0;0;3;0;9;read: 51-51-0 s=99,c=1,t=2,pt=2,l=2:1
                              51;99;1;0;2;1
                              This "51;99;2;1;2;anything" is the ack generated automatically by the library, and this "51;99;1;0;2;1" is the response that my program performs. Correct!
                              Then sent this, which sets the light child 99 on node 51 to 0 (off), requesting an ack
                              51;99;1;1;2;0
                              0;0;3;0;9;send: 0-0-51-51 s=99,c=1,t=2,pt=0,l=1,st=ok:0
                              0;0;3;0;9;read: 51-51-0 s=99,c=1,t=2,pt=0,l=1:0
                              51;99;1;1;2;0
                              The last one above is the ack generated automatically by the library.
                              Then sent this, which requests the status of light child 99 on node 51, requesting an ack. Should return the ack and the response containing the current status of the light (0).
                              0;0;3;0;9;read: 51-51-0 s=99,c=1,t=2,pt=2,l=2:0
                              51;99;1;0;2;0
                              This "51;99;2;1;2;anything" is the ack generated automatically by the library, and this "51;99;1;0;2;0" is the response that my program performs. Correct!
                              K
                              K
                              Kumar Ratnanabh
                              @marcusvdt said:
                              lightMsg
                              Hello
                              I wanted the same functionality and during forum found your post.
                              Can you please post your code as attached code block has missing functions e.g lightMsg.set... SetLightState(..
                              Ratnanabh
                              • rollercontainerR
                                rollercontainerR
                                rollercontainer
                                I would like to share my sketch for 2.0.0-beta. Its a node with two relays and the ability to read the status from mqtt.
                                // Relais Node for MySensors 2.0.0-beta
                                // I am using the filename and compile date for sktech announcements:
                                #include <string.h>
                                // Strip the path info from __FILE__
                                // For Windows use '\\' instead of '/'.
                                #define __FILENAME__ (strrchr(__FILE__, '\\') ? strrchr(__FILE__, '\\') + 1 : __FILE__)
                                // #define MY_DEBUG
                                #define SKETCH_NAME __FILENAME__
                                #define SKETCH_DATE __DATE__
                                #define MY_NODE_ID 2
                                #define MY_PARENT_NODE_ID 0
                                #define MY_REPEATER_FEATURE false
                                #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                                void before() {
                                    pinMode(pin, OUTPUT);
                                  sendSketchInfo(SKETCH_NAME, SKETCH_DATE);
                                    present(sensor, S_LIGHT);
                                int msgcmd = mGetCommand(message);
                                  // Verify its a switch command (V_LIGHT)
                                    // Command type 1 is a set command
                                     if (msgcmd==1){
                                       // Store state in eeprom
                                   // Command type 2 is a request for the sensor state
                                   if (msgcmd==2){
                                       // construct message body with requested sensor-id and type V_LIGHT (= switch)
                                       MyMessage msg(message.sensor,V_LIGHT);
                                       // Example: requested sensor is 2 (message.sensor).
                                       // The programm reads the digital pin 4, calculated by 2 (sensor) - 1 (static) + 3 (first relay pin)
                                       // after that, the reading is compared to the RELAY_ON value (might be invers logic, regarding to your relais schematic)
                                       // if it is matching, the payload is set to 1, otherwise its set to 0
                                       send(msg.set(digitalRead(message.sensor-1+RELAY_1) == RELAY_ON ? 1 : 0));
                                and here are the lines in my openhab2 items.item:
                                Switch node2_sw1   "N2SW1"    (all,node2)    { mqtt=">[mosquitto:mysensors-in/2/1/1/0/2:command:ON:1],>[mosquitto:mysensors-in/2/1/1/0/2:command:OFF:0],<[mosquitto:mysensors-out/2/1/2/0/2:state:default]" }
                                Switch node2_sw2   "N2SW2"    (all,node2)    { mqtt=">[mosquitto:mysensors-in/2/2/1/0/2:command:ON:1],>[mosquitto:mysensors-in/2/2/1/0/2:command:OFF:0],<[mosquitto:mysensors-out/2/2/2/0/2:state:default]" }
                                I would like to repeat: Its for the last versions of mysensors and openhab2. Notice the absence of any "gw." and the different structure in the mqtt strings !
                                Can someone tell me, if it is a problem to redefine the "MyMessage msg(message.sensor,V_LIGHT); " every time a request is done? I am not sure.
                                Greetings
                                rollercontainerR 1 Reply Last reply
                                • rollercontainerR rollercontainer
                                  #include <string.h>
                                  // #define MY_DEBUG
                                  void before() {
                                       if (msgcmd==1){
                                     if (msgcmd==2){
                                  Greetings
                                  rollercontainerR
                                  rollercontainerR
                                  rollercontainer
                                  I dont see openHAB requesting any state, so maybe its a better idea to read the state of the output pin immediately after setting the relay and publish this and bind it to a control lamp. If this isnt toggling, the command wasnt received.
