  3. Domoticz
  4. nrf24l01+ RPi2 direct connection problem
13 Posts 5 Posters 8.7k Views 5 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    @Mediacj - I have just noticed you had a similar issue. Care to share how you resolved it please?
    @hek - Do you know if the problem is only in librf24-bcm.so.1.0?
      Mediacj
      wrote on last edited by Mediacj
      I didn't get it to work unfortunately.
      alexsh1A 1 Reply Last reply
      • M Mediacj
        alexsh1A
        alexsh1A
        alexsh1
        Damn! All google links are only to this website and it looks like there is no solution to this issue for now. Thanks for your reply though
          salvato
          Hello.
          I think that the problem related to the messsage:
          error: invalid suffix "x" on integer constant
          come from a problem in the Makefile of the librf24-bcm.
          There you can find the following line:
          IOBASE := $(shell cat /proc/iomem | grep bcm2708_vcio | cut -f 1 -d "-")
          This try to find the memory base address of the peripherals in the Raspberry that is variable between the different models.
          In my Raspberry the /proc/iomem file does not contain any information about bcm2708_vcio and the string returned is empty (in my case should be 0x20000000)
          You could try to hard code the correct value in the Makefile.
          Hope this help
          • alexsh1A
            alexsh1A
            alexsh1
            @salvato Thanks very much!
            The makefile has to be changed to
            This is for the standard PI
            amend the following:
            #define BCM2835_PERI_BASE 0x3F000000
            I can confirm - now it works and everything compiles fine!
            S 1 Reply Last reply
            • alexsh1A alexsh1
              salvato
              @alexsh1
              Happy to have solved your problem.
              • L
                L
                lubo
                Hi guys, i have the same problem with compiling librf24-bcm library on RPI2. I have changed line "#define BCM2835_PERI_BASE 0x20000000" to "#define BCM2835_PERI_BASE 0x3F000000" in bcm2835.h file but it didnt help. I still get compiling error "bcm2835.c:1253:79: error: invalid suffix "x" on integer constant
                Makefile:52: recipe for target 'bcm2835.o' failed". What else need to be changed ? thanks
                L 1 Reply Last reply
                • L lubo
                  L
                  L
                  lubo
                  @lubo
                  oh i had to update CCFLAGS += -D BCM2835_PERI_BASE=0x${IOBASE} to CCFLAGS += -D BCM2835_PERI_BASE=0x3F000000 in makefile and it works now thanks :)
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    @lubo Ok, you have figured it out. Excellent! It is the makefile which has to be changed
                      salvato
                      well... I made a different modification:
                      I changed the row
                      in
                      IOBASE := 20000000
                      (3F000000 in your case)
                      • E
                        E
                        Eawo
                        Wow nice and easy to follow. I had the error but the error thread helped me.
                        Just wondering why does it say its running "MySensors Gateway USB
                        Version: 1.4"
                        • E Eawo
                          Version: 1.4"
                          alexsh1A
                          alexsh1A
                          alexsh1
                          Because it is running MS v1.4 (current is v1.5 and development is v1.6) :-)
                          If you wonder why it says USB, it emulates USB.
                          Version: 1.4"
